[petsc-users] BJACOBI with FIELDSPLIT
Rossi, Simone
srossi at email.unc.edu
Mon Mar 18 14:14:55 CDT 2019
Dear all,
I'm debugging my application in which I'm trying to use the FIELDSPLIT preconditioner for solving a 2x2 block matrix.
Currently I'm testing the preconditioner on a decoupled system where I solve two identical and independent Poisson problems. Using the default fieldsplit type (multiplicative), I'm expecting the method to be equivalent to a Block Jacobi solver.
Setting
-ksp_rtol 1e-6
while using gmres/hypre on each subblock with
-fieldsplit_0_ksp_rtol 1e-12
-fieldsplit_1_ksp_rtol 1e-12
I'm expecting to converge in 1 iteration with a single solve for each block.
Asking to output the iteration count for the subblocks with
-ksp_converged_reason
-fieldsplit_0_ksp_converged_reason
-fieldsplit_1_ksp_converged_reason
revealed that the outer solver converges in 1 iteration, but each block is solved for 3 times.
This is the output I get:
Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 7
Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 7
0 KSP preconditioned resid norm 9.334948012657e+01 true resid norm 1.280164130222e+02 ||r(i)||/||b|| 1.000000000000e+00
1 KSP preconditioned resid norm 1.518151977611e-11 true resid norm 8.123270435936e-12 ||r(i)||/||b|| 6.345491366429e-14
Linear solve converged due to CONVERGED_RTOL iterations 1
Are the subblocks actually solved for multiple times at every outer iteration?
Thanks for the help,
Simone
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190318/ab60c88e/attachment.html>
