[petsc-users] parallel dual porosity
Stefano Zampini
stefano.zampini at gmail.com
Thu May 30 00:26:36 CDT 2019
Matt,
redistribution with overlapped mesh is fixed in master (probably also in
maint)
Stefano
Il Gio 30 Mag 2019, 06:09 Matthew Knepley via petsc-users <
petsc-users at mcs.anl.gov> ha scritto:
> On Wed, May 29, 2019 at 10:54 PM Adrian Croucher <
> a.croucher at auckland.ac.nz> wrote:
>> On 30/05/19 2:45 PM, Matthew Knepley wrote:
>> Hmm, I had not thought about that. It will not do that at all. We have
>> never rebalanced a simulation
>> using overlap cells. I would have to write the code that strips them out.
>> Not hard, but more code.
>> If you only plan on redistributing once, you can wait until then to add
>> the overlap cells.
>> So for now at least, you would suggest doing the initial distribution
>> with overlap = 0, and then the redistribution with overlap = 1?
>> (I shouldn't need to redistribute more than once.)
> Yep. Those actions are actually separate too. All Distribute() does is
> first distribute with no overlap, and then call DIstributeOverlap().
> Thanks,
> Matt
>> - Adrian
>> Dr Adrian Croucher
>> Senior Research Fellow
>> Department of Engineering Science
>> University of Auckland, New Zealand
>> email: a.croucher at auckland.ac.nz
>> tel: +64 (0)9 923 4611
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190530/2abd6f7f/attachment.html>
