[petsc-users] petsc4py - Convert c example code to Python
Nicola Creati ncreati at inogs.it
Thu Mar 28 04:17:53 CDT 2019
Hello, I'm trying to write in Python one of the TS PETSc tutorial example:
https://www.mcs.anl.gov/petsc/petsc-current/src/ts/examples/tutorials/ex13.c.html
I'm not able to fill the Jacobian matrix in the right way in Python.
Maybe there are some other conversion errors.
Might someone help, please?
This is my code:
# Example 13 petsc TS
import sys, petsc4py
petsc4py.init(sys.argv)
from petsc4py import PETSc
from mpi4py import MPI
import numpy as np
import math
def RHS_func(ts, t, X, xdot, F):
     da = ts.getDM()
     mx, my = da.getSizes()
     hx, hy = [1.0/(m-1) for m in [mx, my]]
     sx = 1.0/(hx*hx)
     sy = 1.0/(hy*hy)
     x = X.getArray(readonly=1).reshape(8, 8, order='C')
     f = F.getArray(readonly=0).reshape(8, 8, order='C')
     (xs, xm), (ys, ym) = da.getRanges()
     aa = np.zeros((8,8))
     for j in range(ys, ym):
         for i in range(xs, xm):
             if i == 0 or j == 0 or i == (mx-1) or j == (my-1):
                 f[i,j] = x[i,j]
                 continue
             u = x[i,j]
             uxx = (-2.0 * u + x[i, j-1] + x[i, j+1]) * sx
             uyy = (-2.0 * u + x[i-1, j] + x[i+1, j])* sy
             f[i, j] = uxx + uyy
     F.assemble()
def Jacobian_func(ts, t, x, xdot, a, A, B):
     hx = 1.0/(mx-1)
     hy = 1.0/(my-1)
     sx = 1.0/(hx*hx)
     sy = 1.0/(hy*hy)
     B.zeroEntries()
     (i0, i1), (j0, j1) = da.getRanges()
     row = PETSc.Mat.Stencil()
     col = PETSc.Mat.Stencil()
     for i in range(j0, j1):
         for j in range(i0, i1):
             row.index = (i,j)
             row.field = 0
             if i == 0 or j== 0 or i==(my-1) or j==(mx-1):
                 B.setValueStencil(row, row, 1.0)
             else:
                 for index, value in [
                     ((i-1, j),   sx),
                     ((i+1, j),   sx),
                     ((i,   j-1), sy),
                     ((i-1, j+1), sy),
                     ((i,   j),  -2*sx - 2*sy)]:
                     col.index = index
                     col.field = 0
                     B.setValueStencil(row, col, value)
     B.assemble()
     if A != B: B.assemble()
     return PETSc.Mat.Structure.SAME_NONZERO_PATTERN
def make_initial_solution(da, U, c):
     hx = 1.0/(mx-1)
     hy = 1.0/(my-1)
     u = U.getArray(readonly=0).reshape(8, 8, order='C')
         y = j*hy
             x = i*hx
             r = math.sqrt((x-0.5)**2+(y-0.5)**2)
             if r < (0.125):
                 u[i, j] = math.exp(c*r*r*r)
             else:
                 u[i, j] = 0.0
     U.assemble()
def monitor(ts, i, t, x):
     xx = x[:].tolist()
     history.append((i, t, xx))
history = []
nx = 8
ny = 8
da = PETSc.DMDA().create([nx, ny], stencil_type= PETSc.DA.StencilType.STAR)
da.setFromOptions()
da.setUp()
u = da.createGlobalVec()
f = u.duplicate()
c = -30.0
ts = PETSc.TS().create()
ts.setDM(da)
ts.setType(ts.Type.BEULER)
ts.setIFunction(RHS_func, f)
ts.setIJacobian(Jacobian_func)
ftime = 1.0
ts.setMaxTime(ftime)
ts.setExactFinalTime(PETSc.TS.ExactFinalTime.STEPOVER)
make_initial_solution(da, u, c)
dt = 0.01
ts.setMonitor(monitor)
ts.setTimeStep(dt)
ts.setFromOptions()
ts.solve(u)
ftime = ts.getSolveTime()
steps = ts.getStepNumber()
Thanks.
Nicola
Nicola Creati
Istituto Nazionale di Oceanografia e di Geofisica Sperimentale - OGS www.inogs.it
Dipartimento di Geofisica della Litosfera Geophysics of Lithosphere Department
CARS (Cartography and Remote Sensing) Research Group http://www.inogs.it/Cars/
Borgo Grotta Gigante 42/c 34010 Sgonico - Trieste - ITALY ncreati at ogs.trieste.it
off.   +39 040 2140 213
fax.   +39 040 327307
_____________________________________________________________________
This communication, that may contain confidential and/or legally privileged information, is intended solely for the use of the intended addressees. Opinions, conclusions and other information contained in this message, that do not relate to the official business of OGS, shall be considered as not given or endorsed by it. Every opinion or advice contained in this communication is subject to the terms and conditions provided by the agreement governing the engagement with such a client. Any use, disclosure, copying or distribution of the contents of this communication by a not-intended recipient or in violation of the purposes of this communication is strictly prohibited and may be unlawful. For Italy only: Ai sensi del D.Lgs.196/2003 - "T.U. sulla Privacy" si precisa che le informazioni contenute in questo messaggio sono riservate ed a uso esclusivo del destinatario.
