[petsc-users] Question about parallel Vectors and communicators
Mon May 13 10:21:54 CDT 2019
On Mon, May 13, 2019 at 10:07 AM GIRET Jean-Christophe via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> Thank you all for you answers and examples, it’s now very clear: the trick
> is to alias a Vec on a subcomm with a Vec on the parent comm, and to make
> the comm through Scatter on the parent comm. I have also been able to
> implement it with petsc4py.
> Junchao, thank you for your example. It is indeed very clear. Although I
> understand how the exchanges are made through the Vecs defined on the
> parent comms, I am wondering why *ISCreateStride* is defined on the
> communicator PETSC_COMM_SELF and not on the parent communicator spanning
> the Vecs used for the Scatter operations.
> When I read the documentation, I see*: “The communicator, comm, should
> consist of all processes that will be using the IS.”* I would say in that
> case that it is the same communicator used for the ‘exchange’ vectors.
> I am surely misunderstanding something here, but I didn’t find any answer
> while googling. Any hint on that?
It would work the same if you gave COMM_WORLD, however its unnecessary.
As Junchao says, IS is only used locally. If, however, you wanted to
concatenate a bunch of indices from different processes,
you would need to set it to COMM_WORLD.
     Matt
> Again, thank you all for your great support,
> Best,
> JC
> *De :* Zhang, Junchao [mailto:jczhang at mcs.anl.gov]
> *Envoyé :* vendredi 10 mai 2019 22:01
> *À :* GIRET Jean-Christophe
> *Cc :* Mark Adams; petsc-users at mcs.anl.gov
> *Objet :* Re: [petsc-users] Question about parallel Vectors and
> communicators
> Jean-Christophe,
>   I added a petsc example at
> https://bitbucket.org/petsc/petsc/pull-requests/1652/add-an-example-to-show-transfer-vectors/diff#chg-src/vec/vscat/examples/ex9.c
>   It shows how to transfer vectors from a parent communicator to vectors
> on a child communicator. It also shows how to transfer vectors from a
> subcomm to vectors on another subcomm. The two subcomms are not required to
> cover all processes in PETSC_COMM_WORLD.
>   Hope it helps you better understand Vec and VecScatter.
> --Junchao Zhang
> On Thu, May 9, 2019 at 11:34 AM GIRET Jean-Christophe via petsc-users <
> Hello,
> Thanks Mark and Jed for your quick answers.
> So the idea is to define all the Vecs on the world communicator, and
> perform the communications using traditional scatter objects? The data
> would still be accessible on the two sub-communicators as they are both
> subsets of the MPI_COMM_WORLD communicator, but they would be used while
> creating the Vecs or the IS for the scatter. Is that right?
> I’m currently trying, without success, to perform a Scatter from a MPI Vec
> defined on a subcomm to another Vec defined on the world comm, and
> vice-versa. But I don’t know if it’s possible.
> I can imagine that trying doing that seems a bit strange. However, I’m
> dealing with code coupling (and linear algebra for the main part of the
> code), and my idea was trying to use the Vec data structures to perform
> data exchange between some parts of the software which would have their own
> communicator. It would eliminate the need to re-implement an ad-hoc
> solution.
> An option would be to stick on the world communicator for all the PETSc
> part, but I could face some situations where my Vecs could be small while I
> would have to run the whole simulation on an important number of core for
> the coupled part. I imagine that It may not really serve the linear system
> solving part in terms of performance. Another one would be perform all the
> PETSc operations on a sub-communicator and use “raw” MPI communications
> between the communicators to perform the data exchange for the coupling
> part.
> Thanks again for your support,
> Best regards,
> Jean-Christophe
> *De :* Mark Adams [mailto:mfadams at lbl.gov]
> *Envoyé :* mardi 7 mai 2019 21:39
> *Cc :* petsc-users at mcs.anl.gov
> communicators
> On Tue, May 7, 2019 at 11:38 AM GIRET Jean-Christophe via petsc-users <
> Dear PETSc users,
> I would like to use Petsc4Py for a project extension, which consists
> mainly of:
> -          Storing data and matrices on several rank/nodes which could
> not fit on a single node.
> -          Performing some linear algebra in a parallel fashion (solving
> sparse linear system for instance)
> -          Exchanging those data structures (parallel vectors) between
> non-overlapping MPI communicators, created for instance by splitting
> MPI_COMM_WORLD.
> While the two first items seems to be well addressed by PETSc, I am
> wondering about the last one.
> Is it possible to access the data of a vector, defined on a communicator
> from another, non-overlapping communicator? From what I have seen from the
> documentation and the several threads on the user mailing-list, I would say
> no. But maybe I am missing something? If not, is it possible to transfer a
> vector defined on a given communicator on a communicator which is a subset
> of the previous one?
> If you are sending to a subset of processes then VecGetSubVec + Jed's
> tricks might work.
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetSubVector.html
> Best regards,
> Jean-Christophe
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190513/7a4cd875/attachment.html>
