[petsc-users] Vector layout in PetscBinaryRead.m
zakaryah
zakaryah at gmail.com
Thu May 2 14:11:12 CDT 2019
I get a segfault on VecViewFromOptions, with the command line you
suggested. Likewise, if I execute ex10 (Tests I/O of vectors for different
data formats (binary,HDF5) and illustrates the use of user-defined event
logging), even with -n 1, I get a segfault.
Is VecViewFromOptions documented somewhere? Google only turns up the
version from 3.2, which took two arguments. From the source, it looks like
a wrapper for PetscObjectViewFromOptions, but I still don't see all the
format specifications. I'd like to test whether the same code crashes for
other formats, like binary, matlab, etc.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190502/48ae8440/attachment.html>
