[petsc-users] Calling LAPACK routines from PETSc
Dave Lee davelee2804 at gmail.com
Mon May 20 02:28:36 CDT 2019
Thanks Jed and Barry,
So, just to confirm,
-- From the KSP_GMRES structure, if I call *HH(a,b), that will return the
row a, column b entry of the Hessenberg matrix (while the back end array
*hh_origin array is ordering using the Fortran convention)
-- Matrices are passed into and returned from
PetscStackCallBLAS("LAPACKgesvd",LAPACKgesvd_() using Fortran indexing, and
need to be transposed to get back to C ordering
Are both of these statements correct?
Cheers, Dave.
On Mon, May 20, 2019 at 4:34 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>    The little work arrays in GMRES tend to be stored in Fortran ordering;
> there is no C style p[][] indexing into such arrays. Thus the arrays can
> safely be sent to LAPACK.  The only trick is knowing the two dimensions and
> as Jed say the "leading dimension parameter. He gave you a place to look
> > On May 20, 2019, at 1:24 AM, Jed Brown via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Dave Lee via petsc-users <petsc-users at mcs.anl.gov> writes:
> >> Hi Petsc,
> >> I'm attempting to implement a "hookstep" for the SNES trust region
> solver.
> >> Essentially what I'm trying to do is replace the solution of the least
> >> squares problem at the end of each GMRES solve with a modified solution
> >> with a norm that is constrained to be within the size of the trust
> region.
> >> In order to do this I need to perform an SVD on the Hessenberg matrix,
> >> which copying the function KSPComputeExtremeSingularValues(), I'm
> trying to
> >> do by accessing the LAPACK function dgesvd() via the
> PetscStackCallBLAS()
> >> machinery. One thing I'm confused about however is the ordering of the
> 2D
> >> arrays into and out of this function, given that that C and FORTRAN
> arrays
> >> use reverse indexing, ie: C[j+1][i+1] = F[i,j].
> >> Given that the Hessenberg matrix has k+1 rows and k columns, should I be
> >> still be initializing this as H[row][col] and passing this into
> >> PetscStackCallBLAS("LAPACKgesvd",LAPACKgrsvd_(...))
> >> or should I be transposing this before passing it in?
> > LAPACK terminology is with respect to Fortran ordering.  There is a
> > "leading dimension" parameter so that you can operate on non-contiguous
> > blocks.  See KSPComputeExtremeSingularValues_GMRES for an example.
> >> Also for the left and right singular vector matrices that are returned
> by
> >> this function, should I be transposing these before I interpret them as
> C
> >> arrays?
> >> I've attached my modified version of gmres.c in case this is helpful. If
> >> you grep for DRL (my initials) then you'll see my changes to the code.
> >> Cheers, Dave.
> >>    This file implements GMRES (a Generalized Minimal Residual) method.
> >>    Reference:  Saad and Schultz, 1986.
> >>    Some comments on left vs. right preconditioning, and restarts.
> >>    Left and right preconditioning.
> >>    If right preconditioning is chosen, then the problem being solved
> >>    by gmres is actually
> >>       My =  AB^-1 y = f
> >>    so the initial residual is
> >>          r = f - Mx
> >>    Note that B^-1 y = x or y = B x, and if x is non-zero, the initial
> >>    residual is
> >>          r = f - A x
> >>    The final solution is then
> >>          x = B^-1 y
> >>    If left preconditioning is chosen, then the problem being solved is
> >>       My = B^-1 A x = B^-1 f,
> >>    and the initial residual is
> >>       r  = B^-1(f - Ax)
> >>    Restarts:  Restarts are basically solves with x0 not equal to zero.
> >>    Note that we can eliminate an extra application of B^-1 between
> >>    restarts as long as we don't require that the solution at the end
> >>    of an unsuccessful gmres iteration always be the solution x.
> >> #include <../src/ksp/ksp/impls/gmres/gmresimpl.h>       /*I
> "petscksp.h"  I*/
> >> #include <petscblaslapack.h> // DRL
> >> #define GMRES_DELTA_DIRECTIONS 10
> >> #define GMRES_DEFAULT_MAXK     30
> >> static PetscErrorCode
> KSPGMRESUpdateHessenberg(KSP,PetscInt,PetscBool,PetscReal*);
> KSPGMRESBuildSoln(PetscScalar*,Vec,Vec,KSP,PetscInt);
> >> PetscErrorCode    KSPSetUp_GMRES(KSP ksp)
> >>  PetscInt       hh,hes,rs,cc;
> >>  PetscErrorCode ierr;
> >>  PetscInt       max_k,k;
> >>  KSP_GMRES      *gmres = (KSP_GMRES*)ksp->data;
> >>  PetscFunctionBegin;
> >>  max_k = gmres->max_k;          /* restart size */
> >>  hh    = (max_k + 2) * (max_k + 1);
> >>  hes   = (max_k + 1) * (max_k + 1);
> >>  rs    = (max_k + 2);
> >>  cc    = (max_k + 1);
> >>  ierr =
> PetscCalloc5(hh,&gmres->hh_origin,hes,&gmres->hes_origin,rs,&gmres->rs_origin,cc,&gmres->cc_origin,cc,&gmres->ss_origin);CHKERRQ(ierr);
> >>  ierr = PetscLogObjectMemory((PetscObject)ksp,(hh + hes + rs +
> 2*cc)*sizeof(PetscScalar));CHKERRQ(ierr);
> >>  if (ksp->calc_sings) {
> >>    /* Allocate workspace to hold Hessenberg matrix needed by lapack */
> >>    ierr = PetscMalloc1((max_k + 3)*(max_k +
> 9),&gmres->Rsvd);CHKERRQ(ierr);
> >>    ierr = PetscLogObjectMemory((PetscObject)ksp,(max_k + 3)*(max_k +
> 9)*sizeof(PetscScalar));CHKERRQ(ierr);
> >>    ierr = PetscMalloc1(6*(max_k+2),&gmres->Dsvd);CHKERRQ(ierr);
> >>    ierr =
> PetscLogObjectMemory((PetscObject)ksp,6*(max_k+2)*sizeof(PetscReal));CHKERRQ(ierr);
> >>  /* Allocate array to hold pointers to user vectors.  Note that we need
> >>   4 + max_k + 1 (since we need it+1 vectors, and it <= max_k) */
> >>  gmres->vecs_allocated = VEC_OFFSET + 2 + max_k + gmres->nextra_vecs;
> >>  ierr = PetscMalloc1(gmres->vecs_allocated,&gmres->vecs);CHKERRQ(ierr);
> >>  ierr =
> PetscMalloc1(VEC_OFFSET+2+max_k,&gmres->user_work);CHKERRQ(ierr);
> >>  ierr =
> PetscMalloc1(VEC_OFFSET+2+max_k,&gmres->mwork_alloc);CHKERRQ(ierr);
> >>  ierr =
> PetscLogObjectMemory((PetscObject)ksp,(VEC_OFFSET+2+max_k)*(sizeof(Vec*)+sizeof(PetscInt))
> + gmres->vecs_allocated*sizeof(Vec));CHKERRQ(ierr);
> >>  if (gmres->q_preallocate) {
> >>    gmres->vv_allocated = VEC_OFFSET + 2 + max_k;
> >>    ierr =
> KSPCreateVecs(ksp,gmres->vv_allocated,&gmres->user_work[0],0,NULL);CHKERRQ(ierr);
> >>    ierr =
> PetscLogObjectParents(ksp,gmres->vv_allocated,gmres->user_work[0]);CHKERRQ(ierr);
> >>    gmres->mwork_alloc[0] = gmres->vv_allocated;
> >>    gmres->nwork_alloc    = 1;
> >>    for (k=0; k<gmres->vv_allocated; k++) {
> >>      gmres->vecs[k] = gmres->user_work[0][k];
> >>  } else {
> >>    gmres->vv_allocated = 5;
> >>    ierr =
> KSPCreateVecs(ksp,5,&gmres->user_work[0],0,NULL);CHKERRQ(ierr);
> >>    ierr =
> PetscLogObjectParents(ksp,5,gmres->user_work[0]);CHKERRQ(ierr);
> >>    gmres->mwork_alloc[0] = 5;
> >>  PetscFunctionReturn(0);
> >>    Run gmres, possibly with restart.  Return residual history if
> requested.
