[petsc-users] Issue when passing DMDA array on to Paraview Catalyst
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Mar 14 00:05:06 CDT 2019
> On Mar 13, 2019, at 11:28 AM, Matthew Knepley via petsc-users <petsc-users at mcs.anl.gov> wrote:
> On Wed, Mar 13, 2019 at 12:16 PM Bastian Löhrer via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Dear PETSc users,
> I am having difficulties passing PETSc data on to Paraview Catalyst and
> it may be related to the way we handle the PETSs data in our Fortran code.
> We have DMDA objects, which we pass on to subroutines this way:
> > call DMCreateLocalVector(da1dof, loc_p, ierr)
> > call VecGetArray(loc_p, loc_p_v, loc_p_i, ierr)
> > call process( loc_p_v(loc_p_i+1) )
> Inside the subroutine (process in this example) we treat the
> subroutine's argument as if it were an ordinary Fortran array:
> > subroutine process( p )
> > use gridinfo ! provides gis, gie, ... etc.
> > implicit none
> > #include "petsc_include.h"
> > PetscScalar, dimension(gis:gie,gjs:gje,gks:gke) :: p
> > PetscInt i,j,k
> > do k = gks, gke
> > do j = gjs, gje
> > do i = gis, gie
> > p(i,j,k) = ...
> > enddo
> > enddo
> > enddo
> > end subroutine process
> I find this procedure a little quirky, but it has been working
> flawlessly for years.
> However, I am now encountering difficulties when passing this
> variable/array p on to a Paraview Catalyst adaptor subroutine. Doing so
> I end up with very strange values there. When replacing p with an
> ordinary local Fortran array everything is fine.
> I can't think of a reason it would not work. I would look at the pointer you get inside
> the Catalyst function using the debugger.
> Note that you can also get an F90 array out if that is what Catalyst needs.
VecGetArrayF90() or DMDAVecGetArrayF90()
> Thanks,
> Matt
> Bastian
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
