[petsc-users] Vector layout in PetscBinaryRead.m
zakaryah zakaryah at gmail.com
Wed May 1 16:55:48 CDT 2019
Thanks Matt.  I have had problems getting HDF5 to work when I run my solver
in parallel.  Can you link me to an example which writes a vector as HDF5
that will work in parallel?  To be clear - I don't care if the I/O is in
serial, I just need the VecView to not crash with multiple processors.
On Wed, May 1, 2019 at 5:51 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, May 1, 2019 at 5:44 PM zakaryah via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> I'm using PETSc to solve some equations, outputting the results using
>> PetscViewerBinaryOpen and VecView, then loading the vector files into
>> Matlab using PetscBinaryRead.m.  The vectors are global vectors created
>> from a 3D DMDA.  Is there a way to extract the layout from the binary file,
>> so that I can visualize the vectors on a 3D grid?
> No, we do not preserve that information in the PETSc binary format. We
> have richer output that does, like HDF5.
>   Thanks,
>     Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190501/d208d8d4/attachment.html>