> >>    input parameters:
> >> .        gmres  - structure containing parameters and work areas
> >>    output parameters:
> >> .        nres    - residuals (from preconditioned system) at each step.
> >>                  If restarting, consider passing nres+it.  If null,
> >>                  ignored
> >> .        itcount - number of iterations used.  nres[0] to nres[itcount]
> >>                  are defined.  If null, ignored.
> >>    Notes:
> >>    On entry, the value in vector VEC_VV(0) should be the initial
> residual
> >>    (this allows shortcuts where the initial preconditioned residual is
> 0).
> >> PetscErrorCode KSPGMRESCycle(PetscInt *itcount,KSP ksp)
> >>  KSP_GMRES      *gmres = (KSP_GMRES*)(ksp->data);
> >>  PetscReal      res_norm,res,hapbnd,tt;
> >>  PetscInt       it     = 0, max_k = gmres->max_k;
> >>  PetscBool      hapend = PETSC_FALSE;
> >>  PetscFunctionBegin;
> >>  if (itcount) *itcount = 0;
> >>  ierr    = VecNormalize(VEC_VV(0),&res_norm);CHKERRQ(ierr);
> >>  KSPCheckNorm(ksp,res_norm);
> >>  res     = res_norm;
> >>  *GRS(0) = res_norm;
> >>  /* check for the convergence */
> >>  ierr       = PetscObjectSAWsTakeAccess((PetscObject)ksp);CHKERRQ(ierr);
> >>  ksp->rnorm = res;
> >>  ierr       =
> PetscObjectSAWsGrantAccess((PetscObject)ksp);CHKERRQ(ierr);
> >>  gmres->it  = (it - 1);
> >>  ierr = KSPLogResidualHistory(ksp,res);CHKERRQ(ierr);
> >>  ierr = KSPMonitor(ksp,ksp->its,res);CHKERRQ(ierr);
> >>  if (!res) {
> >>    ksp->reason = KSP_CONVERGED_ATOL;
> >>    ierr        = PetscInfo(ksp,"Converged due to zero residual norm on
> entry\n");CHKERRQ(ierr);
> >>  ierr =
> (*ksp->converged)(ksp,ksp->its,res,&ksp->reason,ksp->cnvP);CHKERRQ(ierr);
> >>  while (!ksp->reason && it < max_k && ksp->its < ksp->max_it) {
> >>    if (it) {
> >>    if (gmres->vv_allocated <= it + VEC_OFFSET + 1) {
> >>      ierr = KSPGMRESGetNewVectors(ksp,it+1);CHKERRQ(ierr);
> >>    ierr =
> KSP_PCApplyBAorAB(ksp,VEC_VV(it),VEC_VV(1+it),VEC_TEMP_MATOP);CHKERRQ(ierr);
> >>    /* update hessenberg matrix and do Gram-Schmidt */
> >>    ierr = (*gmres->orthog)(ksp,it);CHKERRQ(ierr);
> >>    if (ksp->reason) break;
> >>    /* vv(i+1) . vv(i+1) */
> >>    ierr = VecNormalize(VEC_VV(it+1),&tt);CHKERRQ(ierr);
> >>    /* save the magnitude */
> >>    *HH(it+1,it)  = tt;
> >>    *HES(it+1,it) = tt;
> >>    /* check for the happy breakdown */
> >>    hapbnd = PetscAbsScalar(tt / *GRS(it));
> >>    if (hapbnd > gmres->haptol) hapbnd = gmres->haptol;
> >>    if (tt < hapbnd) {
> >>      ierr   = PetscInfo2(ksp,"Detected happy breakdown, current hapbnd
> = %14.12e tt = %14.12e\n",(double)hapbnd,(double)tt);CHKERRQ(ierr);
> >>      hapend = PETSC_TRUE;
> >>    ierr = KSPGMRESUpdateHessenberg(ksp,it,hapend,&res);CHKERRQ(ierr);
> >>    it++;
> >>    gmres->it = (it-1);   /* For converged */
> >>    ksp->its++;
> >>    ksp->rnorm = res;
> >>    ierr =
> >>    /* Catch error in happy breakdown and signal convergence and break
> from loop */
> >>    if (hapend) {
> >>      if (!ksp->reason) {
> >>        if (ksp->errorifnotconverged)
> SETERRQ1(PetscObjectComm((PetscObject)ksp),PETSC_ERR_NOT_CONVERGED,"You
> reached the happy break down, but convergence was not indicated. Residual
> norm = %g",(double)res);
> >>        else {
> >>          ksp->reason = KSP_DIVERGED_BREAKDOWN;
> >>          break;
> >>  /* Monitor if we know that we will not return for a restart */
> >>  if (it && (ksp->reason || ksp->its >= ksp->max_it)) {
> >>  if (itcount) *itcount = it;
> >>    Down here we have to solve for the "best" coefficients of the Krylov
> >>    columns, add the solution values together, and possibly unwind the
> >>    preconditioning from the solution
> >>  /* Form the solution (or the solution so far) */
> >>  ierr =
> KSPGMRESBuildSoln(GRS(0),ksp->vec_sol,ksp->vec_sol,ksp,it-1);CHKERRQ(ierr);
> >> PetscErrorCode KSPSolve_GMRES(KSP ksp)
> >>  PetscInt       its,itcount,i;
> >>  PetscBool      guess_zero = ksp->guess_zero;
> >>  PetscInt       N = gmres->max_k + 1;
> >>  PetscBLASInt   bN;
> >>  PetscFunctionBegin;
> >>  if (ksp->calc_sings && !gmres->Rsvd)
