[petsc-users] BJACOBI with FIELDSPLIT
Rossi, Simone srossi at email.unc.edu
Mon Mar 18 14:56:12 CDT 2019
To follow up on that: when would you want to use gmres instead of fgmres in the outer ksp?
Thanks again for the help,
Simone
Sent: Monday, March 18, 2019 3:43:04 PM
To: Justin Chang
Cc: Smith, Barry F.; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] BJACOBI with FIELDSPLIT
Thanks, using fgmres it does work as expected.
I thought gmres would do the same since I'm solving the subblocks "exactly".
Simone
Sent: Monday, March 18, 2019 3:38:34 PM
To: Rossi, Simone
Use -ksp_type fgmres if your inner ksp solvers are gmres. Maybe that will help?
On Mon, Mar 18, 2019 at 1:33 PM Rossi, Simone via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Thanks Barry.
Let me know if you can spot anything out of the ksp_view
KSP Object: 1 MPI processes
  type: gmres
    restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    happy breakdown tolerance 1e-30
  maximum iterations=5000, nonzero initial guess
  tolerances:  relative=0.001, absolute=1e-50, divergence=10000.
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with MULTIPLICATIVE composition: total splits = 2, blocksize = 2
    Solver info for each split is in the following KSP objects:
    Split number 0 Fields  0
    KSP Object: (fieldsplit_0_) 1 MPI processes
      type: gmres
      maximum iterations=10000, initial guess is zero
      tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
    PC Object: (fieldsplit_0_) 1 MPI processes
      type: hypre
        HYPRE BoomerAMG preconditioning
          Cycle type V
          Maximum number of levels 25
          Maximum number of iterations PER hypre call 1
          Convergence tolerance PER hypre call 0.
          Threshold for strong coupling 0.25
          Interpolation truncation factor 0.
          Interpolation: max elements per row 0
          Number of levels of aggressive coarsening 0
          Number of paths for aggressive coarsening 1
          Maximum row sums 0.9
          Sweeps down         1
          Sweeps up           1
          Sweeps on coarse    1
          Relax down          symmetric-SOR/Jacobi
          Relax up            symmetric-SOR/Jacobi
          Relax on coarse     Gaussian-elimination
          Relax weight  (all)      1.
          Outer relax weight (all) 1.
          Using CF-relaxation
          Not using more complex smoothers.
          Measure type        local
          Coarsen type        Falgout
          Interpolation type  classical
      linear system matrix = precond matrix:
      Mat Object: (fieldsplit_0_) 1 MPI processes
        type: seqaij
        rows=35937, cols=35937
        total: nonzeros=912673, allocated nonzeros=912673
        total number of mallocs used during MatSetValues calls =0
          not using I-node routines
    Split number 1 Fields  1
    KSP Object: (fieldsplit_1_) 1 MPI processes
      type: gmres
    PC Object: (fieldsplit_1_) 1 MPI processes
      type: hypre
          Cycle type V
          Sweeps down         1
          Sweeps up           1
          Sweeps on coarse    1
          Using CF-relaxation
          Measure type        local
      Mat Object: (fieldsplit_1_) 1 MPI processes
        type: seqaij
  Mat Object: () 1 MPI processes
    type: seqaij
    rows=71874, cols=71874
    total: nonzeros=3650692, allocated nonzeros=3650692
      using I-node routines: found 35937 nodes, limit used is 5
From: Smith, Barry F. <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>>
Sent: Monday, March 18, 2019 3:27:13 PM
To: Rossi, Simone
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
 Simone,
    This is indeed surprising, given the block structure of the matrix and the exact block solves we'd expect the solver to converge after the application of the preconditioner. Please send the output of -ksp_view
   Barry
Also if you are willing to share your test code we can try running it to determine why it doesn't converge immediately.
> On Mar 18, 2019, at 2:14 PM, Rossi, Simone via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> Dear all,
> I'm debugging my application in which I'm trying to use the FIELDSPLIT preconditioner for solving a 2x2 block matrix.
> Currently I'm testing the preconditioner on a decoupled system where I solve two identical and independent Poisson problems. Using the default fieldsplit type (multiplicative), I'm expecting the method to be equivalent to a Block Jacobi solver.
> Setting
> -ksp_rtol 1e-6
> while  using gmres/hypre on each subblock with
> -fieldsplit_0_ksp_rtol 1e-12
> -fieldsplit_1_ksp_rtol 1e-12
> I'm expecting to converge in 1 iteration with a single solve for each block.
> Asking to output the iteration count for the subblocks with
> -ksp_converged_reason
> -fieldsplit_0_ksp_converged_reason
> -fieldsplit_1_ksp_converged_reason
> revealed that the outer solver converges in 1 iteration, but each block is solved for 3 times.
> This is the output I get:
>   Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 7
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 7
>   0 KSP preconditioned resid norm 9.334948012657e+01 true resid norm 1.280164130222e+02 ||r(i)||/||b|| 1.000000000000e+00
>   1 KSP preconditioned resid norm 1.518151977611e-11 true resid norm 8.123270435936e-12 ||r(i)||/||b|| 6.345491366429e-14
> Linear solve converged due to CONVERGED_RTOL iterations 1
> Are the subblocks actually solved for multiple times at every outer iteration?
> Thanks for the help,
> Simone
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190318/f8b81205/attachment.html>
