[petsc-users] Consistent domain decomposition between DMDA and DMPLEX
Mark Adams
mfadams at lbl.gov
Thu Mar 28 07:55:53 CDT 2019
> That seems like a bad tradeoff. You avoid one communication during
> injection for at least that much or more during
> FE assembly on that cell partition?
I am just guessing about the purpose as a way to describing what they are
asking for.
> Matt
>>> Thanks,
>>> Matt
>>>> Sincerely,
>>>> Swarnava
>>>> On Fri, Mar 22, 2019 at 4:08 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> Matt,
>>>>> I think they want a vertex partitioning. They may have elements on the
>>>>> unstructured mesh that intersect with any number of processor domains on
>>>>> the structured mesh. But the unstructured mesh vertices are in the
>>>>> structured mesh set of vertices. They want the partition of the
>>>>> unstructured mesh vertices (ie, matrices) to be slaved to the partitioning
>>>>> of the structured mesh.
>>>>> Do I have that right Swarnava?
>>>>> Mark
>>>>> On Fri, Mar 22, 2019 at 6:56 PM Matthew Knepley via petsc-users <
>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>> On Thu, Mar 21, 2019 at 8:20 PM Swarnava Ghosh via petsc-users <
>>>>>>> Dear PETSc users and developers,
>>>>>>> I am new to DMPLEX and had a query regarding setting up a consistent
>>>>>>> domain decomposition of two meshes in PETSc.
>>>>>>> I have a structured finite difference grid, managed through DMDA. I
>>>>>>> have another unstructured finite element mesh managed through DMPLEX. Now
>>>>>>> all the nodes in the unstructured finite element mesh also belong to the
>>>>>>> set of nodes in the structured finite difference mesh (but not necessarily
>>>>>>> vice-versa), and the number of nodes in DMPLEX mesh is less than the number
>>>>>>> of nodes in DMDA mesh. How can I guarantee a consistent domain
>>>>>>> decomposition of the two meshes? By consistent, I mean that if a process
>>>>>>> has a set of nodes P from DMDA, and the same process has the set of nodes Q
>>>>>>> from DMPLEX, then Q is a subset of P.
>>>>>> Okay, this is not hard. DMPlexDistribute() basically distributes
>>>>>> according to a cell partition. You can use PetscPartitionerShell() to stick
>>>>>> in whatever cell partition you want. You can see me doing this here:
>>>>>> https://bitbucket.org/petsc/petsc/src/e2aefa968a094f48dc384fffc7d599a60aeeb591/src/dm/impls/plex/examples/tests/ex1.c#lines-261
>>>>>> Will that work for you?
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> I look forward to your response.
>>>>>>> Sincerely,
>>>>>>> Swarnava
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190328/83ef4117/attachment.html>
