[petsc-users] Using PETSc with GPU
Yuyun Yang yyang85 at stanford.edu
Fri Mar 15 16:29:58 CDT 2019
Hello team,
Our group is thinking of using GPUs for the linear solves in our code, which is written in PETSc. I was reading the 2013 book chapter on implementation of PETSc using GPUs but wonder if there is any more updated reference that I check out? I also saw one example cuda code online (using thrust), but would like to check with you if there is a more complete documentation of how the GPU implementation is done?
Thanks very much!
Best regards,
Yuyun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190315/f743d04e/attachment.html>
