[petsc-users] Bad memory scaling with PETSc 3.10
Myriam Peyrounette
myriam.peyrounette at idris.fr
Tue Mar 26 04:52:37 CDT 2019
How can I be sure they are indeed used? Can I print this information in
some log file?
Thanks in advance
Myriam
Le 03/25/19 à 18:24, Matthew Knepley a écrit :
> On Mon, Mar 25, 2019 at 10:54 AM Myriam Peyrounette via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Hi,
> thanks for the explanations. I tried the last PETSc version
> (commit fbc5705bc518d02a4999f188aad4ccff5f754cbf), which includes
> the patch you talked about. But the memory scaling shows no
> improvement (see scaling attached), even when using the "scalable"
> options :(
> I had a look at the PETSc functions MatPtAPNumeric_MPIAIJ_MPIAIJ
> and MatPtAPSymbolic_MPIAIJ_MPIAIJ (especially at the differences
> before and after the first "bad" commit), but I can't find what
> induced this memory issue.
> Are you sure that the option was used? It just looks suspicious to me
> that they use exactly the same amount of memory. It should be
> different, even if it does not solve the problem.
> Thanks,
> Matt
> Myriam
> Le 03/20/19 à 17:38, Fande Kong a écrit :
>> Hi Myriam,
>> There are three algorithms in PETSc to do PtAP ( const char
>> *algTypes[3] = {"scalable","nonscalable","hypre"};), and can
>> be specified using the petsc options: -matptap_via xxxx.
>> (1) -matptap_via hypre: This call the hypre package to do the
>> PtAP trough an all-at-once triple product. In our experiences, it
>> is the most memory efficient, but could be slow.
>> (2) -matptap_via scalable: This involves a row-wise algorithm
>> plus an outer product. This will use more memory than hypre, but
>> way faster. This used to have a bug that could take all your
>> memory, and I have a fix
>> at https://bitbucket.org/petsc/petsc/pull-requests/1452/mpiptap-enable-large-scale-simulations/diff.
>> When using this option, we may want to have extra options such
>> as -inner_offdiag_matmatmult_via scalable
>> -inner_diag_matmatmult_via scalable to select inner scalable
>> algorithms.
>> (3) -matptap_via nonscalable: Suppose to be even faster, but
>> use more memory. It does dense matrix operations.
>> Thanks,
>> Fande Kong
>> On Wed, Mar 20, 2019 at 10:06 AM Myriam Peyrounette via
>> petsc-users <petsc-users at mcs.anl.gov
>> More precisely: something happens when upgrading the
>> functions MatPtAPNumeric_MPIAIJ_MPIAIJ and/or
>> MatPtAPSymbolic_MPIAIJ_MPIAIJ.
>> Unfortunately, there are a lot of differences between the old
>> and new versions of these functions. I keep investigating but
>> if you have any idea, please let me know.
>> Best,
>> Myriam
>> Le 03/20/19 à 13:48, Myriam Peyrounette a écrit :
>>> Hi all,
>>> I used git bisect to determine when the memory need
>>> increased. I found that the first "bad" commit is
>>> aa690a28a7284adb519c28cb44eae20a2c131c85.
>>> Barry was right, this commit seems to be about an evolution
>>> of MatPtAPSymbolic_MPIAIJ_MPIAIJ. You mentioned the option
>>> "-matptap_via scalable" but I can't find any information
>>> about it. Can you tell me more?
>>> Thanks
>>> Myriam
>>> Le 03/11/19 à 14:40, Mark Adams a écrit :
>>>> Is there a difference in memory usage on your tiny problem?
>>>> I assume no.
>>>> I don't see anything that could come from GAMG other than
>>>> the RAP stuff that you have discussed already.
>>>> On Mon, Mar 11, 2019 at 9:32 AM Myriam Peyrounette
>>>> <myriam.peyrounette at idris.fr
>>>> <mailto:myriam.peyrounette at idris.fr>> wrote:
>>>> The code I am using here is the example 42 of PETSc
>>>> (https://www.mcs.anl.gov/petsc/petsc-3.9/src/ksp/ksp/examples/tutorials/ex42.c.html).
>>>> Indeed it solves the Stokes equation. I thought it was
>>>> a good idea to use an example you might know (and
>>>> didn't find any that uses GAMG functions). I just
>>>> changed the PCMG setup so that the memory problem
>>>> appears. And it appears when adding PCGAMG.
>>>> I don't care about the performance or even the result
>>>> rightness here, but only about the difference in memory
>>>> use between 3.6 and 3.10. Do you think finding a more
>>>> adapted script would help?
>>>> I used the threshold of 0.1 only once, at the
>>>> beginning, to test its influence. I used the default
>>>> threshold (of 0, I guess) for all the other runs.
>>>> Myriam
>>>> Le 03/11/19 à 13:52, Mark Adams a écrit :
>>>>> In looking at this larger scale run ...
>>>>> * Your eigen estimates are much lower than your tiny
>>>>> test problem. But this is Stokes apparently and it
>>>>> should not work anyway. Maybe you have a small time
>>>>> step that adds a lot of mass that brings the eigen
>>>>> estimates down. And your min eigenvalue (not used) is
>>>>> positive. I would expect negative for Stokes ...
>>>>> * You seem to be setting a threshold value of 0.1 --
>>>>> that is very high
>>>>> * v3.6 says "using nonzero initial guess" but this is
>>>>> not in v3.10. Maybe we just stopped printing that.
>>>>> * There were some changes to coasening parameters in
>>>>> going from v3.6 but it does not look like your problem
>>>>> was effected. (The coarsening algo is
>>>>> non-deterministic by default and you can see small
>>>>> difference on different runs)
>>>>> * We may have also added a "noisy" RHS for eigen
>>>>> estimates by default from v3.6.
