[petsc-users] Valgrind Issue With Ghosted Vectors
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Mar 21 11:38:34 CDT 2019
Il giorno mer 20 mar 2019 alle ore 23:40 Derek Gaston via petsc-users <
petsc-users at mcs.anl.gov> ha scritto:
> Trying to track down some memory corruption I'm seeing on larger scale
> runs (3.5B+ unknowns).
Uhm.... are you using 32bit indices? is it possible there's integer
overflow somewhere?
> Was able to run Valgrind on it... and I'm seeing quite a lot of
> uninitialized value errors coming from ghost updating.  Here are some of
> the traces:
> ==87695== Conditional jump or move depends on uninitialised value(s)
> ==87695==    at 0x73236D3: PetscMallocAlign (mal.c:28)
> ==87695==    by 0x7323C70: PetscMallocA (mal.c:390)
> ==87695==    by 0x739048E: VecScatterMemcpyPlanCreate_Index (vscat.c:284)
> ==87695==    by 0x73A5D97: VecScatterMemcpyPlanCreate_PtoP
> (vpscat_mpi1.c:312)
> ==64730==    by 0x7393E8A: VecScatterSetUp_vectype_private (vscat.c:857)
> ==64730==    by 0x7395E5D: VecScatterSetUp_MPI1 (vpscat_mpi1.c:2543)
> ==64730==    by 0x73DDD39: VecScatterSetUp (vscatfce.c:212)
> ==64730==    by 0x73DCD73: VecScatterCreateWithData (vscreate.c:333)
> ==64730==    by 0x7444232: VecCreateGhostWithArray (pbvec.c:685)
> ==64730==    by 0x744490D: VecCreateGhost (pbvec.c:741)
> ==133582== Conditional jump or move depends on uninitialised value(s)
> ==133582==    at 0x4030384: memcpy@@GLIBC_2.14 (vg_replace_strmem.c:1034)
> ==133582==    by 0x739E4F9: PetscMemcpy (petscsys.h:1649)
> ==133582==    by 0x739E4F9: VecScatterMemcpyPlanExecute_Pack
> (vecscatterimpl.h:150)
> ==133582==    by 0x739E4F9: VecScatterBeginMPI1_1 (vpscat_mpi1.h:69)
> ==133582==    by 0x73DD964: VecScatterBegin (vscatfce.c:110)
> ==133582==    by 0x744E195: VecGhostUpdateBegin (commonmpvec.c:225)
> This is from a Git checkout of PETSc... the hash I branched from is:
> 0e667e8fea4aa from December 23rd (updating would be really hard at this
> point as I've completed 90% of my dissertation with this version... and
> changing PETSc now would be pretty painful!).
> Any ideas?  Is it possible it's in my code?  Is it possible that there are
> later PETSc commits that already fix this?
> Thanks for any help,
> Derek
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190321/14afbffd/attachment-0001.html>
