[petsc-users] ``--with-clanguage=c++" turns on "PETSC_HAVE_COMPLEX"?
Balay, Satish balay at mcs.anl.gov
Fri May 3 21:43:11 CDT 2019
On Fri, 3 May 2019, Fande Kong via petsc-users wrote:
> > > It looks like mpicxx from openmpi does not handle this correctly.
> > Perhaps my earlier messages was not clear. The problem is not with
> > OpenMPI - but your build of it. Its installed with 'clang' as the C++
> > compiler - it should be built with 'clang++' as the c++ compiler.
> Oh, I see. Thanks.
I've added a check to configure
https://bitbucket.org/petsc/petsc/pull-requests/1622/configure-when-with-clanguage-cxx-is-used/diff
Satish
