[petsc-users] [Ext] Re: error: identifier "MatCreateMPIAIJMKL" is undefined in 3.10.4
Balay, Satish
balay at mcs.anl.gov
Tue Mar 26 15:41:44 CDT 2019
Please apply the patch I sent earlier and retry.
Satish
On Tue, 26 Mar 2019, Kun Jiao via petsc-users wrote:
> Strange things, when I compile my code in the test dir in PETSC, it works. After I "make install" PETSC, and try to compile my code against the installed PETSC, it doesn't work any more.
> I guess this is what you means.
> Is there any way to reenable MatCreateMPIAIJMKL public interface?
> And, I am using intel MKL, here is my configure option:
> Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions PETSC_ARCH=linux-gnu-intel --with-precision=single --with-cc=mpiicc --with-cxx=mpiicc --with-fc=mpiifort --with-mpi-include=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mpi/intel64/include --with-mpi-lib="-L/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel//compilers_and_libraries_2019.2.187/linux/mpi/intel64/lib -lmpifort -lmpi_ilp64" --with-blaslapack-lib="-L/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl/lib/intel64 -Wl, --no-as-needed -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -ldl" --with-scalapack-lib="-L/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl/lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64" --with-scalapack-include=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl/include --with-mkl_pardiso-dir=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl --with-mkl_sparse=1 --with-mkl_sparse-dir=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl --with-mkl_cpardiso=1 --with-mkl_cpardiso-dir=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl --with-mkl_sparse_optimize=1 --with-mkl_sparse_optimize-dir=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl --with-mkl_sparse_sp2m=1 --with-mkl_sparse_sp2m-dir=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/intel/compilers_and_libraries_2019.2.187/linux/mkl --with-cmake=1 --prefix=/wgdisk/hy3300/source_code_dev/imaging/kjiao/software/petsc_3.9.4 --known-endian=big --with-debugging=0 --COPTFLAGS=" -Ofast -xHost" --CXXOPTFLAGS=" -Ofast -xHost" --FOPTFLAGS=" -Ofast -xHost" --with-x=0
> Working directory: /wgdisk/hy3300/source_code_dev/imaging/kjiao/petsc-3.10.4
> Schlumberger-Private
> -----Original Message-----
> From: Balay, Satish <balay at mcs.anl.gov>
> Sent: Tuesday, March 26, 2019 10:19 AM
> To: Kun Jiao <KJiao at slb.com>
> Cc: Mark Adams <mfadams at lbl.gov>; petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] [Ext] Re: error: identifier "MatCreateMPIAIJMKL" is undefined in 3.10.4
> balay at sb /home/balay/petsc (maint=)
> $ git grep MatCreateMPIAIJMKL maint-3.8
> maint-3.8:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c: MatCreateMPIAIJMKL - Creates a sparse parallel matrix whose local
> maint-3.8:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:PetscErrorCode MatCreateMPIAIJMKL(MPI_Comm comm,PetscInt m,PetscInt n,PetscInt M,PetscInt N,PetscInt d_nz,const PetscInt d_nnz[],PetscInt o_nz,const PetscInt o_nnz[],Mat *A)
> maint-3.8:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:.seealso: MatCreateMPIAIJMKL(), MATSEQAIJMKL, MATMPIAIJMKL
> maint-3.8:src/mat/impls/aij/seq/aijmkl/aijmkl.c:.seealso: MatCreate(), MatCreateMPIAIJMKL(), MatSetValues() balay at sb /home/balay/petsc (maint=) $ git grep MatCreateMPIAIJMKL maint
> maint:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c: MatCreateMPIAIJMKL - Creates a sparse parallel matrix whose local
> maint:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:PetscErrorCode MatCreateMPIAIJMKL(MPI_Comm comm,PetscInt m,PetscInt n,PetscInt M,PetscInt N,PetscInt d_nz,const PetscInt d_nnz[],PetscInt o_nz,const PetscInt o_nnz[],Mat *A)
> maint:src/mat/impls/aij/mpi/aijmkl/mpiaijmkl.c:.seealso: MatCreateMPIAIJMKL(), MATSEQAIJMKL, MATMPIAIJMKL
> maint:src/mat/impls/aij/seq/aijmkl/aijmkl.c:.seealso: MatCreate(), MatCreateMPIAIJMKL(), MatSetValues() balay at sb /home/balay/petsc (maint=) $ <<<<<<<<<<<
> MatCreateMPIAIJMKL() exists in both petsc-3.8 and petsc-3.10. However the public interface is missing from both of these versions. So I'm surprised you don't get the same error with petsc-3.8
> Can you try the following change?
