[petsc-users] SLEPc: logpcg works but lanczos fails
Qiyue Lu qiyuelu1 at gmail.com
Sun May 5 10:05:39 CDT 2019
Hello,
I am solving a general eigenvalue problem
Ax=lamda*Bx
A is the stiffness matrix, B the mass matrix. The DOF of these matrices are
24,000 around. Both of them are symmetric and stored in SEQSBAIJ format.
Also, I downloaded mumps during the configuration and installation of
PETSc.
In SLETc, this eigenvalue system can be solved by *-eps_tpye logpcg* while
requesting *EPS_SMALLEST_REAL*. However, *-eps_type lanczos* doesn't work,
which yields a very huge number. It seems mumps is called indeed. The
output of *-eps_view* is attached. The command line I am using is:
*mpirun -np 40 ./test -fA matrixA -fB matrixB -eps_type lanczos -eps_view*
Did I miss any substantial configurations for lanczos solver?
Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190505/428f7516/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190505/428f7516/attachment.obj>
