[petsc-users] Confusing Schur preconditioner behaviour
Dave May dave.mayhem23 at gmail.com
Tue Mar 19 06:25:11 CDT 2019
Hi Colin,
On Tue, 19 Mar 2019 at 09:33, Cotter, Colin J <colin.cotter at imperial.ac.uk>
wrote:
> Hi Dave,
> >If you are doing that, then you need to tell fieldsplit to use the Amat
> to define the splits otherwise it will define the Schur compliment as
> >S = B22 - B21 inv(B11) B12
> >preconditiones with B22, where as what you want is
> >S = A22 - A21 inv(A11) A12
> >preconditioned with B22.
> >If your operators are set up this way and you didn't indicate to use Amat
> to define S this would definitely explain why preonly works but iterating
> on Schur does not.
> Yes, thanks - this solves it! I need pc_use_amat.
Okay great. But doesn't that option eradicate your custom Schur complement
object which you inserted into the Bmat in the (2,2) slot?
I thought you would use the option
-pc_fieldsplit_diag_use_amat
In general for fieldsplit (Schur) I found that the best way to manage user
defined Schur complement preconditioners is via PCFieldSplitSetSchurPre().
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetSchurPre.html#PCFieldSplitSetSchurPre
Also, for solver debugging purposes with fieldsplit and MatNest, I find it
incredibly useful to attach textual names to all the matrices going to into
FieldSplit. You can use PetscObjectSetName() with each of your sub-matrices
in the Amat and the Bmat, and any schur complement operators. The textual
names will be displayed in KSP view. In that way you have a better chance
of understanding which operators are being used where. (Note that this
trick is less useful with the Amat and Bmat are AIJ matrices).
Below is an example KSPView associated with 2x2 block system where I've
attached the names Auu,Aup,Apu,App, and S* to the Amat sub-matices and the
schur complement preconditioner.
PC Object:(dcy_) 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization FULL
    Preconditioner for the Schur complement formed from Sp, an assembled
approximation to S, which uses (lumped, if requested) A00's diagonal's
inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (dcy_fieldsplit_u_)       1 MPI processes
        type: preonly
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        left preconditioning
        using NONE norm type for convergence test
      PC Object:      (dcy_fieldsplit_u_)       1 MPI processes
        type: lu
          LU: out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          matrix ordering: nd
          factor fill ratio given 0., needed 0.
            Factored matrix follows:
              Mat Object:               1 MPI processes
                type: seqaij
                rows=85728, cols=85728
                package used to perform factorization: umfpack
                total: nonzeros=0, allocated nonzeros=0
                total number of mallocs used during MatSetValues calls =0
                  not using I-node routines
                  UMFPACK run parameters:
                    Control[UMFPACK_PRL]: 1.
                    Control[UMFPACK_STRATEGY]: 0.
                    Control[UMFPACK_DENSE_COL]: 0.2
                    Control[UMFPACK_DENSE_ROW]: 0.2
                    Control[UMFPACK_AMD_DENSE]: 10.
                    Control[UMFPACK_BLOCK_SIZE]: 32.
                    Control[UMFPACK_FIXQ]: 0.
                    Control[UMFPACK_AGGRESSIVE]: 1.
                    Control[UMFPACK_PIVOT_TOLERANCE]: 0.1
                    Control[UMFPACK_SYM_PIVOT_TOLERANCE]: 0.001
                    Control[UMFPACK_SCALE]: 1.
                    Control[UMFPACK_ALLOC_INIT]: 0.7
                    Control[UMFPACK_DROPTOL]: 0.
                    Control[UMFPACK_IRSTEP]: 0.
                    Control[UMFPACK_ORDERING]: AMD (not using the PETSc
ordering)
        linear system matrix = precond matrix:
        Mat Object:        Auu        (dcy_fieldsplit_u_)         1 MPI
processes
          type: seqaij
          total: nonzeros=1028736, allocated nonzeros=1028736
            using I-node routines: found 21432 nodes, limit used is 5
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (dcy_fieldsplit_p_)       1 MPI processes
        type: fgmres
          GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
          GMRES: happy breakdown tolerance 1e-30
        maximum iterations=300, initial guess is zero
        tolerances:  relative=0.01, absolute=1e-50, divergence=10000.
        right preconditioning
        using UNPRECONDITIONED norm type for convergence test
      PC Object:      (dcy_fieldsplit_p_)       1 MPI processes
        type: lu
          matrix ordering: nd
                type: seqaij
                rows=32542, cols=32542
ordering)
        linear system matrix followed by preconditioner matrix:
        Mat Object:        (dcy_fieldsplit_p_)         1 MPI processes
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
              Mat Object:              App              (dcy_fieldsplit_p_)
            1 MPI processes
                type: seqaij
                total: nonzeros=548482, allocated nonzeros=548482
            A10
              Mat Object:              Apu               1 MPI processes
                type: seqaij
                rows=32542, cols=85728
                total: nonzeros=857280, allocated nonzeros=921990
            KSP of A00
MPI processes
                type: preonly
divergence=10000.
MPI processes
                type: lu
                  matrix ordering: nd
                        type: seqaij
calls =0
PETSc ordering)
                Mat Object:                Auu
(dcy_fieldsplit_u_)
                1 MPI processes
                  type: seqaij
5
            A01
              Mat Object:              Aup               1 MPI processes
                type: seqaij
                rows=85728, cols=32542
                total: nonzeros=857280, allocated nonzeros=942634
        Mat Object:              S*               1 MPI processes
          type: seqaij
    type: nest
    rows=118270, cols=118270
      has attached null space
      Matrix object:
        type=nest, rows=2, cols=2
        MatNest structure:
        (0,0) : name="Auu", prefix="dcy_fieldsplit_u_", type=seqaij,
        (0,1) : name="Aup", type=seqaij, rows=85728, cols=32542
        (1,0) : name="Apu", type=seqaij, rows=32542, cols=85728
        (1,1) : name="App", prefix="dcy_fieldsplit_p_", type=seqaij,
> all the best
> --Colin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190319/790d1cce/attachment-0001.html>
