[petsc-users] Getting n largest and m smallest eigenvalues from SLEPc at the same time
Jose E. Roman
jroman at dsic.upv.es
Mon May 27 04:43:17 CDT 2019
The options -eps_largest_real -eps_smallest_real are exclusive.
The second one, overrides the first one, because both of them call http://slepc.upv.es/documentation/current/docs/manualpages/EPS/EPSSetWhichEigenpairs.html
You should run the example twice, or create a program that calls EPSSolve() twice.
Jose
> El 27 may 2019, a las 11:36, Afrah Najib via petsc-users <petsc-users at mcs.anl.gov> escribió:
> Hi,
> I have very large matrices and limited CPU hours and I want to get the first n largest and m smallest eigenvalues form these matrices using SLEPc without calculating all of them.
> I tried with this command :
> mpirun -n 2 ./ex4 -file bcsstk17.bin -eps_max_it 10000 -eps_ncv 24 -eps_tol 1.0e-8 -eps_type gd -eps_nev 6 -eps_largest_real -eps_smallest_real
> but it returns the first smallest eigenvalues only.
> Any idea,
