[petsc-users] MatCreateBAIJ, SNES, Preallocation...
William Coirier William.Coirier at kratosdefense.com
Thu May 16 15:44:47 CDT 2019
Folks:
I'm developing an application using the SNES, and overall it's working great, as many of our other PETSc-based projects. But, I'm having a problem related to (presumably) pre-allocation, block matrices and SNES.
Without going into details about the actual problem we are solving, here are the symptoms/characteristics/behavior.
  *   For the SNES Jacobian, I'm using MatCreateBAIJ for a block size=3, and letting "PETSC_DECIDE" the partitioning. Actual call is:
     *   ierr = MatCreateBAIJ(PETSC_COMM_WORLD, bs, PETSC_DECIDE, PETSC_DECIDE, (int)3 * numNodesSAM, (int)3 * numNodesSAM, PETSC_DEFAULT, NULL, PETSC_DEFAULT, NULL, &J);
  *   When registering the SNES jacobian function, I set the B and J matrices to be the same.
     *       ierr = SNESSetJacobian(snes, J, J, SAMformSNESJ, (void *)this); CHKERRQ(ierr);
  *   I can either let PETSc figure out the allocation structure:
     *   ierr = MatMPIBAIJSetPreallocation(J, bs, PETSC_DEFAULT, NULL,PETSC_DEFAULT, NULL);
  *    or, do it myself, since I know the fill pattern,
     *   ierr = MatMPIBAIJSetPreallocation(J, bs, d_nz_dum,&d_nnz[0],o_nz_dum,&o_nnz[0]);
The symptoms/problems are as follows:
  *   Whether I do preallocation or not, the "setup" time is pretty long. It might take 2 minutes before SNES starts doing its thing. After this setup, convergence and speed is great. But this first phase takes a long time. I'm assuming this has to be related to some poor preallocation setup so it's doing tons of mallocs where it's not needed.
  *   If I don't call my Jacobian formulation before calling SNESSolve, I get a segmentation violation in a PETSc routine.  (If I DO call my Jacobian first, things work great, although slow for the setup phase.) Here's a snippet of the traceback:
0  0x00000000009649fc in MatMultAdd_SeqBAIJ_3 (A=<optimized out>,
    xx=0x3a525b0, yy=0x3a531b0, zz=0x3a531b0)
    at /home/jstutts/Downloads/petsc-3.11.1/src/mat/impls/baij/seq/baij2.c:1424
#1  0x00000000006444cb in MatMult_MPIBAIJ (A=0x15da340, xx=0x3a542a0,
    yy=0x3a531b0)
    at /home/jstutts/Downloads/petsc-3.11.1/src/mat/impls/baij/mpi/mpibaij.c:1380
#2  0x00000000005b2c0f in MatMult (mat=0x15da340, x=x at entry=0x3a542a0,
    y=y at entry=0x3a531b0)
    at /home/jstutts/Downloads/petsc-3.11.1/src/mat/interface/matrix.c:2396
#3  0x0000000000c61f2e in PCApplyBAorAB (pc=0x1ce78c0, side=PC_LEFT,
    x=0x3a542a0, y=y at entry=0x3a548a0, work=0x3a531b0)
    at /home/jstutts/Downloads/petsc-3.11.1/src/ksp/pc/interface/precon.c:690
#4  0x0000000000ccb36b in KSP_PCApplyBAorAB (w=<optimized out>, y=0x3a548a0,
    x=<optimized out>, ksp=0x1d44d50)
    at /home/jstutts/Downloads/petsc-3.11.1/include/petsc/private/kspimpl.h:309
#5  KSPGMRESCycle (itcount=itcount at entry=0x7fffffffc02c,
    ksp=ksp at entry=0x1d44d50)
    at /home/jstutts/Downloads/petsc-3.11.1/src/ksp/ksp/impls/gmres/gmres.c:152
#6  0x0000000000ccbf6f in KSPSolve_GMRES (ksp=0x1d44d50)
    at /home/jstutts/Downloads/petsc-3.11.1/src/ksp/ksp/impls/gmres/gmres.c:237
#7  0x00000000007dc193 in KSPSolve (ksp=0x1d44d50, b=b at entry=0x1d41c70,
    x=x at entry=0x1cebf40)
I apologize if I've missed something in the documentation or examples, but I can't seem to figure this one out. The "setup" seems to take too long, and from my previous experiences with PETSc, this is due to a poor preallocation strategy.
Any and all help is appreciated!
William J. Coirier, Ph.D.
Director, Aerosciences and Engineering Analysis Branch
Advanced Concepts Development and Test Division
Kratos Defense and Rocket Support Services
4904 Research Drive
Huntsville, AL 35805
256-327-8170
256-327-8120 (fax)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190516/862a1346/attachment.html>
