[petsc-users] With-batch (new) flags
Mark Adams mfadams at lbl.gov
Mon May 20 15:10:45 CDT 2019
On Mon, May 20, 2019 at 3:55 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> for ex:  ilp version of mkl is --known-64-bit-blas-indices=1 while lp mkl
> is --known-64-bit-blas-indices=0
> Default blas we normally use is --known-64-bit-blas-indices=0 [they don't
> use 64bit indices]
Humm, that is what Dylan (in the log that I sent). He is downloading blas
and has --known-64-bit-blas-indices=0. Should this be correct?
> Satish
> On Mon, 20 May 2019, Mark Adams via petsc-users wrote:
> > We are getting this failure. This a bit frustrating in that the first
> error
> > message "Must give a default value for known-mpi-shared-libraries.." OK,
> I
> > google it and find that =0 is suggested. That seemed to work. Then we
> got a
> > similar error about -known-64-bit-blas-indices. It was clear from the
> > documentation what to use so we tried =0 and that failed (attached). This
> > is little frustrating having to use try and error for each of these
> 'known"
> > things.
> > Dylan is trying  --known-64-bit-blas-indices=1 now. I trust that will
> work,
> > but I think the error are not very informative. All this known stuff is
> new
> > to me. Perhaps put an FAQ for this and list all of the "known"s that we
> > need to add in batch.
> > Thanks,
> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190520/5a575476/attachment.html>
