[petsc-users] parallel dual porosity
Adrian Croucher
a.croucher at auckland.ac.nz
Wed May 29 21:54:24 CDT 2019
On 30/05/19 2:45 PM, Matthew Knepley wrote:
> Hmm, I had not thought about that. It will not do that at all. We have
> never rebalanced a simulation
> using overlap cells. I would have to write the code that strips them
> out. Not hard, but more code.
> If you only plan on redistributing once, you can wait until then to
> add the overlap cells.
So for now at least, you would suggest doing the initial distribution
with overlap = 0, and then the redistribution with overlap = 1?
(I shouldn't need to redistribute more than once.)
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190530/02e80bdc/attachment.html>