>>>>> * And for non-symetric problems you can try
>>>>> -pc_gamg_agg_nsmooths 0, but again GAMG is not built
>>>>> for Stokes anyway.
>>>>> On Tue, Mar 5, 2019 at 11:53 AM Myriam Peyrounette
>>>>> I used PCView to display the size of the linear
>>>>> system in each level of the MG. You'll find the
>>>>> outputs attached to this mail (zip file) for both
>>>>> the default threshold value and a value of 0.1,
>>>>> and for both 3.6 and 3.10 PETSc versions.
>>>>> For convenience, I summarized the information in a
>>>>> graph, also attached (png file).
>>>>> As you can see, there are slight differences
>>>>> between the two versions but none is critical, in
>>>>> my opinion. Do you see anything suspicious in the
>>>>> outputs?
>>>>> + I can't find the default threshold value. Do you
>>>>> know where I can find it?
>>>>> Thanks for the follow-up
>>>>> Myriam
>>>>> Le 03/05/19 à 14:06, Matthew Knepley a écrit :
>>>>>> On Tue, Mar 5, 2019 at 7:14 AM Myriam Peyrounette
>>>>>> Hi Matt,
>>>>>> I plotted the memory scalings using different
>>>>>> threshold values. The two scalings are
>>>>>> slightly translated (from -22 to -88 mB) but
>>>>>> this gain is neglectable. The 3.6-scaling
>>>>>> keeps being robust while the 3.10-scaling
>>>>>> deteriorates.
>>>>>> Do you have any other suggestion?
>>>>>> Mark, what is the option she can give to output
>>>>>> all the GAMG data?
>>>>>> Also, run using -ksp_view. GAMG will report all
>>>>>> the sizes of its grids, so it should be easy to see
>>>>>> if the coarse grid sizes are increasing, and also
>>>>>> what the effect of the threshold value is.
>>>>>> Thanks,
>>>>>> Matt
>>>>>> Thanks
>>>>>> Myriam
>>>>>> Le 03/02/19 à 02:27, Matthew Knepley a écrit :
>>>>>>> On Fri, Mar 1, 2019 at 10:53 AM Myriam
>>>>>>> Hi,
>>>>>>> I used to run my code with PETSc 3.6.
>>>>>>> Since I upgraded the PETSc version
>>>>>>> to 3.10, this code has a bad memory scaling.
>>>>>>> To report this issue, I took the PETSc
>>>>>>> script ex42.c and slightly
>>>>>>> modified it so that the KSP and PC
>>>>>>> configurations are the same as in my
>>>>>>> code. In particular, I use a
>>>>>>> "personnalised" multi-grid method. The
>>>>>>> modifications are indicated by the
>>>>>>> keyword "TopBridge" in the attached
>>>>>>> scripts.
>>>>>>> To plot the memory (weak) scaling, I ran
>>>>>>> four calculations for each
>>>>>>> script with increasing problem sizes and
>>>>>>> computations cores:
>>>>>>> 1. 100,000 elts on 4 cores
>>>>>>> 2. 1 million elts on 40 cores
>>>>>>> 3. 10 millions elts on 400 cores
>>>>>>> 4. 100 millions elts on 4,000 cores
>>>>>>> The resulting graph is also attached.
>>>>>>> The scaling using PETSc 3.10
>>>>>>> clearly deteriorates for large cases,
>>>>>>> while the one using PETSc 3.6 is
>>>>>>> robust.
>>>>>>> After a few tests, I found that the
>>>>>>> scaling is mostly sensitive to the
>>>>>>> use of the AMG method for the coarse
>>>>>>> grid (line 1780 in
>>>>>>> main_ex42_petsc36.cc). In particular,
>>>>>>> the performance strongly
>>>>>>> deteriorates when commenting lines 1777
>>>>>>> to 1790 (in main_ex42_petsc36.cc).
>>>>>>> Do you have any idea of what changed
>>>>>>> between version 3.6 and version
>>>>>>> 3.10 that may imply such degradation?
>>>>>>> I believe the default values for PCGAMG
>>>>>>> changed between versions. It sounds like the
>>>>>>> coarsening rate
>>>>>>> is not great enough, so that these grids are
>>>>>>> too large. This can be set using:
>>>>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
>>>>>>> There is some explanation of this effect on
>>>>>>> that page. Let us know if setting this does
>>>>>>> not correct the situation.
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>> Let me know if you need further information.
>>>>>>> Best,
>>>>>>> Myriam Peyrounette
>>>>>>> Myriam Peyrounette
>>>>>>> CNRS/IDRIS - HLST
>>>>>>> What most experimenters take for granted
>>>>>>> before they begin their experiments is
>>>>>>> infinitely more interesting than any results
>>>>>>> to which their experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/%7Eknepley/>
>>>>>> Myriam Peyrounette
>>>>>> CNRS/IDRIS - HLST
>>>>>> What most experimenters take for granted before
>>>>>> they begin their experiments is infinitely more
>>>>>> interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> Myriam Peyrounette
>>>>> CNRS/IDRIS - HLST
>>>> Myriam Peyrounette
>>>> CNRS/IDRIS - HLST
>>> Myriam Peyrounette
>>> CNRS/IDRIS - HLST
>> Myriam Peyrounette
>> CNRS/IDRIS - HLST
> Myriam Peyrounette
> CNRS/IDRIS - HLST
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190326/fe8166df/attachment-0001.html>
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190326/fe8166df/attachment-0001.p7s>