> SETERRQ(PetscObjectComm((PetscObject)ksp),PETSC_ERR_ORDER,"Must call
> KSPSetComputeSingularValues() before KSPSetUp() is called");
> >>  ksp->its = 0;
> >>  ierr     = PetscObjectSAWsGrantAccess((PetscObject)ksp);CHKERRQ(ierr);
> >>  itcount     = 0;
> >>  gmres->fullcycle = 0;
> >>  ksp->reason = KSP_CONVERGED_ITERATING;
> >>  while (!ksp->reason) {
> >>    ierr     =
> KSPInitialResidual(ksp,ksp->vec_sol,VEC_TEMP,VEC_TEMP_MATOP,VEC_VV(0),ksp->vec_rhs);CHKERRQ(ierr);
> >>    ierr     = KSPGMRESCycle(&its,ksp);CHKERRQ(ierr);
> >>    /* Store the Hessenberg matrix and the basis vectors of the Krylov
> subspace
> >>    if the cycle is complete for the computation of the Ritz pairs */
> >>    if (its == gmres->max_k) {
> >>      gmres->fullcycle++;
> >>      if (ksp->calc_ritz) {
> >>        if (!gmres->hes_ritz) {
> >>          ierr = PetscMalloc1(N*N,&gmres->hes_ritz);CHKERRQ(ierr);
> >>          ierr =
> PetscLogObjectMemory((PetscObject)ksp,N*N*sizeof(PetscScalar));CHKERRQ(ierr);
> >>          ierr =
> VecDuplicateVecs(VEC_VV(0),N,&gmres->vecb);CHKERRQ(ierr);
> >>        ierr = PetscBLASIntCast(N,&bN);CHKERRQ(ierr);
> >>        ierr =
> PetscMemcpy(gmres->hes_ritz,gmres->hes_origin,bN*bN*sizeof(PetscReal));CHKERRQ(ierr);
> >>        for (i=0; i<gmres->max_k+1; i++) {
> >>          ierr = VecCopy(VEC_VV(i),gmres->vecb[i]);CHKERRQ(ierr);
> >>    itcount += its;
> >>    if (itcount >= ksp->max_it) {
> >>      if (!ksp->reason) ksp->reason = KSP_DIVERGED_ITS;
> >>      break;
> >>    ksp->guess_zero = PETSC_FALSE; /* every future call to
> KSPInitialResidual() will have nonzero guess */
> >>  ksp->guess_zero = guess_zero; /* restore if user provided nonzero
> initial guess */
> >> PetscErrorCode KSPReset_GMRES(KSP ksp)
> >>  PetscInt       i;
> >>  PetscFunctionBegin;
> >>  /* Free the Hessenberg matrices */
> >>  ierr =
> PetscFree6(gmres->hh_origin,gmres->hes_origin,gmres->rs_origin,gmres->cc_origin,gmres->ss_origin,gmres->hes_ritz);CHKERRQ(ierr);
> >>  /* free work vectors */
> >>  ierr = PetscFree(gmres->vecs);CHKERRQ(ierr);
> >>  for (i=0; i<gmres->nwork_alloc; i++) {
> >>    ierr =
> VecDestroyVecs(gmres->mwork_alloc[i],&gmres->user_work[i]);CHKERRQ(ierr);
> >>  gmres->nwork_alloc = 0;
> >>  if (gmres->vecb)  {
> >>    ierr = VecDestroyVecs(gmres->max_k+1,&gmres->vecb);CHKERRQ(ierr);
> >>  ierr = PetscFree(gmres->user_work);CHKERRQ(ierr);
> >>  ierr = PetscFree(gmres->mwork_alloc);CHKERRQ(ierr);
> >>  ierr = PetscFree(gmres->nrs);CHKERRQ(ierr);
> >>  ierr = VecDestroy(&gmres->sol_temp);CHKERRQ(ierr);
> >>  ierr = PetscFree(gmres->Rsvd);CHKERRQ(ierr);
> >>  ierr = PetscFree(gmres->Dsvd);CHKERRQ(ierr);
> >>  ierr = PetscFree(gmres->orthogwork);CHKERRQ(ierr);
> >>  gmres->sol_temp       = 0;
> >>  gmres->vv_allocated   = 0;
> >>  gmres->vecs_allocated = 0;
> >> PetscErrorCode KSPDestroy_GMRES(KSP ksp)
> >>  PetscFunctionBegin;
> >>  ierr = KSPReset_GMRES(ksp);CHKERRQ(ierr);
> >>  ierr = PetscFree(ksp->data);CHKERRQ(ierr);
> >>  /* clear composed functions */
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESSetPreAllocateVectors_C",NULL);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESSetOrthogonalization_C",NULL);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESGetOrthogonalization_C",NULL);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESSetRestart_C",NULL);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESGetRestart_C",NULL);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESSetHapTol_C",NULL);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESSetCGSRefinementType_C",NULL);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESGetCGSRefinementType_C",NULL);CHKERRQ(ierr);
> >>    KSPGMRESBuildSoln - create the solution from the starting vector and
> the
> >>    current iterates.
> >>    Input parameters:
> >>        nrs - work area of size it + 1.
> >>        vs  - index of initial guess
> >>        vdest - index of result.  Note that vs may == vdest (replace
> >>                guess with the solution).
> >>     This is an internal routine that knows about the GMRES internals.
