[petsc-users] SLEPc Build Error
Eda Oktay
eda.oktay at metu.edu.tr
Tue Mar 19 07:02:46 CDT 2019
Without slepc, I configured petsc succesfully. Then I installed slepc with
following steps:
export PETSC_ARCH=arch-linux2-c-debug
export PETSC_DIR=/home/slurm_local/e200781/petsc-3.10.4
export SLEPC_DIR=/home/slurm_local/e200781/slepc-3.10.2
cd slepc-3.10.2
./configure
However, I still get the error:
Checking environment... done
Checking PETSc installation...
ERROR: Unable to link with PETSc
ERROR: See "arch-linux2-c-debug/lib/slepc/conf/configure.log" file for
details
Where the configure.log is:
Starting Configure Run at Tue Mar 19 14:57:21 2019
Configure Options:
Working directory: /home/slurm_local/e200781/slepc-3.10.2
Python version:
2.7.9 (default, Sep 25 2018, 20:42:16)
[GCC 4.9.2]
make: /usr/bin/make
PETSc source directory: /home/slurm_local/e200781/petsc-3.10.4
PETSc install directory:
/home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug
PETSc version: 3.10.4
PETSc architecture: arch-linux2-c-debug
SLEPc source directory: /home/slurm_local/e200781/slepc-3.10.2
SLEPc version: 3.10.2
#include "petscsnes.h"
int main() {
Vec v; Mat m; KSP k;
PetscInitializeNoArguments();
VecCreate(PETSC_COMM_WORLD,&v);
MatCreate(PETSC_COMM_WORLD,&m);
KSPCreate(PETSC_COMM_WORLD,&k);
return 0;
/home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/bin/mpicc -o
checklink.o -c -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g3
-I/home/slurm_local/e200781/petsc-3.10.4/include
-I/home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/include
`pwd`/checklink.c
/home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/bin/mpicc -fPIC
-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-fstack-protector -fvisibility=hidden -g3 -o checklink checklink.o
-Wl,-rpath,/home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/lib
-L/home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/lib
-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.9
-L/usr/lib/gcc/x86_64-linux-gnu/4.9 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
-L/lib/x86_64-linux-gnu -lpetsc -lopenblas -lparmetis -lmetis -lm -lX11
-lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi
-lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
/usr/bin/ld: warning: libmpi.so.0, needed by
/home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/lib/libopenblas.so,
may conflict with libmpi.so.40
/home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/lib/libpetsc.so:
undefined reference to `MatPartitioningParmetisSetRepartition'
undefined reference to `MatPartitioningCreate_Parmetis'
collect2: error: ld returned 1 exit status
makefile:2: recipe for target 'checklink' failed
make: *** [checklink] Error 1
Jose E. Roman <jroman at dsic.upv.es>, 19 Mar 2019 Sal, 14:08 tarihinde şunu
yazdı:
> There seems to be a link problem with PETSc.
> Suggest re-configuring without the option --download-slepc
> Then, after building PETSc, try 'make check' to make sure that PETSc is
> built correctly. Then install SLEPc afterwards.
> Jose
> > El 19 mar 2019, a las 11:58, Eda Oktay <eda.oktay at metu.edu.tr> escribió:
> > Starting Configure Run at Tue Mar 19 11:53:05 2019
> > Configure Options:
> --prefix=/home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug
> > Working directory:
> /home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/externalpackages/git.slepc
> > Python version:
> > [GCC 4.9.2]
> > make: /usr/bin/make
> > SLEPc install directory:
> > SLEPc version: 3.10.1
> > int main() {
> > return 0;
> > make[2]: Entering directory '/tmp/slepc-2F1MtJ'
> `pwd`/checklink.c
> -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
> > make[2]: *** [checklink] Error 1
> > make[2]: Leaving directory '/tmp/slepc-2F1MtJ'
> > Jose E. Roman <jroman at dsic.upv.es>, 19 Mar 2019 Sal, 13:49 tarihinde
> şunu yazdı:
> > Correction: the correct path is
> $PETSC_DIR/$PETSC_ARCH/externalpackages/git.slepc/$PETSC_ARCH/lib/slepc/conf/configure.log
> > > El 19 mar 2019, a las 11:46, Jose E. Roman via petsc-users <
> petsc-users at mcs.anl.gov> escribió:
> > > And what is in
> $SLEPC_DIR/arch-linux2-c-debug/lib/slepc/conf/configure.log ?
> > > Jose
> > >> El 19 mar 2019, a las 11:41, Eda Oktay via petsc-users <
> > >> This is slepc.log:
> for details
> > >> Matthew Knepley <knepley at gmail.com>, 19 Mar 2019 Sal, 13:36
> tarihinde şunu yazdı:
> > >> On Tue, Mar 19, 2019 at 6:31 AM Eda Oktay via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > >> Hello,
> > >> I am trying to install PETSc with following configure options:
> > >> ./configure --download-openmpi --download-openblas --download-slepc
> --download-cmake --download-metis --download-parmetis
> > >> Compilation is done but after the following command, I got an error:
> > >> make PETSC_DIR=/home/slurm_local/e200781/petsc-3.10.4
> PETSC_ARCH=arch-linux2-c-debug all
> > >> *** Building slepc ***
> > >> **************************ERROR*************************************
> > >> Error building slepc. Check
> arch-linux2-c-debug/lib/petsc/conf/slepc.log
> > >> We need slepc.log
> > >> Thanks,
> > >> Matt
> /home/slurm_local/e200781/petsc-3.10.4/arch-linux2-c-debug/lib/petsc/conf/petscrules:46:
> recipe for target 'slepcbuild' failed
> > >> make[1]: *** [slepcbuild] Error 1
> > >> make[1]: Leaving directory '/home/slurm_local/e200781/petsc-3.10.4'
> > >> Error during compile, check
> arch-linux2-c-debug/lib/petsc/conf/make.log
> > >> Send it and arch-linux2-c-debug/lib/petsc/conf/configure.log to
> petsc-maint at mcs.anl.gov
> > >> makefile:30: recipe for target 'all' failed
> > >> make: *** [all] Error 1
> > >> How can I fix the problem?
> > >> Thank you,
> > >> Eda
> > >> What most experimenters take for granted before they begin their
> experiments lead.
> > >> -- Norbert Wiener
> > >> https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190319/9c00344a/attachment.html>
