[petsc-users] Bad memory scaling with PETSc 3.10
Zhang, Hong hzhang at mcs.anl.gov
Fri May 3 09:34:58 CDT 2019
Myriam:
Very interesting results. Do you have time for petsc-3.10 (blue) and 3.6 (green)?
I do not understand why all algorithms gives non-scalable memory performance except petsc-3.6. We can easily resume petsc-3.6's MatPtAP though.
Hong
And the attached files... Sorry
Le 05/03/19 à 16:11, Myriam Peyrounette a écrit :
I plotted new scalings (memory and time) using the new algorithms. I used the options -options_left true to make sure that the options are effectively used. They are.
I don't have access to the platform I used to run my computations on, so I ran them on a different one. In particular, I can't reach problem size = 1e8 and the values might be different from the previous scalings I sent you. But the comparison of the PETSc versions and options is still relevant.
I plotted the scalings of reference: the "good" one (PETSc 3.6.4) in green, the "bad" one (PETSc 3.10.2) in blue.
I used the commit d330a26 (3.11.1) for all the other scalings, adding different sets of options:
Light blue -> -matptap_via allatonce  -mat_freeintermediatedatastructures 1
Orange -> -matptap_via allatonce_merged -mat_freeintermediatedatastructures 1
Purple -> -matptap_via allatonce  -mat_freeintermediatedatastructures 1 -inner_diag_matmatmult_via scalable -inner_offdiag_matmatmult_via scalable
Yellow: -matptap_via allatonce_merged -mat_freeintermediatedatastructures 1 -inner_diag_matmatmult_via scalable -inner_offdiag_matmatmult_via scalable
Conclusion: with regard to memory, the two algorithms imply a similarly good improvement of the scaling. The use of the -inner_(off)diag_matmatmult_via options is also very interesting. The scaling is still not as good as 3.6.4 though.
With regard to time, I noted a real improvement in time execution! I used to spend 200-300s on these executions. Now they take 10-15s. Beside that, the "_merged" versions are more efficient. And the -inner_(off)diaf_matmatmult_via options are slightly expensive but it is not critical.
What do you think? Is it possible to match again the scaling of PETSc 3.6.4? Is it worthy keeping investigating?
Myriam
Le 04/30/19 à 17:00, Fande Kong a écrit :
HI Myriam,
We are interesting how the new algorithms perform. So there are two new algorithms you could try.
Algorithm 1:
Algorithm 2:
Note that you need to use the current petsc-master, and also please put "-snes_view" in your script so that we can confirm these options are actually get set.
Fande,
On Tue, Apr 30, 2019 at 2:26 AM Myriam Peyrounette via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
that's really good news for us, thanks! I will plot again the memory scaling using these new options and let you know. Next week I hope.
Before that, I just need to clarify the situation. Throughout our discussions, we mentionned a number of options concerning the scalability:
-matptatp_via scalable
Which ones of them are compatible? Should I use all of them at the same time? Is there redundancy?
Myriam
Le 04/25/19 à 21:47, Zhang, Hong a écrit :
Myriam:
Checking MatPtAP() in petsc-3.6.4, I realized that it uses different algorithm than petsc-10 and later versions. petsc-3.6 uses out-product for C=P^T * AP, while petsc-3.10 uses local transpose of P. petsc-3.10 accelerates data accessing, but doubles the memory of P.
Fande added two new implementations for MatPtAP() to petsc-master which use much smaller and scalable memories with slightly higher computing time (faster than hypre though). You may use these new implementations if you have concern on memory scalability. The option for these new implementation are:
Hong
On Mon, Apr 15, 2019 at 12:10 PM hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov> <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>> wrote:
Myriam:
Thank you very much for providing these results!
I have put effort to accelerate execution time and avoid using global sizes in PtAP, for which the algorithm of transpose of P_local and P_other likely doubles the memory usage. I'll try to investigate why it becomes unscalable.
Hong
you'll find the new scaling attached (green line). I used the version 3.11 and the four scalability options :
-matptap_via scalable
The scaling is much better! The code even uses less memory for the smallest cases. There is still an increase for the larger one.
With regard to the time scaling, I used KSPView and LogView on the two previous scalings (blue and yellow lines) but not on the last one (green line). So we can't really compare them, am I right? However, we can see that the new time scaling looks quite good. It slightly increases from ~8s to ~27s.
Unfortunately, the computations are expensive so I would like to avoid re-run them if possible. How relevant would be a proper time scaling for you?
Myriam
Le 04/12/19 à 18:18, Zhang, Hong a écrit :
Myriam :
Thanks for your effort. It will help us improve PETSc.
Hong
Hi all,
I used the wrong script, that's why it diverged... Sorry about that.
I tried again with the right script applied on a tiny problem (~200
elements). I can see a small difference in memory usage (gain ~ 1mB).
when adding the -mat_freeintermediatestructures option. I still have to
execute larger cases to plot the scaling. The supercomputer I am used to
run my jobs on is really busy at the moment so it takes a while. I hope
I'll send you the results on Monday.
Thanks everyone,
Myriam
Le 04/11/19 à 06:01, Jed Brown a écrit :
> "Zhang, Hong" <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>> writes:
>> Jed:
>>>> Myriam,
>>>> Thanks for the plot. '-mat_freeintermediatedatastructures' should not affect solution. It releases almost half of memory in C=PtAP if C is not reused.
>>> And yet if turning it on causes divergence, that would imply a bug.
>>> Hong, are you able to reproduce the experiment to see the memory
>>> scaling?
>> I like to test his code using an alcf machine, but my hands are full now. I'll try it as soon as I find time, hopefully next week.
> I have now compiled and run her code locally.
> Myriam, thanks for your last mail adding configuration and removing the
> MemManager.h dependency.  I ran with and without
> -mat_freeintermediatedatastructures and don't see a difference in
> convergence.  What commands did you run to observe that difference?
Myriam Peyrounette
CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190503/4affb3ec/attachment.html>
