[petsc-users] BJACOBI with FIELDSPLIT
Matthew Knepley
knepley at gmail.com
Mon Mar 18 14:57:37 CDT 2019
On Mon, Mar 18, 2019 at 3:18 PM Rossi, Simone via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear all,
> I'm debugging my application in which I'm trying to use the FIELDSPLIT
> preconditioner for solving a 2x2 block matrix.
> Currently I'm testing the preconditioner on a decoupled system where I
> solve two identical and independent Poisson problems. Using the default
> fieldsplit type (multiplicative), I'm expecting the method to be equivalent
> to a Block Jacobi solver.
> Setting
> -ksp_rtol 1e-6
> while using gmres/hypre on each subblock with
> -fieldsplit_0_ksp_rtol 1e-12
> -fieldsplit_1_ksp_rtol 1e-12
> I'm expecting to converge in 1 iteration with a single solve for each
> block.
> Asking to output the iteration count for the subblocks with
> -ksp_converged_reason
> -fieldsplit_0_ksp_converged_reason
> -fieldsplit_1_ksp_converged_reason
> revealed that the outer solver converges in 1 iteration, but each block is
> solved for 3 times.
> This is the output I get:
> Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 7
> Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 7
This first application of the PC is to evaluate the initial preconditioned
residual.
> 0 KSP preconditioned resid norm 9.334948012657e+01 true resid norm
> 1.280164130222e+02 ||r(i)||/||b|| 1.000000000000e+00
This next one is for applying M^{-1} A in the Krylov iteration.
I think this one might be from building the true residual.
Matt
> 1 KSP preconditioned resid norm 1.518151977611e-11 true resid norm
> 8.123270435936e-12 ||r(i)||/||b|| 6.345491366429e-14
> Linear solve converged due to CONVERGED_RTOL iterations 1
> Are the subblocks actually solved for multiple times at every outer
> iteration?
> Thanks for the help,
> Simone
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190318/ad4946a4/attachment-0001.html>
