[petsc-users] Singlar values of the GMRES Hessenberg matrix
Matthew Knepley
knepley at gmail.com
Thu May 23 05:20:19 CDT 2019
On Thu, May 23, 2019 at 5:09 AM Dave Lee via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi PETSc,
> I'm trying to add a "hook step" to the SNES trust region solver (at the
> end of the function: KSPGMRESBuildSoln())
> I'm testing this using the (linear) example:
> src/ksp/ksp/examples/tutorials/ex1.c
> as
> gdb --args ./test -snes_mf -snes_type newtontr -ksp_rtol 1.0e-12
> -snes_stol 1.0e-12 -ksp_converged_reason -snes_converged_reason
> -ksp_monitor -snes_monitor
> (Ignore the SNES stuff, this is for when I test nonlinear examples).
> When I call the LAPACK SVD routine via PETSc as
> PetscStackCallBLAS("LAPACKgesvd",LAPACKgesvd_(...))
> I get the following singular values:
> 0 KSP Residual norm 7.071067811865e-01
> 1 KSP Residual norm 3.162277660168e-01
> 2 KSP Residual norm 1.889822365046e-01
> 3 KSP Residual norm 1.290994448736e-01
> 4 KSP Residual norm 9.534625892456e-02
> 5 KSP Residual norm 8.082545620881e-16
> 1 0.5 -7.85046e-16 1.17757e-15
> 0.5 1 0.5 1.7271e-15
> 0 0.5 1 0.5
> 0 0 0.5 1
> 0 0 0 0.5
> singular values: 2.36264 0.409816 1.97794e-15 6.67632e-16
> Linear solve converged due to CONVERGED_RTOL iterations 5
> Where the lines above the singular values are the Hessenberg matrix that
> I'm doing the SVD on.
First, write out all the SVD matrices you get and make sure that they
reconstruct the input matrix (that
you do not have something transposed somewhere).
Matt
> When I build the solution in terms of the leading two right singular
> vectors (and subsequently the first two orthonormal basis vectors in
> VECS_VV I get an error norm as:
> Norm of error 3.16228, Iterations 5
> My suspicion is that I'm creating the Hessenberg incorrectly, as I would
> have thought that this problem should have more than two non-zero leading
> singular values.
> Within my modified version of the GMRES build solution function (attached)
> I'm creating this (and passing it to LAPACK as):
> nRows = gmres->it+1;
> nCols = nRows-1;
> ierr = PetscBLASIntCast(nRows,&nRows_blas);CHKERRQ(ierr);
> ierr = PetscBLASIntCast(nCols,&nCols_blas);CHKERRQ(ierr);
> ierr = PetscBLASIntCast(5*nRows,&lwork);CHKERRQ(ierr);
> ierr = PetscMalloc1(5*nRows,&work);CHKERRQ(ierr);
> ierr = PetscMalloc1(nRows*nCols,&R);CHKERRQ(ierr);
> ierr = PetscMalloc1(nRows*nCols,&H);CHKERRQ(ierr);
> for (jj = 0; jj < nRows; jj++) {
> for (ii = 0; ii < nCols; ii++) {
> R[jj*nCols+ii] = *HES(jj,ii);
> // Duplicate the Hessenberg matrix as the one passed to the SVD solver
> is destroyed
> for (ii=0; ii<nRows*nCols; ii++) H[ii] = R[ii];
> ierr = PetscMalloc1(nRows*nRows,&U);CHKERRQ(ierr);
> ierr = PetscMalloc1(nCols*nCols,&VT);CHKERRQ(ierr);
> ierr = PetscMalloc1(nRows*nRows,&UT);CHKERRQ(ierr);
> ierr = PetscMalloc1(nCols*nCols,&V);CHKERRQ(ierr);
> ierr = PetscMalloc1(nRows,&p);CHKERRQ(ierr);
> ierr = PetscMalloc1(nCols,&q);CHKERRQ(ierr);
> ierr = PetscMalloc1(nCols,&y);CHKERRQ(ierr);
> // Perform an SVD on the Hessenberg matrix - Note: this call destroys
> the input Hessenberg
> ierr = PetscFPTrapPush(PETSC_FP_TRAP_OFF);CHKERRQ(ierr);
> PetscStackCallBLAS("LAPACKgesvd",LAPACKgesvd_("A","A",&nRows_blas,&nCols_blas,R,&nRows_blas,S,UT,&nRows_blas,V,&nCols_blas,work,&lwork,&lierr));
> if (lierr) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"Error in SVD Lapack
> routine %d",(int)lierr);
> ierr = PetscFPTrapPop();CHKERRQ(ierr);
> // Find the number of non-zero singular values
> for(nnz=0; nnz<nCols; nnz++) {
> if(fabs(S[nnz]) < 1.0e-8) break;
> printf("number of nonzero singular values: %d\n",nnz);
> trans(nRows,nRows,UT,U);
> trans(nCols,nCols,V,VT);
> // Compute p = ||r_0|| U^T e_1
> beta = gmres->res_beta;
> for (ii=0; ii<nCols; ii++) {
> p[ii] = beta*UT[ii*nRows];
> p[nCols] = 0.0;
> // Original GMRES solution (\mu = 0)
> for (ii=0; ii<nnz; ii++) {
> q[ii] = p[ii]/S[ii];
> // Expand y in terms of the right singular vectors as y = V q
> for (jj=0; jj<nnz; jj++) {
> y[jj] = 0.0;
> y[jj] += V[jj*nCols+ii]*q[ii]; // transpose of the transpose
> // Pass the orthnomalized Krylov vector weights back out
> nrs[ii] = y[ii];
> I just wanted to check that this is the correct way to extract the
> Hessenberg from the KSP_GMRES structure, and to pass it to LAPACK, and if
> so, should I really be expecting only two non-zero singular values in
> return for this problem?
> Cheers, Dave.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190523/97804f56/attachment.html>