> >> static PetscErrorCode KSPGMRESBuildSoln(PetscScalar *nrs,Vec vs,Vec
> vdest,KSP ksp,PetscInt it)
> >>  PetscScalar    tt;
> >>  PetscInt       ii,k,j;
> >>  PetscFunctionBegin;
> >>  /* Solve for solution vector that minimizes the residual */
> >>  /* If it is < 0, no gmres steps have been performed */
> >>  if (it < 0) {
> >>    ierr = VecCopy(vs,vdest);CHKERRQ(ierr); /* VecCopy() is smart,
> exists immediately if vguess == vdest */
> >>  if (*HH(it,it) != 0.0) {
> >>    nrs[it] = *GRS(it) / *HH(it,it);
> >>  } else {
> >>    ierr = PetscInfo2(ksp,"Likely your matrix or preconditioner is
> singular. HH(it,it) is identically zero; it = %D GRS(it) =
> %g\n",it,(double)PetscAbsScalar(*GRS(it)));CHKERRQ(ierr);
> >>  for (ii=1; ii<=it; ii++) {
> >>    k  = it - ii;
> >>    tt = *GRS(k);
> >>    for (j=k+1; j<=it; j++) tt = tt - *HH(k,j) * nrs[j];
> >>    if (*HH(k,k) == 0.0) {
> >>      ierr = PetscInfo1(ksp,"Likely your matrix or preconditioner is
> singular. HH(k,k) is identically zero; k = %D\n",k);CHKERRQ(ierr);
> >>    nrs[k] = tt / *HH(k,k);
> >>  /* Perform the hookstep correction - DRL */
> >>  if(gmres->delta > 0.0 && gmres->it > 0) { // Apply the hookstep to
> correct the GMRES solution (if required)
> >>    printf("\t\tapplying hookstep: initial delta: %lf", gmres->delta);
> >>    PetscInt N = gmres->max_k+2, ii, jj, j0;
> >>    PetscBLASInt nRows, nCols, lwork, lierr;
> >>    PetscScalar *R, *work;
> >>    PetscReal* S;
> >>    PetscScalar *U, *VT, *p, *q, *y;
> >>    PetscScalar bnorm, mu, qMag, qMag2, delta2;
> >>    ierr = PetscMalloc1((gmres->max_k + 3)*(gmres->max_k +
> 9),&R);CHKERRQ(ierr);
> >>    work = R + N*N;
> >>    ierr = PetscMalloc1(6*(gmres->max_k+2),&S);CHKERRQ(ierr);
> >>    ierr = PetscBLASIntCast(gmres->it+1,&nRows);CHKERRQ(ierr);
> >>    ierr = PetscBLASIntCast(gmres->it+0,&nCols);CHKERRQ(ierr);
> >>    ierr = PetscBLASIntCast(5*N,&lwork);CHKERRQ(ierr);
> >>    //ierr =
> PetscMemcpy(R,gmres->hes_origin,(gmres->max_k+2)*(gmres->max_k+1)*sizeof(PetscScalar));CHKERRQ(ierr);
> >>    ierr = PetscMalloc1(nRows*nCols,&R);CHKERRQ(ierr);
> >>    for (ii = 0; ii < nRows; ii++) {
> >>      for (jj = 0; jj < nCols; jj++) {
> >>        R[ii*nCols+jj] = *HH(ii,jj);
> >>        // Ensure Hessenberg structure
> >>        //if (ii > jj+1) R[ii*nCols+jj] = 0.0;
> >>    ierr = PetscMalloc1(nRows*nRows,&U);CHKERRQ(ierr);
> >>    ierr = PetscMalloc1(nCols*nCols,&VT);CHKERRQ(ierr);
> >>    ierr = PetscMalloc1(nRows,&p);CHKERRQ(ierr);
> >>    ierr = PetscMalloc1(nCols,&q);CHKERRQ(ierr);
> >>    ierr = PetscMalloc1(nRows,&y);CHKERRQ(ierr);
> printf("\n\n");for(ii=0;ii<nRows;ii++){for(jj=0;jj<nCols;jj++){printf("\t%g",R[ii*nCols+jj]);}printf("\n");}printf("\n");
> >>    // Perform an SVD on the Hessenberg matrix
> >>    ierr = PetscFPTrapPush(PETSC_FP_TRAP_OFF);CHKERRQ(ierr);
> PetscStackCallBLAS("LAPACKgesvd",LAPACKgesvd_("A","A",&nRows,&nCols,R,&nRows,S,U,&nRows,VT,&nCols,work,&lwork,&lierr));
> >>    if (lierr) SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"Error in SVD
> Lapack routine %d",(int)lierr);
> >>    ierr = PetscFPTrapPop();CHKERRQ(ierr);
> >>    // Compute p = ||b|| U^T e_1
> >>    ierr = VecNorm(ksp->vec_rhs,NORM_2,&bnorm);CHKERRQ(ierr);
> >>    for (ii=0; ii<nRows; ii++) {
> >>      p[ii] = bnorm*U[ii*nRows];
> >>    // Solve the root finding problem for \mu such that ||q|| < \delta
> (where \delta is the radius of the trust region)
> >>    // This step is largely copied from Ashley Willis' openpipeflow:
> doi.org/10.1016/j.softx.2017.05.003
> >>    mu = S[nCols-1]*S[nCols-1]*1.0e-6;
> >>    if (mu < 1.0e-99) mu = 1.0e-99;
> >>    qMag = 1.0e+99;
> >>    while (qMag > gmres->delta) {
> >>      mu *= 1.1;
> >>      qMag2 = 0.0;
> >>      for (ii=0; ii<nCols; ii++) {
> >>        q[ii] = p[ii]*S[ii]/(mu + S[ii]*S[ii]);
> >>        qMag2 += q[ii]*q[ii];
> >>      qMag = PetscSqrtScalar(qMag2);
> >>    // Expand y in terms of the right singular vectors as y = V q
> >>      y[ii] = 0.0;
> >>      for (jj=0; jj<nCols; jj++) {
> >>          y[ii] += VT[jj*nCols+ii]*q[jj]; // transpose of the transpose
> >>    // Recompute the size of the trust region, \delta
> >>    delta2 = 0.0;
> >>      j0 = (ii < 2) ? 0 : ii - 1;
> >>      p[ii] = 0.0;
> >>      for (jj=j0; jj<nCols; jj++) {
> >>        p[ii] -= R[ii*nCols+jj]*y[jj];
> >>      if (ii == 0) {
> >>        p[ii] += bnorm;
> >>      delta2 += p[ii]*p[ii];
> >>    gmres->delta = PetscSqrtScalar(delta2);
> >>    printf("\t\t...final delta: %lf.\n", gmres->delta);
> >>    // Pass the orthnomalized Krylov vector weights back out
> >>      nrs[ii] = y[ii];
> >>    ierr = PetscFree(R);CHKERRQ(ierr);
> >>    ierr = PetscFree(S);CHKERRQ(ierr);
> >>    ierr = PetscFree(U);CHKERRQ(ierr);
> >>    ierr = PetscFree(VT);CHKERRQ(ierr);
> >>    ierr = PetscFree(p);CHKERRQ(ierr);
> >>    ierr = PetscFree(q);CHKERRQ(ierr);
> >>    ierr = PetscFree(y);CHKERRQ(ierr);
> >>  /*** DRL ***/
> >>  /* Accumulate the correction to the solution of the preconditioned
> problem in TEMP */
> >>  ierr = VecSet(VEC_TEMP,0.0);CHKERRQ(ierr);
> >>  if (gmres->delta > 0.0) {
> >>    ierr = VecMAXPY(VEC_TEMP,it,nrs,&VEC_VV(0));CHKERRQ(ierr); // DRL
> >>  } else {
> >>  ierr = VecMAXPY(VEC_TEMP,it+1,nrs,&VEC_VV(0));CHKERRQ(ierr);
> >>  ierr =
> KSPUnwindPreconditioner(ksp,VEC_TEMP,VEC_TEMP_MATOP);CHKERRQ(ierr);
> >>  /* add solution to previous solution */
> >>  if (vdest != vs) {
> >>  ierr = VecAXPY(vdest,1.0,VEC_TEMP);CHKERRQ(ierr);
> >>   Do the scalar work for the orthogonalization.  Return new residual
> norm.
