[petsc-users] PCFieldSplit gives different results for direct and iterative solver
Matthew Knepley
knepley at gmail.com
Tue Mar 19 06:17:43 CDT 2019
On Tue, Mar 19, 2019 at 6:59 AM Y. Shidi via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello Barry,
> Thank you for your reply.
> I reduced the tolerances and get desired solution.
> I am solving a multiphase incompressible n-s problems and currently
> we are using augmented lagrangina technique with uzawa iteration.
> Because the problems are getting larger, we are also looking for some
> other methods for solving the linear system.
> I follow pcfieldsplit tutorial from:
> https://www.mcs.anl.gov/petsc/documentation/tutorials/MSITutorial.pdf
> However, it takes about 10s to finish one iteration and overall
> it requires like 150s to complete one time step with 100k unknowns,
> which is a long time compared to our current solver 10s for one
> time step.
The first thing to do is look at how many Schur complement iterations you
are doing:
-fieldsplit_pressure_ksp_monitor_true_residual
Perhaps you need a better preconditioner for it.
Matt
> I tried the following options:
> 1).
> -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur
> -pc_fieldsplit_schur_factorization_type lower
> -fieldsplit_velocity_ksp_type preonly -fieldsplit_velocity_pc_type gamg
> -fieldsplit_pressure_ksp_type minres -fieldsplit_pressure_pc_type none
> 2).
> -pc_fieldsplit_schur_factorization_type diag
> 3).
> -pc_fieldsplit_schur_factorization_type full
> -fieldsplit_velocity_ksp_type preonly -fieldsplit_velocity_pc_type lu
> -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_pressure_pc_type jacobi
> So I am wondering if there is any other options that can help improve
> the
> pcfieldsplit performance.
> Kind Regards,
> Shidi
> On 2019-03-17 00:05, Smith, Barry F. wrote:
> >> On Mar 16, 2019, at 6:50 PM, Y. Shidi via petsc-users
> >> <petsc-users at mcs.anl.gov> wrote:
> >> Hello,
> >> I am trying to solve the incompressible n-s equations by
> >> PCFieldSplit.
> >> The large matrix and vectors are formed by MatCreateNest()
> >> and VecCreateNest().
> >> The system is solved directly by the following command:
> >> -ksp_type fgmres \
> >> -pc_type fieldsplit \
> >> -pc_fieldsplit_type schur \
> >> -pc_fieldsplit_schur_fact_type full \
> >> -ksp_converged_reason \
> >> -ksp_monitor_true_residual \
> >> -fieldsplit_0_ksp_type preonly \
> >> -fieldsplit_0_pc_type cholesky \
> >> -fieldsplit_0_pc_factor_mat_solver_package mumps \
> >> -mat_mumps_icntl_28 2 \
> >> -mat_mumps_icntl_29 2 \
> >> -fieldsplit_1_ksp_type preonly \
> >> -fieldsplit_1_pc_type jacobi \
> >> Output:
> >> 0 KSP unpreconditioned resid norm 1.214252932161e+04 true resid norm
> >> 1.214252932161e+04 ||r(i)||/||b|| 1.000000000000e+00
> >> 1 KSP unpreconditioned resid norm 1.642782495109e-02 true resid norm
> >> 1.642782495109e-02 ||r(i)||/||b|| 1.352916226594e-06
> >> Linear solve converged due to CONVERGED_RTOL iterations 1
> >> The system is solved iteratively by the following command:
> >> -ksp_type fgmres \
> >> -pc_fieldsplit_schur_factorization_type diag \
> >> -fieldsplit_0_pc_type gamg \
> >> -fieldsplit_1_ksp_type minres \
> >> -fieldsplit_1_pc_type none \
> >> Output:
> >> 1 KSP unpreconditioned resid norm 2.184037364915e+02 true resid norm
> >> 2.184037364915e+02 ||r(i)||/||b|| 1.798667565109e-02
> >> 2 KSP unpreconditioned resid norm 2.120097409539e+02 true resid norm
> >> 2.120097409635e+02 ||r(i)||/||b|| 1.746009709742e-02
> >> 3 KSP unpreconditioned resid norm 4.364091658268e+01 true resid norm
> >> 4.364091658575e+01 ||r(i)||/||b|| 3.594054865332e-03
> >> 4 KSP unpreconditioned resid norm 2.632671796885e+00 true resid norm
> >> 2.632671797020e+00 ||r(i)||/||b|| 2.168141189773e-04
> >> 5 KSP unpreconditioned resid norm 2.209213998004e+00 true resid norm
> >> 2.209213980361e+00 ||r(i)||/||b|| 1.819401808180e-04
> >> 6 KSP unpreconditioned resid norm 4.683775185840e-01 true resid norm
> >> 4.683775085753e-01 ||r(i)||/||b|| 3.857330677735e-05
> >> 7 KSP unpreconditioned resid norm 3.042503284736e-02 true resid norm
> >> 3.042503349258e-02 ||r(i)||/||b|| 2.505658638883e-06
> >> Both methods give answers, but they are different
> > What do you mean the answers are different? Do you mean the
> > solution x from KSPSolve() is different? How are you calculating their
> > difference and how different are they?
> > Since the solutions are only approximate; true residual norm is
> > around 1.642782495109e-02 and 3.042503349258e-02 for the two
> > different solvers there will only be a certain number of identical
> > digits in the two solutions (which depends on the condition number of
> > the original matrix). You can run both solvers with -ksp_rtol 1.e-12
> > and then (assuming everything is working correctly) the two solutions
> > will be much closer to each other.
> > Barry
> >> so I am wondering
> >> if it is possible that you can help me figure out which part I am
> >> doing wrong.
> >> Thank you for your time.
> >> Kind Regards,
> >> Shidi
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190319/1553b4dc/attachment.html>