> diff --git a/include/petscmat.h b/include/petscmat.h index 1b8ac69377..c66f727994 100644
> --- a/include/petscmat.h
> +++ b/include/petscmat.h
> @@ -223,7 +223,8 @@ typedef enum {DIFFERENT_NONZERO_PATTERN,SUBSET_NONZERO_PATTERN,SAME_NONZERO_PATT
> #if defined PETSC_HAVE_MKL_SPARSE
> PETSC_EXTERN PetscErrorCode MatCreateBAIJMKL(MPI_Comm,PetscInt,PetscInt,PetscInt,PetscInt,PetscInt,PetscInt,const PetscInt[],PetscInt,const PetscInt[],Mat*); -PETSC_EXTERN PetscErrorCode MatCreateSeqBAIJMKL(MPI_Comm comm,PetscInt bs,PetscInt m,PetscInt n,PetscInt nz,const PetscInt nnz[],Mat *A);
> +PETSC_EXTERN PetscErrorCode
> +MatCreateSeqBAIJMKL(MPI_Comm,PetscInt,PetscInt,PetscInt,PetscInt,const
> +PetscInt[],Mat*); PETSC_EXTERN PetscErrorCode
> +MatCreateMPIAIJMKL(MPI_Comm,PetscInt,PetscInt,PetscInt,PetscInt,PetscIn
> +t,const PetscInt[],PetscInt,const PetscInt[],Mat*);
> #endif
> PETSC_EXTERN PetscErrorCode MatCreateSeqSELL(MPI_Comm,PetscInt,PetscInt,PetscInt,const PetscInt[],Mat*);
> Also note: - this routine is available only when PETSc is built with Intel MKL
> Satish
> > [kjiao at hyi0016 src/lsqr]% make
> > [ 50%] Building CXX object lsqr/CMakeFiles/p_lsqr.dir/lsqr.cc.o
> > /wgdisk/hy3300/source_code_dev/imaging/kjiao/src/git/src/lsqr/lsqr.cc(318): error: identifier "MatCreateMPIAIJMKL" is undefined
> > ierr = MatCreateMPIAIJMKL(comm,m,n,M,N,maxnz,dialens,maxnz,offlens,&A);CHKERRQ(ierr);
> > /wgdisk/hy3300/source_code_dev/imaging/kjiao/src/git/src/lsqr/lsqr.cc(578): error: identifier "MatCreateMPIAIJMKL" is undefined
> > compilation aborted for
> > (code 2)
> > Thanks.
> > From: Mark Adams <mfadams at lbl.gov>
> > Sent: Tuesday, March 26, 2019 9:22 AM
> > Cc: petsc-users at mcs.anl.gov
> > Subject: Re: [Ext] Re: [petsc-users] error: identifier
> > I assume the whole error message will have the line of code. Please send the whole error message and line of offending code if not included.
> > On Tue, Mar 26, 2019 at 10:08 AM Kun Jiao <KJiao at slb.com<mailto:KJiao at slb.com>> wrote:
> > It is compiling error, error message is:
> > error: identifier "MatCreateMPIAIJMKL" is undefined.
> > From: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
> > Sent: Tuesday, March 26, 2019 6:48 AM
> > To: Kun Jiao <KJiao at slb.com<mailto:KJiao at slb.com>>
> > Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
> > Subject: [Ext] Re: [petsc-users] error: identifier
> > Please send the output of the error (runtime, compile time, link
> > time?)
> > On Mon, Mar 25, 2019 at 10:50 PM Kun Jiao via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> > Hi Petsc Experts,
> > Is MatCreateMPIAIJMKL retired in 3.10.4?
> > I got this error with my code which works fine in 3.8.3 version.
> > Regards,
> > Kun