> >> static PetscErrorCode KSPGMRESUpdateHessenberg(KSP ksp,PetscInt
> it,PetscBool hapend,PetscReal *res)
> >>  PetscScalar *hh,*cc,*ss,tt;
> >>  PetscInt    j;
> >>  PetscFunctionBegin;
> >>  hh = HH(0,it);
> >>  cc = CC(0);
> >>  ss = SS(0);
> >>  /* Apply all the previously computed plane rotations to the new column
> >>     of the Hessenberg matrix */
> >>  for (j=1; j<=it; j++) {
> >>    tt  = *hh;
> >>    *hh = PetscConj(*cc) * tt + *ss * *(hh+1);
> >>    hh++;
> >>    *hh = *cc++ * *hh - (*ss++ * tt);
> >>    compute the new plane rotation, and apply it to:
> >>     1) the right-hand-side of the Hessenberg system
> >>     2) the new column of the Hessenberg matrix
> >>    thus obtaining the updated value of the residual
> >>  if (!hapend) {
> >>    tt = PetscSqrtScalar(PetscConj(*hh) * *hh + PetscConj(*(hh+1)) *
> *(hh+1));
> >>    if (tt == 0.0) {
> >>      ksp->reason = KSP_DIVERGED_NULL;
> >>    *cc        = *hh / tt;
> >>    *ss        = *(hh+1) / tt;
> >>    *GRS(it+1) = -(*ss * *GRS(it));
> >>    *GRS(it)   = PetscConj(*cc) * *GRS(it);
> >>    *hh        = PetscConj(*cc) * *hh + *ss * *(hh+1);
> >>    *res       = PetscAbsScalar(*GRS(it+1));
> >>  } else {
> >>    /* happy breakdown: HH(it+1, it) = 0, therfore we don't need to apply
> >>            another rotation matrix (so RH doesn't change).  The new
> residual is
> >>            always the new sine term times the residual from last time
> (GRS(it)),
> >>            but now the new sine rotation would be zero...so the
> residual should
> >>            be zero...so we will multiply "zero" by the last residual.
> This might
> >>            not be exactly what we want to do here -could just return
> "zero". */
> >>    *res = 0.0;
> >>   This routine allocates more work vectors, starting from VEC_VV(it).
> >> PetscErrorCode KSPGMRESGetNewVectors(KSP ksp,PetscInt it)
> >>  PetscInt       nwork = gmres->nwork_alloc,k,nalloc;
> >>  PetscFunctionBegin;
> >>  nalloc = PetscMin(ksp->max_it,gmres->delta_allocate);
> >>  /* Adjust the number to allocate to make sure that we don't exceed the
> >>    number of available slots */
> >>  if (it + VEC_OFFSET + nalloc >= gmres->vecs_allocated) {
> >>    nalloc = gmres->vecs_allocated - it - VEC_OFFSET;
> >>  if (!nalloc) PetscFunctionReturn(0);
> >>  gmres->vv_allocated += nalloc;
> >>  ierr =
> KSPCreateVecs(ksp,nalloc,&gmres->user_work[nwork],0,NULL);CHKERRQ(ierr);
> >>  ierr =
> PetscLogObjectParents(ksp,nalloc,gmres->user_work[nwork]);CHKERRQ(ierr);
> >>  gmres->mwork_alloc[nwork] = nalloc;
> >>  for (k=0; k<nalloc; k++) {
> >>    gmres->vecs[it+VEC_OFFSET+k] = gmres->user_work[nwork][k];
> >>  gmres->nwork_alloc++;
> >> PetscErrorCode KSPBuildSolution_GMRES(KSP ksp,Vec ptr,Vec *result)
> >>  PetscFunctionBegin;
> >>  if (!ptr) {
> >>    if (!gmres->sol_temp) {
> >>      ierr = VecDuplicate(ksp->vec_sol,&gmres->sol_temp);CHKERRQ(ierr);
> >>      ierr =
> PetscLogObjectParent((PetscObject)ksp,(PetscObject)gmres->sol_temp);CHKERRQ(ierr);
> >>    ptr = gmres->sol_temp;
> >>  if (!gmres->nrs) {
> >>    /* allocate the work area */
> >>    ierr = PetscMalloc1(gmres->max_k,&gmres->nrs);CHKERRQ(ierr);
> >>    ierr =
> PetscLogObjectMemory((PetscObject)ksp,gmres->max_k*sizeof(PetscScalar));CHKERRQ(ierr);
> >>  ierr =
> KSPGMRESBuildSoln(gmres->nrs,ksp->vec_sol,ptr,ksp,gmres->it);CHKERRQ(ierr);
> >>  if (result) *result = ptr;
> >> PetscErrorCode KSPView_GMRES(KSP ksp,PetscViewer viewer)
> >>  const char     *cstr;
> >>  PetscBool      iascii,isstring;
> >>  PetscFunctionBegin;
> >>  ierr =
> PetscObjectTypeCompare((PetscObject)viewer,PETSCVIEWERASCII,&iascii);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectTypeCompare((PetscObject)viewer,PETSCVIEWERSTRING,&isstring);CHKERRQ(ierr);
> >>  if (gmres->orthog == KSPGMRESClassicalGramSchmidtOrthogonalization) {
> >>    switch (gmres->cgstype) {
> >>    case (KSP_GMRES_CGS_REFINE_NEVER):
> >>      cstr = "Classical (unmodified) Gram-Schmidt Orthogonalization with
> no iterative refinement";
> >>      break;
> >>    case (KSP_GMRES_CGS_REFINE_ALWAYS):
> one step of iterative refinement";
> >>      break;
> >>    case (KSP_GMRES_CGS_REFINE_IFNEEDED):
> one step of iterative refinement when needed";
> >>      break;
> >>    default:
> SETERRQ(PetscObjectComm((PetscObject)ksp),PETSC_ERR_ARG_OUTOFRANGE,"Unknown
> orthogonalization");
> >>  } else if (gmres->orthog ==
> KSPGMRESModifiedGramSchmidtOrthogonalization) {
> >>    cstr = "Modified Gram-Schmidt Orthogonalization";
> >>  } else {
> >>    cstr = "unknown orthogonalization";
> >>  if (iascii) {
> >>    ierr = PetscViewerASCIIPrintf(viewer,"  restart=%D, using
> %s\n",gmres->max_k,cstr);CHKERRQ(ierr);
> >>    ierr = PetscViewerASCIIPrintf(viewer,"  happy breakdown tolerance
> %g\n",(double)gmres->haptol);CHKERRQ(ierr);
> >>  } else if (isstring) {
> >>    ierr = PetscViewerStringSPrintf(viewer,"%s restart
> %D",cstr,gmres->max_k);CHKERRQ(ierr);
> >> /*@C
> >>   KSPGMRESMonitorKrylov - Calls VecView() for each new direction in the
> GMRES accumulated Krylov space.
