[petsc-users] Vector layout in PetscBinaryRead.m
zakaryah
zakaryah at gmail.com
Thu May 2 14:32:06 CDT 2019
Thanks Matt - that snippet ran fine.
On Thu, May 2, 2019 at 3:30 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, May 2, 2019 at 3:13 PM zakaryah via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> I get a segfault on VecViewFromOptions, with the command line you
>> suggested. Likewise, if I execute ex10 (Tests I/O of vectors for
>> different data formats (binary,HDF5) and illustrates the use of
>> user-defined event logging), even with -n 1, I get a segfault.
>> Is VecViewFromOptions documented somewhere? Google only turns up the
>> version from 3.2, which took two arguments. From the source, it looks like
>> a wrapper for PetscObjectViewFromOptions, but I still don't see all the
>> format specifications. I'd like to test whether the same code crashes for
>> other formats, like binary, matlab, etc.
> I think it must be you call. Lets try and example first:
> cd $PETSC_DIR/src/snes/examples/tutorials
> make ex5
> ./ex5 -mms 1 -sol_view hdf5:sol.h5
> Thanks,
> Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190502/42e84ea5/attachment.html>
