[petsc-users] Cross-compilation cluster
Amneet Bhalla
mail2amneet at gmail.com
Thu Mar 14 07:46:33 CDT 2019
Ah, Ok. Do serial compilers look OK to you?
Can lib-32 and lib-64 (say -lm) operate simulataneously during runtime, or
this is my imagination?
On Thu, Mar 14, 2019 at 5:36 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 14, 2019 at 8:28 AM Amneet Bhalla <mail2amneet at gmail.com>
> wrote:
>> Matt -- SAMRAI, PETSc, and libMesh configure logs are attached with this
>> email. Also including some other log files in case they are useful.
> Okay, PETSc is not sticking in a /usr/lib (or /usr/lib64). However, I can
> see that you mpif90 (and perhaps other of the wrappers) are
> reporting both /usr/lib64 AND /usr/lib flags, and I am guessing that is
> where the other configures are picking it up.
> Thanks,
> Matt
>> Thanks,
>> --Amneet
>> On Thu, Mar 14, 2019 at 4:21 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> In order to see why each flag was included, we need to see configure.log.
>>> Thanks,
>>> Matt
>>> On Thu, Mar 14, 2019 at 2:40 AM Amneet Bhalla via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>>> Hi Folks,
>>>> I am on a cluster that has -L/lib dir with 32-bit libraries and
>>>> -L/lib64 with 64-bit libraries. During compilation of some of
>>>> libraries required for my code (such as SAMRAI and libMesh) both paths
>>>> get picked -L/lib and -L/lib64.
>>>> I am seeing some sporadic behavior in runtime when at some timesteps
>>>> PETSc does not converge. The same code with the same number of processors
>>>> run just fine on my workstation that has just 64-bit version of libraries.
>>>> Even during the final linking stage of the executable, the linker gives
>>>> warnings like
>>>> ld: skipping incompatible //lib/libm.so when searching for -lm
>>>> ld: skipping incompatible /lib/libm.so when searching for -lm
>>>> ld: skipping incompatible //lib/libpthread.so when searching for
>>>> -lpthread
>>>> ld: skipping incompatible /lib/libpthread.so when searching for
>>>> -lpthread
>>>> -lpthread
>>>> ld: skipping incompatible //lib/libdl.so when searching for -ldl
>>>> ld: skipping incompatible //lib/libc.so when searching for -lc
>>>> ld: skipping incompatible /lib/libc.so when searching for -lc
>>>> but the executable runs.
>>>> This is during config of SAMRAI when it picks both -L/lib and -L/lib64:
>>>> checking whether we are using the GNU Fortran 77 compiler... no
>>>> checking whether ifort accepts -g... yes
>>>> checking how to get verbose linking output from ifort... -v
>>>> checking for Fortran 77 libraries of ifort...
>>>> -L/opt/intel/compilers_and_libraries_2018.2.199/linux/tbb/lib/intel64/gcc4.4
>>>> -L/opt/intel/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64
>>>> -L/opt/intel/compilers_and_libraries_2018.2.199/linux/compiler/lib/intel64
>>>> -L/opt/intel/compilers_and_libraries_2018.2.199/linux/ipp/lib/intel64
>>>> -L/opt/intel/compilers_and_libraries_2018.2.199/linux/compiler/lib/intel64_lin
>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/
>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64
>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/ -L/lib/../lib64
>>>> -L/lib/../lib64/ -L/usr/lib/../lib64 -L/usr/lib/../lib64/
>>>> -L/opt/intel/compilers_and_libraries_2018.2.199/linux/tbb/lib/intel64/gcc4.4/
>>>> -L/opt/intel/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64/
>>>> -L/opt/intel/compilers_and_libraries_2018.2.199/linux/compiler/lib/intel64/
>>>> -L/opt/intel/compilers_and_libraries_2018.2.199/linux/ipp/lib/intel64/
>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../ -L/lib64 -L/lib/
>>>> -L/usr/lib64 -L/usr/lib -lifport -lifcoremt -limf -lsvml -lm -lipgo -lirc
>>>> -lpthread -lgcc -lgcc_s -lirc_s -ldl
>>>> libMesh is also picking that path
>>>> libmesh_optional_LIBS............ : -lhdf5 -lhdf5_cpp -lz
>>>> -L/home/asbhalla/softwares/PETSc-BitBucket/PETSc/linux-opt/lib
>>>> -Wl,-rpath,/home/asbhalla/softwares/PETSc-BitBucket/PETSc/linux-opt/lib
>>>> -Wl,-rpath,/opt/intel/mkl/lib/intel64 -L/opt/intel/mkl/lib/intel64
>>>> -Wl,-rpath,/opt/mellanox/hcoll/lib -L/opt/mellanox/hcoll/lib
>>>> -Wl,-rpath,/opt/mellanox/mxm/lib -L/opt/mellanox/mxm/lib
>>>> -Wl,-rpath,/opt/intel/compilers_and_libraries_2018.2.199/linux/tbb/lib/intel64/gcc4.4
>>>> -Wl,-rpath,/opt/intel/compilers_and_libraries_2018.2.199/linux/mkl/lib/intel64
>>>> -Wl,-rpath,/opt/intel/compilers_and_libraries_2018.2.199/linux/compiler/lib/intel64
>>>> -Wl,-rpath,/opt/intel/compilers_and_libraries_2018.2.199/linux/ipp/lib/intel64
>>>> -Wl,-rpath,/opt/intel/compilers_and_libraries_2018.2.199/linux/compiler/lib/intel64_lin
>>>> -lpetsc -lHYPRE -lmkl_intel_lp64 -lmkl_sequential -lmkl_core
>>>> -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lifport
>>>> -lifcoremt_pic -limf -lsvml -lm -lipgo -lirc -lpthread -lgcc_s -lirc_s
>>>> -lstdc++ -ldl -L/lib -Wl,-rpath,/lib
>>>> -Wl,-rpath,/usr/local/mpi/intel/openmpi-4.0.0/lib64
>>>> -L/usr/local/mpi/intel/openmpi-4.0.0/lib64
>>>> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>>> Perhaps PETSc also picks up both versions (and there is a way to query
>>>> it from PETSc?), but I can't confirm this. Is there a way to instruct make
>>>> to select only -L/lib64? I want to rule out that 32-bit dynamic library is
>>>> not a culprit for the random non-convergence of PETSc solvers and the
>>>> eventual crash of the simulations. I have tried both gcc-7.3.0 and intel-18
>>>> compilers -- but the same thing is happening.
>>>> --Amneet
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> --Amneet
> experiments lead.
> -- Norbert Wiener
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190314/c7828e11/attachment-0001.html>