> >>   Collective on KSP
> >>   Input Parameters:
> >> +  ksp - the KSP context
> >> .  its - iteration number
> >> .  fgnorm - 2-norm of residual (or gradient)
> >> -  dummy - an collection of viewers created with KSPViewerCreate()
> >>   Options Database Keys:
> >> .   -ksp_gmres_kyrlov_monitor
> >>   Notes: A new PETSCVIEWERDRAW is created for each Krylov vector so
> they can all be simultaneously viewed
> >>   Level: intermediate
> >> .keywords: KSP, nonlinear, vector, monitor, view, Krylov space
> >> .seealso: KSPMonitorSet(), KSPMonitorDefault(), VecView(),
> KSPViewersCreate(), KSPViewersDestroy()
> >> PetscErrorCode  KSPGMRESMonitorKrylov(KSP ksp,PetscInt its,PetscReal
> fgnorm,void *dummy)
> >>  PetscViewers   viewers = (PetscViewers)dummy;
> >>  Vec            x;
> >>  PetscViewer    viewer;
> >>  PetscBool      flg;
> >>  PetscFunctionBegin;
> >>  ierr =
> PetscViewersGetViewer(viewers,gmres->it+1,&viewer);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectTypeCompare((PetscObject)viewer,PETSCVIEWERDRAW,&flg);CHKERRQ(ierr);
> >>  if (!flg) {
> >>    ierr = PetscViewerSetType(viewer,PETSCVIEWERDRAW);CHKERRQ(ierr);
> >>    ierr = PetscViewerDrawSetInfo(viewer,NULL,"Krylov GMRES
> Monitor",PETSC_DECIDE,PETSC_DECIDE,300,300);CHKERRQ(ierr);
> >>  x    = VEC_VV(gmres->it+1);
> >>  ierr = VecView(x,viewer);CHKERRQ(ierr);
> >> PetscErrorCode KSPSetFromOptions_GMRES(PetscOptionItems
> *PetscOptionsObject,KSP ksp)
> >>  PetscInt       restart;
> >>  PetscReal      haptol;
> >>  PetscBool      flg;
> >>  PetscFunctionBegin;
> >>  ierr = PetscOptionsHead(PetscOptionsObject,"KSP GMRES
> Options");CHKERRQ(ierr);
> >>  ierr = PetscOptionsInt("-ksp_gmres_restart","Number of Krylov search
> directions","KSPGMRESSetRestart",gmres->max_k,&restart,&flg);CHKERRQ(ierr);
> >>  if (flg) { ierr = KSPGMRESSetRestart(ksp,restart);CHKERRQ(ierr); }
> >>  ierr = PetscOptionsReal("-ksp_gmres_haptol","Tolerance for exact
> convergence (happy
> ending)","KSPGMRESSetHapTol",gmres->haptol,&haptol,&flg);CHKERRQ(ierr);
> >>  if (flg) { ierr = KSPGMRESSetHapTol(ksp,haptol);CHKERRQ(ierr); }
> >>  flg  = PETSC_FALSE;
> >>  ierr = PetscOptionsBool("-ksp_gmres_preallocate","Preallocate Krylov
> vectors","KSPGMRESSetPreAllocateVectors",flg,&flg,NULL);CHKERRQ(ierr);
> >>  if (flg) {ierr = KSPGMRESSetPreAllocateVectors(ksp);CHKERRQ(ierr);}
> >>  ierr =
> PetscOptionsBoolGroupBegin("-ksp_gmres_classicalgramschmidt","Classical
> (fast)","KSPGMRESSetOrthogonalization",&flg);CHKERRQ(ierr);
> >>  if (flg) {ierr =
> KSPGMRESSetOrthogonalization(ksp,KSPGMRESClassicalGramSchmidtOrthogonalization);CHKERRQ(ierr);}
> >>  ierr =
> PetscOptionsBoolGroupEnd("-ksp_gmres_modifiedgramschmidt","Modified
> Gram-Schmidt (slow,more
> stable)","KSPGMRESSetOrthogonalization",&flg);CHKERRQ(ierr);
> >>  if (flg) {ierr =
> KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization);CHKERRQ(ierr);}
> >>  ierr = PetscOptionsEnum("-ksp_gmres_cgs_refinement_type","Type of
> iterative refinement for classical (unmodified)
> Gram-Schmidt","KSPGMRESSetCGSRefinementType",
> KSPGMRESCGSRefinementTypes,(PetscEnum)gmres->cgstype,(PetscEnum*)&gmres->cgstype,&flg);CHKERRQ(ierr);
> >>  flg  = PETSC_FALSE;
> >>  ierr = PetscOptionsBool("-ksp_gmres_krylov_monitor","Plot the Krylov
> directions","KSPMonitorSet",flg,&flg,NULL);CHKERRQ(ierr);
> >>  if (flg) {
> >>    PetscViewers viewers;
> >>    ierr =
> PetscViewersCreate(PetscObjectComm((PetscObject)ksp),&viewers);CHKERRQ(ierr);
> >>    ierr =
> KSPMonitorSet(ksp,KSPGMRESMonitorKrylov,viewers,(PetscErrorCode
> (*)(void**))PetscViewersDestroy);CHKERRQ(ierr);
> >>  ierr = PetscOptionsTail();CHKERRQ(ierr);
> >> PetscErrorCode  KSPGMRESSetHapTol_GMRES(KSP ksp,PetscReal tol)
> >>  PetscFunctionBegin;
> >>  if (tol < 0.0)
> SETERRQ(PetscObjectComm((PetscObject)ksp),PETSC_ERR_ARG_OUTOFRANGE,"Tolerance
> must be non-negative");
> >>  gmres->haptol = tol;
> >> PetscErrorCode  KSPGMRESGetRestart_GMRES(KSP ksp,PetscInt *max_k)
> >>  PetscFunctionBegin;
> >>  *max_k = gmres->max_k;
