[petsc-users] BJACOBI with FIELDSPLIT
Rossi, Simone
srossi at email.unc.edu
Mon Mar 18 14:33:35 CDT 2019
Thanks Barry.
Let me know if you can spot anything out of the ksp_view
KSP Object: 1 MPI processes
type: gmres
restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
happy breakdown tolerance 1e-30
maximum iterations=5000, nonzero initial guess
tolerances: relative=0.001, absolute=1e-50, divergence=10000.
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
type: fieldsplit
FieldSplit with MULTIPLICATIVE composition: total splits = 2, blocksize = 2
Solver info for each split is in the following KSP objects:
Split number 0 Fields 0
KSP Object: (fieldsplit_0_) 1 MPI processes
type: gmres
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-12, absolute=1e-50, divergence=10000.
PC Object: (fieldsplit_0_) 1 MPI processes
type: hypre
HYPRE BoomerAMG preconditioning
Cycle type V
Maximum number of levels 25
Maximum number of iterations PER hypre call 1
Convergence tolerance PER hypre call 0.
Threshold for strong coupling 0.25
Interpolation truncation factor 0.
Interpolation: max elements per row 0
Number of levels of aggressive coarsening 0
Number of paths for aggressive coarsening 1
Maximum row sums 0.9
Sweeps down 1
Sweeps up 1
Sweeps on coarse 1
Relax down symmetric-SOR/Jacobi
Relax up symmetric-SOR/Jacobi
Relax on coarse Gaussian-elimination
Relax weight (all) 1.
Outer relax weight (all) 1.
Using CF-relaxation
Not using more complex smoothers.
Measure type local
Coarsen type Falgout
Interpolation type classical
linear system matrix = precond matrix:
Mat Object: (fieldsplit_0_) 1 MPI processes
type: seqaij
rows=35937, cols=35937
total: nonzeros=912673, allocated nonzeros=912673
total number of mallocs used during MatSetValues calls =0
not using I-node routines
Split number 1 Fields 1
KSP Object: (fieldsplit_1_) 1 MPI processes
type: gmres
PC Object: (fieldsplit_1_) 1 MPI processes
type: hypre
Cycle type V
Sweeps down 1
Sweeps up 1
Sweeps on coarse 1
Using CF-relaxation
Measure type local
Mat Object: (fieldsplit_1_) 1 MPI processes
type: seqaij
Mat Object: () 1 MPI processes
type: seqaij
rows=71874, cols=71874
total: nonzeros=3650692, allocated nonzeros=3650692
using I-node routines: found 35937 nodes, limit used is 5
Sent: Monday, March 18, 2019 3:27:13 PM
To: Rossi, Simone
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] BJACOBI with FIELDSPLIT
Simone,
This is indeed surprising, given the block structure of the matrix and the exact block solves we'd expect the solver to converge after the application of the preconditioner. Please send the output of -ksp_view
Barry
Also if you are willing to share your test code we can try running it to determine why it doesn't converge immediately.
> On Mar 18, 2019, at 2:14 PM, Rossi, Simone via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Dear all,
> I'm debugging my application in which I'm trying to use the FIELDSPLIT preconditioner for solving a 2x2 block matrix.
> Currently I'm testing the preconditioner on a decoupled system where I solve two identical and independent Poisson problems. Using the default fieldsplit type (multiplicative), I'm expecting the method to be equivalent to a Block Jacobi solver.
> Setting
> -ksp_rtol 1e-6
> while using gmres/hypre on each subblock with
> -fieldsplit_0_ksp_rtol 1e-12
> -fieldsplit_1_ksp_rtol 1e-12
> I'm expecting to converge in 1 iteration with a single solve for each block.
> Asking to output the iteration count for the subblocks with
> -ksp_converged_reason
> -fieldsplit_0_ksp_converged_reason
> -fieldsplit_1_ksp_converged_reason
> revealed that the outer solver converges in 1 iteration, but each block is solved for 3 times.
> This is the output I get:
> Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 7
> Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 7
> 0 KSP preconditioned resid norm 9.334948012657e+01 true resid norm 1.280164130222e+02 ||r(i)||/||b|| 1.000000000000e+00
> 1 KSP preconditioned resid norm 1.518151977611e-11 true resid norm 8.123270435936e-12 ||r(i)||/||b|| 6.345491366429e-14
> Linear solve converged due to CONVERGED_RTOL iterations 1
> Are the subblocks actually solved for multiple times at every outer iteration?
> Thanks for the help,
> Simone
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190318/43d65d5d/attachment-0001.html>
