[petsc-users] About Configuring PETSc
Maahi Talukder
maahi.buet at gmail.com
Fri Mar 22 14:07:07 CDT 2019
I tried to run the command 'make PETSC_ARCH=arch-opt wholetest1' but it
shows me the following error-
[maahi at CB272PP-THINK1 Desktop]$ make PETSC_ARCH=arch-opt wholetest1
/home/maahi/petsc/lib/petsc/conf/rules:960:
*/home/maahi/petsc/arch-opt/lib/petsc/conf/petscrules:
No such file or directory*
make: *** No rule to make target
'/home/maahi/petsc/arch-opt/lib/petsc/conf/petscrules'. Stop.
My .bashrc is the following -
PATH=$PATH:$HOME/.local/bin:$HOME/bin:/usr/lib64/openmpi/bin
export PATH
export PETSC_DIR=$HOME/petsc
export PETSC_ARCH=arch-linux2-c-debug
#export PETSC_ARCH=arch-debug
Could you please tell me what went wrong?
Maahi Talukder
On Thu, Mar 21, 2019 at 11:55 PM Maahi Talukder <maahi.buet at gmail.com>
wrote:
> Thank you so much for your reply. That clear things up!
> On Thu, Mar 21, 2019 at 10:43 PM Balay, Satish <balay at mcs.anl.gov> wrote:
>> On Thu, 21 Mar 2019, Maahi Talukder via petsc-users wrote:
>> > Thank you for your reply.
>> > So do I need to set the value of PETSC_ARCH as needed in .bashrc as I
>> did
>> > in case of PETSC_DIR ?
>> You can specify PETSC_ARCH as an option to make. You can have a default
>> value set in .bashrc - and change to a different value on command line.
>> For ex: in .bashrc
>> Now if you want to build with debug libraries:
>> make wholetest1
>> Now If you want to build with optimized libraries:
>> > And by PETSC_ARCH=arch-opt, do you mean the
>> > non-debugging mode?
>> Yes. You can use whatever name you think is appropriate here.
>> ./configure PETSC_ARCH=a-name-i-can-easily-associate-with-this-build
>> [other configure options.]
>> > And I am using the following makefile with my code-
>> > CFLAGS =
>> > FFLAGS =-I/home/maahi/petsc/include
>> > -I/home/maahi/petsc/arch-linux2-c-debug/include -cpp -mcmodel=large
>> Hm - you shouldn't be needing these options here. You should switch your
>> source files from .f to .F and .f90 to .F90 - and remove the above FFLAGS
>> Satish
>> > CPPFLAGS =
>> > FPPFLAGS =
>> > include ${PETSC_DIR}/lib/petsc/conf/variables
>> > include ${PETSC_DIR}/lib/petsc/conf/rules
>> > wholetest1: wholetest1.o
>> > -${FLINKER} -o wholetest1 wholetest1.o ${PETSC_LIB}
>> > ${RM} wholetest1.o
>> > So where do I add that PETSC_ARCH?
>> > Thanks,
>> > Maahi Talukder
>> > On Thu, Mar 21, 2019 at 10:14 PM Balay, Satish <balay at mcs.anl.gov>
>> wrote:
>> > > PETSc uses the concept of PETSC_ARCH to enable multiple in-place
>> > > builds.
>> > > So you can have a debug build with PETSC_ARCH=arch-debug, and a
>> > > optimized build with PETSC_ARCH=arch-opt etc.
>> > > And if you are using a petsc formatted makefile with your code - you
>> > > can switch between these builds by just switching PETSC_ARCH.
>> > > Satish
>> > > > Dear All,
>> > > > Currently, I am running PETSc with debugging option. And it says
>> that if
>> > > I
>> > > > run ./configure --with-debugging=no, the performance would be
>> faster. My
>> > > > question is: what would I do if I want to go back to debugging
>> mode, and
>> > > If
>> > > > I configure it now with no debugging option, would it make any
>> changes to
>> > > > my current setting?
>> > > > Regards,
>> > > > Maahi Talukder
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190322/8fc079e7/attachment.html>