> >> PetscErrorCode  KSPGMRESSetRestart_GMRES(KSP ksp,PetscInt max_k)
> >>  PetscFunctionBegin;
> >>  if (max_k < 1)
> SETERRQ(PetscObjectComm((PetscObject)ksp),PETSC_ERR_ARG_OUTOFRANGE,"Restart
> must be positive");
> >>  if (!ksp->setupstage) {
> >>    gmres->max_k = max_k;
> >>  } else if (gmres->max_k != max_k) {
> >>    ksp->setupstage = KSP_SETUP_NEW;
> >>    /* free the data structures, then create them again */
> >> PetscErrorCode  KSPGMRESSetOrthogonalization_GMRES(KSP ksp,FCN fcn)
> >>  PetscFunctionBegin;
> >>  ((KSP_GMRES*)ksp->data)->orthog = fcn;
> >> PetscErrorCode  KSPGMRESGetOrthogonalization_GMRES(KSP ksp,FCN *fcn)
> >>  PetscFunctionBegin;
> >>  *fcn = ((KSP_GMRES*)ksp->data)->orthog;
> >> PetscErrorCode  KSPGMRESSetPreAllocateVectors_GMRES(KSP ksp)
> >>  KSP_GMRES *gmres;
> >>  PetscFunctionBegin;
> >>  gmres->q_preallocate = 1;
> >> PetscErrorCode  KSPGMRESSetCGSRefinementType_GMRES(KSP
> ksp,KSPGMRESCGSRefinementType type)
> >>  PetscFunctionBegin;
> >>  gmres->cgstype = type;
> >> PetscErrorCode  KSPGMRESGetCGSRefinementType_GMRES(KSP
> ksp,KSPGMRESCGSRefinementType *type)
> >>  PetscFunctionBegin;
> >>  *type = gmres->cgstype;
> >>   KSPGMRESSetCGSRefinementType - Sets the type of iterative refinement
> to use
> >>         in the classical Gram Schmidt orthogonalization.
> >>   Logically Collective on KSP
> >>   Input Parameters:
> >> +  ksp - the Krylov space context
> >> -  type - the type of refinement
> >>  Options Database:
> >> .  -ksp_gmres_cgs_refinement_type
> <refine_never,refine_ifneeded,refine_always>
> >>   Level: intermediate
> >> .keywords: KSP, GMRES, iterative refinement
> >> .seealso: KSPGMRESSetOrthogonalization(), KSPGMRESCGSRefinementType,
> KSPGMRESClassicalGramSchmidtOrthogonalization(),
> KSPGMRESGetCGSRefinementType(),
> >>          KSPGMRESGetOrthogonalization()
> >> PetscErrorCode  KSPGMRESSetCGSRefinementType(KSP
> >>  PetscFunctionBegin;
> >>  PetscValidHeaderSpecific(ksp,KSP_CLASSID,1);
> >>  PetscValidLogicalCollectiveEnum(ksp,type,2);
> >>  ierr =
> PetscTryMethod(ksp,"KSPGMRESSetCGSRefinementType_C",(KSP,KSPGMRESCGSRefinementType),(ksp,type));CHKERRQ(ierr);
> >>   KSPGMRESGetCGSRefinementType - Gets the type of iterative refinement
> to use
> >>   Not Collective
> >>   Input Parameter:
> >> .  ksp - the Krylov space context
> >>   Output Parameter:
> >> .  type - the type of refinement
> >>  Options Database:
> >> .  -ksp_gmres_cgs_refinement_type <never,ifneeded,always>
> >>   Level: intermediate
> KSPGMRESSetCGSRefinementType(),
> >> PetscErrorCode  KSPGMRESGetCGSRefinementType(KSP
> >>  PetscFunctionBegin;
> >>  ierr =
> PetscUseMethod(ksp,"KSPGMRESGetCGSRefinementType_C",(KSP,KSPGMRESCGSRefinementType*),(ksp,type));CHKERRQ(ierr);
> >>   KSPGMRESSetRestart - Sets number of iterations at which GMRES, FGMRES
> and LGMRES restarts.
> >>   Input Parameters:
> >> -  restart - integer restart value
> >>  Options Database:
> >> .  -ksp_gmres_restart <positive integer>
> >>    Note: The default value is 30.
> >>   Level: intermediate
> >> .keywords: KSP, GMRES, restart, iterations
> >> .seealso: KSPSetTolerances(), KSPGMRESSetOrthogonalization(),
> KSPGMRESSetPreAllocateVectors(), KSPGMRESGetRestart()
> >> PetscErrorCode  KSPGMRESSetRestart(KSP ksp, PetscInt restart)
> >>  PetscFunctionBegin;
> >>  PetscValidLogicalCollectiveInt(ksp,restart,2);
> >>  ierr =
> PetscTryMethod(ksp,"KSPGMRESSetRestart_C",(KSP,PetscInt),(ksp,restart));CHKERRQ(ierr);
> >>   KSPGMRESGetRestart - Gets number of iterations at which GMRES, FGMRES
> >>   Not Collective
> >>   Input Parameter:
> >>   Output Parameter:
> >> .   restart - integer restart value
> >>   Level: intermediate
> KSPGMRESSetPreAllocateVectors(), KSPGMRESSetRestart()
> >> PetscErrorCode  KSPGMRESGetRestart(KSP ksp, PetscInt *restart)
> >>  PetscFunctionBegin;
> >>  ierr =
> PetscUseMethod(ksp,"KSPGMRESGetRestart_C",(KSP,PetscInt*),(ksp,restart));CHKERRQ(ierr);
> >>   KSPGMRESSetHapTol - Sets tolerance for determining happy breakdown in
> GMRES, FGMRES and LGMRES.
