[petsc-users] Valgrind Issue With Ghosted Vectors
Stefano Zampini stefano.zampini at gmail.com
Mon Mar 25 16:47:50 CDT 2019
Il giorno lun 25 mar 2019 alle ore 21:40 Derek Gaston <friedmud at gmail.com>
ha scritto:
> Stefano: the stupidity was all mine and had nothing to do with PETSc.
> Valgrind helped me track down a memory corruption issue that ultimately was
> just about a bad input file to my code (and obviously not enough error
> checking for input files!).
> The issue is fixed.
> Now - I'd like to understand a bit more about what happened here on the
> PETSc side.  Was this valgrind issue something that was known and you
> already had a fix for it - but it wasn't on maint yet?  Or was it just that
> I was using too old of a version of PETSc so I didn't have the fix?
None of this. My fix is for a separate code path (ADD_VALUES, and not
INSERT_VALUES). I cannot tell what happened on your side without knowing
the details.
> Derek
> On Fri, Mar 22, 2019 at 4:29 AM Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
>> On Mar 21, 2019, at 7:59 PM, Derek Gaston <friedmud at gmail.com> wrote:
>> It sounds like you already tracked this down... but for completeness here
>> is what track-origins gives:
>> ==262923== Conditional jump or move depends on uninitialised value(s)
>> ==262923==    at 0x73C6548: VecScatterMemcpyPlanCreate_Index (vscat.c:294)
>> ==262923==    by 0x73DBD97: VecScatterMemcpyPlanCreate_PtoP
>> (vpscat_mpi1.c:312)
>> ==262923==    by 0x73DE6AE: VecScatterCreateCommon_PtoS_MPI1
>> (vpscat_mpi1.c:2328)
>> ==262923==    by 0x73DFFEA: VecScatterCreateLocal_PtoS_MPI1
>> (vpscat_mpi1.c:2202)
>> ==262923==    by 0x73C7A51: VecScatterCreate_PtoS (vscat.c:608)
>> ==262923==    by 0x73C9E8A: VecScatterSetUp_vectype_private (vscat.c:857)
>> ==262923==    by 0x73CBE5D: VecScatterSetUp_MPI1 (vpscat_mpi1.c:2543)
>> ==262923==    by 0x7413D39: VecScatterSetUp (vscatfce.c:212)
>> ==262923==    by 0x7412D73: VecScatterCreateWithData (vscreate.c:333)
>> ==262923==    by 0x747A232: VecCreateGhostWithArray (pbvec.c:685)
>> ==262923==    by 0x747A90D: VecCreateGhost (pbvec.c:741)
>> ==262923==    by 0x5C7FFD6: libMesh::PetscVector<double>::init(unsigned
>> long, unsigned long, std::vector<unsigned long, std::allocator<unsigned
>> long> > const&, bool, libMesh::ParallelType) (petsc_vector.h:752)
>> ==262923==  Uninitialised value was created by a heap allocation
>> ==262923==    at 0x402DDC6: memalign (vg_replace_malloc.c:899)
>> ==262923==    by 0x7359702: PetscMallocAlign (mal.c:41)
>> ==262923==    by 0x7359C70: PetscMallocA (mal.c:390)
>> ==262923==    by 0x73DECF0: VecScatterCreateLocal_PtoS_MPI1
>> (vpscat_mpi1.c:2061)
>> BTW: This turned out not to be my actual problem.  My actual problem was
>> just some stupidity on my part... just a simple input parameter issue to my
>> code (should have had better error checking!).
>> But: It sounds like my digging may have uncovered something real here...
>> so it wasn't completely useless :-)
>> Derek,
>> I don’t understand. Is your problem fixed or not? Would be nice to
>> understand what was the “some stupidity on your part”, and if it was still
>> leading to valid PETSc code or just to a broken setup.
>> In the first case, then we should investigate the valgrind error you
>> reported.
>> In the second case, this is not a PETSc issue.
>> Thanks for your help everyone!
>> Derek
>> On Thu, Mar 21, 2019 at 10:38 AM Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> Il giorno mer 20 mar 2019 alle ore 23:40 Derek Gaston via petsc-users <
>>> petsc-users at mcs.anl.gov> ha scritto:
>>>> Trying to track down some memory corruption I'm seeing on larger scale
>>>> runs (3.5B+ unknowns).
>>> Uhm.... are you using 32bit indices? is it possible there's integer
>>> overflow somewhere?
>>>> Was able to run Valgrind on it... and I'm seeing quite a lot of
>>>> uninitialized value errors coming from ghost updating.  Here are some of
>>>> the traces:
>>>> ==87695== Conditional jump or move depends on uninitialised value(s)
>>>> ==87695==    at 0x73236D3: PetscMallocAlign (mal.c:28)
>>>> ==87695==    by 0x7323C70: PetscMallocA (mal.c:390)
>>>> ==87695==    by 0x739048E: VecScatterMemcpyPlanCreate_Index
>>>> (vscat.c:284)
>>>> ==87695==    by 0x73A5D97: VecScatterMemcpyPlanCreate_PtoP
>>>> (vpscat_mpi1.c:312)
>>>> ==64730==    by 0x7393E8A: VecScatterSetUp_vectype_private (vscat.c:857)
>>>> ==64730==    by 0x7395E5D: VecScatterSetUp_MPI1 (vpscat_mpi1.c:2543)
>>>> ==64730==    by 0x73DDD39: VecScatterSetUp (vscatfce.c:212)
>>>> ==64730==    by 0x73DCD73: VecScatterCreateWithData (vscreate.c:333)
>>>> ==64730==    by 0x7444232: VecCreateGhostWithArray (pbvec.c:685)
>>>> ==64730==    by 0x744490D: VecCreateGhost (pbvec.c:741)
>>>> ==133582== Conditional jump or move depends on uninitialised value(s)
>>>> ==133582==    at 0x4030384: memcpy@@GLIBC_2.14
>>>> (vg_replace_strmem.c:1034)
>>>> ==133582==    by 0x739E4F9: PetscMemcpy (petscsys.h:1649)
>>>> ==133582==    by 0x739E4F9: VecScatterMemcpyPlanExecute_Pack
>>>> (vecscatterimpl.h:150)
>>>> ==133582==    by 0x739E4F9: VecScatterBeginMPI1_1 (vpscat_mpi1.h:69)
>>>> ==133582==    by 0x73DD964: VecScatterBegin (vscatfce.c:110)
>>>> ==133582==    by 0x744E195: VecGhostUpdateBegin (commonmpvec.c:225)
>>>> This is from a Git checkout of PETSc... the hash I branched from is:
>>>> 0e667e8fea4aa from December 23rd (updating would be really hard at this
>>>> point as I've completed 90% of my dissertation with this version... and
>>>> changing PETSc now would be pretty painful!).
>>>> Any ideas?  Is it possible it's in my code?  Is it possible that there
>>>> are later PETSc commits that already fix this?
>>>> Thanks for any help,
>>>> Derek
>>> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190325/be68ab4c/attachment.html>
