[petsc-users] About Configuring PETSc
Maahi Talukder maahi.buet at gmail.com
Sat Mar 23 13:12:21 CDT 2019
I think I didn't build with PETSC-ARCH=arch-opt.
So just to make sure, now I just run the command - ./configure  PETSC_ARCH
= arch-opt - and it will create the missing directory and I can switch
between different architectures, right?
Maahi Talukder
On Fri, Mar 22, 2019 at 3:12 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> Did you build PETSc with PETSC_ARCH=arch-opt?
> Btw - I used PETSC_ARCH=arch-debug to illustrate - but you already
> have a build with PETSC_ARCH=arch-linux2-c-debug - so you should stick
> to that.
> Satish
> On Fri, 22 Mar 2019, Maahi Talukder via petsc-users wrote:
> > Hi,
> > I tried to run the command 'make PETSC_ARCH=arch-opt wholetest1' but it
> > shows me the following error-
> > [maahi at CB272PP-THINK1 Desktop]$ make PETSC_ARCH=arch-opt wholetest1
> > /home/maahi/petsc/lib/petsc/conf/rules:960:
> > */home/maahi/petsc/arch-opt/lib/petsc/conf/petscrules:
> > No such file or directory*
> > make: *** No rule to make target
> > '/home/maahi/petsc/arch-opt/lib/petsc/conf/petscrules'.  Stop.
> > My .bashrc is the following -
> > PATH=$PATH:$HOME/.local/bin:$HOME/bin:/usr/lib64/openmpi/bin
> > export PATH
> > export PETSC_DIR=$HOME/petsc
> > export PETSC_ARCH=arch-linux2-c-debug
> > #export PETSC_ARCH=arch-debug
> > Could you please tell me what went wrong?
> > Regards,
> > Maahi Talukder
> > On Thu, Mar 21, 2019 at 11:55 PM Maahi Talukder <maahi.buet at gmail.com>
> > wrote:
> > > Thank you so much for your reply. That clear things up!
> > > On Thu, Mar 21, 2019 at 10:43 PM Balay, Satish <balay at mcs.anl.gov>
> wrote:
> > >> On Thu, 21 Mar 2019, Maahi Talukder via petsc-users wrote:
> > >> > Thank you for your reply.
> > >> > So do I need to set the value of PETSC_ARCH as needed in .bashrc
> as I
> > >> did
> > >> > in case of PETSC_DIR ?
> > >> You can specify PETSC_ARCH as an option to make. You can have a
> default
> > >> value set in .bashrc - and change to a different value on command
> line.
> > >> For ex: in .bashrc
> > >> Now if you want to build with debug libraries:
> > >> make wholetest1
> > >> Now If you want to build with optimized libraries:
> > >> >  And by PETSC_ARCH=arch-opt, do you mean the
> > >> > non-debugging mode?
> > >> Yes. You can use whatever name you think is appropriate here.
> > >> ./configure PETSC_ARCH=a-name-i-can-easily-associate-with-this-build
> > >> [other configure options.]
> > >> > And I am using the following makefile with my code-
> > >> > CFLAGS =
> > >> > FFLAGS =-I/home/maahi/petsc/include
> > >> > -I/home/maahi/petsc/arch-linux2-c-debug/include -cpp -mcmodel=large
> > >> Hm - you shouldn't be needing these options here. You should switch
> your
> > >> source files from .f to .F and .f90 to .F90 - and remove the above
> FFLAGS
> > >> Satish
> > >> > CPPFLAGS =
> > >> > FPPFLAGS =
> > >> > include ${PETSC_DIR}/lib/petsc/conf/variables
> > >> > include ${PETSC_DIR}/lib/petsc/conf/rules
> > >> > wholetest1: wholetest1.o
> > >> > -${FLINKER} -o wholetest1 wholetest1.o ${PETSC_LIB}
> > >> > ${RM} wholetest1.o
> > >> > So where do I add that PETSC_ARCH?
> > >> > Thanks,
> > >> > Maahi Talukder
> > >> > On Thu, Mar 21, 2019 at 10:14 PM Balay, Satish <balay at mcs.anl.gov>
> > >> wrote:
> > >> > > PETSc uses the concept of PETSC_ARCH to enable multiple in-place
> > >> > > builds.
> > >> > > So you can have a debug build with PETSC_ARCH=arch-debug, and a
> > >> > > optimized build with PETSC_ARCH=arch-opt etc.
> > >> > > And if you are using a petsc formatted makefile with your code -
> you
> > >> > > can switch between these builds by just switching PETSC_ARCH.
> > >> > > Satish
> > >> > > > Dear All,
> > >> > > > Currently, I am running PETSc with debugging option. And it says
> > >> that if
> > >> > > I
> > >> > > > run ./configure --with-debugging=no, the performance would be
> > >> faster. My
> > >> > > > question is: what would I do if I want to go back to debugging
> > >> mode, and
> > >> > > If
> > >> > > > I configure it now with no debugging option, would it make any
> > >> changes to
> > >> > > > my current setting?
> > >> > > > Regards,
> > >> > > > Maahi Talukder
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190323/7083b4ce/attachment.html>