> >>   Input Parameters:
> >> -  tol - the tolerance
> >>  Options Database:
> >> .  -ksp_gmres_haptol <positive real value>
> >>   Note: Happy breakdown is the rare case in GMRES where an 'exact'
> solution is obtained after
> >>         a certain number of iterations. If you attempt more iterations
> after this point unstable
> >>         things can happen hence very occasionally you may need to set
> this value to detect this condition
> >>   Level: intermediate
> >> .keywords: KSP, GMRES, tolerance
> >> PetscErrorCode  KSPGMRESSetHapTol(KSP ksp,PetscReal tol)
> >>  PetscFunctionBegin;
> >>  PetscValidLogicalCollectiveReal(ksp,tol,2);
> >>  ierr =
> PetscTryMethod((ksp),"KSPGMRESSetHapTol_C",(KSP,PetscReal),((ksp),(tol)));CHKERRQ(ierr);
> >> /*MC
> >>     KSPGMRES - Implements the Generalized Minimal Residual method.
> >>                (Saad and Schultz, 1986) with restart
> >> +   -ksp_gmres_restart <restart> - the number of Krylov directions to
> orthogonalize against
> >> .   -ksp_gmres_haptol <tol> - sets the tolerance for "happy ending"
> (exact convergence)
> >> .   -ksp_gmres_preallocate - preallocate all the Krylov search
> directions initially (otherwise groups of
> >>                             vectors are allocated as needed)
> >> .   -ksp_gmres_classicalgramschmidt - use classical (unmodified)
> Gram-Schmidt to orthogonalize against the Krylov space (fast) (the default)
> >> .   -ksp_gmres_modifiedgramschmidt - use modified Gram-Schmidt in the
> orthogonalization (more stable, but slower)
> >> .   -ksp_gmres_cgs_refinement_type <never,ifneeded,always> - determine
> if iterative refinement is used to increase the
> >>                                   stability of the classical
> Gram-Schmidt  orthogonalization.
> >> -   -ksp_gmres_krylov_monitor - plot the Krylov space generated
> >>   Level: beginner
> >>   Notes: Left and right preconditioning are supported, but not
> symmetric preconditioning.
> >>   References:
> >> .     1. - YOUCEF SAAD AND MARTIN H. SCHULTZ, GMRES: A GENERALIZED
> MINIMAL RESIDUAL ALGORITHM FOR SOLVING NONSYMMETRIC LINEAR SYSTEMS.
> >>          SIAM J. ScI. STAT. COMPUT. Vo|. 7, No. 3, July 1986.
> >> .seealso:  KSPCreate(), KSPSetType(), KSPType (for list of available
> types), KSP, KSPFGMRES, KSPLGMRES,
> >>           KSPGMRESSetRestart(), KSPGMRESSetHapTol(),
> KSPGMRESSetPreAllocateVectors(), KSPGMRESSetOrthogonalization(),
> KSPGMRESGetOrthogonalization(),
> KSPGMRESModifiedGramSchmidtOrthogonalization(),
> >>           KSPGMRESCGSRefinementType, KSPGMRESSetCGSRefinementType(),
> KSPGMRESGetCGSRefinementType(), KSPGMRESMonitorKrylov(), KSPSetPCSide()
> >> M*/
> >> PETSC_EXTERN PetscErrorCode KSPCreate_GMRES(KSP ksp)
> >>  KSP_GMRES      *gmres;
> >>  PetscFunctionBegin;
> >>  ierr      = PetscNewLog(ksp,&gmres);CHKERRQ(ierr);
> >>  ksp->data = (void*)gmres;
> >>  ierr =
> KSPSetSupportedNorm(ksp,KSP_NORM_PRECONDITIONED,PC_LEFT,4);CHKERRQ(ierr);
> >>  ierr =
> KSPSetSupportedNorm(ksp,KSP_NORM_UNPRECONDITIONED,PC_RIGHT,3);CHKERRQ(ierr);
> >>  ierr =
> KSPSetSupportedNorm(ksp,KSP_NORM_PRECONDITIONED,PC_SYMMETRIC,2);CHKERRQ(ierr);
> >>  ierr = KSPSetSupportedNorm(ksp,KSP_NORM_NONE,PC_RIGHT,1);CHKERRQ(ierr);
> >>  ierr = KSPSetSupportedNorm(ksp,KSP_NORM_NONE,PC_LEFT,1);CHKERRQ(ierr);
> >>  ksp->ops->buildsolution                = KSPBuildSolution_GMRES;
> >>  ksp->ops->setup                        = KSPSetUp_GMRES;
> >>  ksp->ops->solve                        = KSPSolve_GMRES;
> >>  ksp->ops->reset                        = KSPReset_GMRES;
> >>  ksp->ops->destroy                      = KSPDestroy_GMRES;
> >>  ksp->ops->view                         = KSPView_GMRES;
> >>  ksp->ops->setfromoptions               = KSPSetFromOptions_GMRES;
> >>  ksp->ops->computeextremesingularvalues =
> KSPComputeExtremeSingularValues_GMRES;
> >>  ksp->ops->computeeigenvalues           = KSPComputeEigenvalues_GMRES;
> >> #if !defined(PETSC_USE_COMPLEX) && !defined(PETSC_HAVE_ESSL)
> >>  ksp->ops->computeritz                  = KSPComputeRitz_GMRES;
> >> #endif
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESSetPreAllocateVectors_C",KSPGMRESSetPreAllocateVectors_GMRES);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESSetOrthogonalization_C",KSPGMRESSetOrthogonalization_GMRES);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESGetOrthogonalization_C",KSPGMRESGetOrthogonalization_GMRES);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESSetRestart_C",KSPGMRESSetRestart_GMRES);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESGetRestart_C",KSPGMRESGetRestart_GMRES);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESSetHapTol_C",KSPGMRESSetHapTol_GMRES);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESSetCGSRefinementType_C",KSPGMRESSetCGSRefinementType_GMRES);CHKERRQ(ierr);
> >>  ierr =
> PetscObjectComposeFunction((PetscObject)ksp,"KSPGMRESGetCGSRefinementType_C",KSPGMRESGetCGSRefinementType_GMRES);CHKERRQ(ierr);
> >>  gmres->haptol         = 1.0e-30;
> >>  gmres->q_preallocate  = 0;
> >>  gmres->delta_allocate = GMRES_DELTA_DIRECTIONS;
> >>  gmres->orthog         = KSPGMRESClassicalGramSchmidtOrthogonalization;
> >>  gmres->nrs            = 0;
> >>  gmres->max_k          = GMRES_DEFAULT_MAXK;
> >>  gmres->Rsvd           = 0;
> >>  gmres->cgstype        = KSP_GMRES_CGS_REFINE_NEVER;
> >>  gmres->orthogwork     = 0;
> >>  gmres->delta          = -1.0; // DRL
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190520/2f579de4/attachment-0001.html>
