[petsc-users] Compiling Fortran Code
Maahi Talukder
maahi.buet at gmail.com
Wed Mar 13 21:13:40 CDT 2019
Thank you so much. Now it works! Thanks again!
On Wed, Mar 13, 2019 at 10:10 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Put the use petscksp starting in column 7 of the file
> > On Mar 13, 2019, at 9:05 PM, Maahi Talukder via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hi,
> > Thank you all for your suggestions. I made the changes as suggested.
> But now I get the following error-
> > [maahi at CB272PP-THINK1 egrid2d]$ make egrid2d
> > /home/maahi/petsc/arch-linux2-c-debug/bin/mpif90 -Wall
> -ffree-line-length-0 -Wno-unused-dummy-argument -g
> -I/home/maahi/petsc/include -I/home/maahi/petsc/arch-linux2-c-debug/include
> -Ofast -fdefault-real-8 -c -I/home/maahi/petsc/include
> -I/home/maahi/petsc/arch-linux2-c-debug/include -Ofast -fdefault-real-8
> main.F -Wl,-rpath,/home/maahi/petsc/arch-linux2-c-debug/lib
> -L/home/maahi/petsc/arch-linux2-c-debug/lib
> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/7
> -L/usr/lib/gcc/x86_64-redhat-linux/7 -lpetsc -lflapack -lfblas -lm
> -lpthread -lstdc++ -ldl -lmpifort -lmpi -lgfortran -lm -lgfortran -lm
> -lgcc_s -lquadmath -lstdc++ -ldl
> > main.F:6:1:
> > use petscksp
> > 1
> > Error: Non-numeric character in statement label at (1)
> > main.F:6:1:
> > use petscksp
> > 1
> > Error: Unclassifiable statement at (1)
> > make: *** [makefile:28: main.o] Error 1
> > Any idea how to fix that?
> > Thanks,
> > Maahi Talukder
> > On Wed, Mar 13, 2019 at 8:44 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > check petsc makefile format - for ex:
> src/tao/unconstrained/examples/tutorials/makefile
> > Also rename your fortran sources that have petsc calls from .f to .F
> > On Wed, 13 Mar 2019, Matthew Knepley via petsc-users wrote:
> > > On Wed, Mar 13, 2019 at 7:36 PM Maahi Talukder via petsc-users <
> > > > Dear All,
> > > > I am trying to compile a Fortran code. The make is as it follows-
> > > > # Makefile for egrid2d
> > > > OBJS = main.o egrid2d.o
> > > > FFLAGS = -I/home/maahi/petsc/include
> -fdefault-real-8
> > > > # link
> > > > include ${PETSC_DIR}/lib/petsc/conf/variables
> > > > include ${PETSC_DIR}/lib/petsc/conf/rules
> > > > egrid2d: $(OBJS)
> > > > ${FLINKER} $(OBJS) -o egrid2d ${PETSC_LIB}
> > > Move this above your includes
> > The location is fine. Can you change OBJS to a different name - say OBJ
> [or something else] and see if that works.
> > Satish
> > > > # compile
> > > > main.o:
> > > > ${FLINKER} -c $(FFLAGS) main.f ${PETSC_LIB}
> > > You should not need this rule.
> > > Thanks,
> > > Matt
> > > > # Common and Parameter Dependencies
> > > > main.o: main.f par2d.f
> > > > egrid2d.o: egrid2d.f par2d.f
> > > > But I get the following error-
> > > > -Ofast -fdefault-real-8 -o egrid2d
> > > > /*usr/lib/gcc/x86_64-redhat-linux/7/../../../../lib64/crt1.o: In
> function
> > > > `_start':*
> > > > *(.text+0x20): undefined reference to `main'*
> > > > collect2: error: ld returned 1 exit status
> > > > make: *** [makefile:18: egrid2d] Error 1
> > > > Any idea how to fix it ?
> > > > Thanks,
> > > > Maahi Talukder
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190313/491c29fe/attachment-0001.html>
