[petsc-users] PCFieldSplit with MatNest
Manuel Colera Rico
m.colera at upm.es
Wed Mar 13 11:04:28 CDT 2019
After adding that line the problem gets fixed.
Manuel
On 3/13/19 3:13 PM, Zhang, Junchao wrote:
> Manuel,
> Could you try to add this line
> sbaij->free_imax_ilen = PETSC_TRUE;
> after line 2431 in
> /opt/PETSc_library/petsc-3.10.4/src/mat/impls/sbaij/seq/sbaij.c
> PS: Matt, this bug looks unrelated to my VecRestoreArrayRead_Nest fix.
> --Junchao Zhang
> On Wed, Mar 13, 2019 at 9:05 AM Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
> On Wed, Mar 13, 2019 at 9:44 AM Manuel Colera Rico via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Yes:
> [ 0]8416 bytes MatCreateSeqSBAIJWithArrays() line 2431 in
> [ 0]4544 bytes MatCreateSeqSBAIJWithArrays() line 2431 in
> Junchao, do imax and ilen get missed in the Destroy with the user
> provides arrays?
> https://bitbucket.org/petsc/petsc/src/06a3e802b3873ffbfd04b71a0821522327dd9b04/src/mat/impls/sbaij/seq/sbaij.c#lines-2431
> Matt
> I have checked that I have destroyed all the MatNest matrices
> and all
> the submatrices individually.
> Manuel
> On 3/13/19 2:28 PM, Jed Brown wrote:
> > Is there any output if you run with -malloc_dump?
> > Manuel Colera Rico via petsc-users <petsc-users at mcs.anl.gov
> <mailto:petsc-users at mcs.anl.gov>> writes:
> >> Hi, Junchao,
> >> I have installed the newest version of PETSc and it works
> fine. I just
> >> get the following memory leak warning:
> >> Direct leak of 28608 byte(s) in 12 object(s) allocated from:
> >> #0 0x7f1ddd5caa38 in __interceptor_memalign
> ../../../../gcc-8.1.0/libsanitizer/asan/asan_malloc_linux.cc:111
> >> #1 0x7f1ddbef1213 in PetscMallocAlign
> (/opt/PETSc_library/petsc-3.10.4/mcr_20190313/lib/libpetsc.so.3.10+0x150213)
> >> Thank you,
> >> Manuel
> >> On 3/12/19 7:08 PM, Zhang, Junchao wrote:
> >>> Hi, Manuel,
> >>> I recently fixed a problem in VecRestoreArrayRead.
> Basically, I
> >>> added VecRestoreArrayRead_Nest. Could you try the master
> branch of
> >>> PETSc to see if it fixes your problem?
> >>> Thanks.
> >>> --Junchao Zhang
> >>> On Mon, Mar 11, 2019 at 6:56 AM Manuel Colera Rico via
> petsc-users
> <mailto:petsc-users at mcs.anl.gov>>> wrote:
> >>> Hello,
> >>> I need to solve a 2*2 block linear system. The
> matrices A_00, A_01,
> >>> A_10, A_11 are constructed separately via
> >>> MatCreateSeqAIJWithArrays and
> >>> MatCreateSeqSBAIJWithArrays. Then, I construct the
> full system matrix
> >>> with MatCreateNest, and use MatNestGetISs and
> PCFieldSplitSetIS to
> >>> set
> >>> up the PC, trying to follow the procedure described here:
> https://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex70.c.html.
> >>> However, when I run the code with Leak Sanitizer, I
> get the
> >>> following error:
> >>> ==54927==ERROR: AddressSanitizer: attempting free on
> address which
> >>> was
> >>> not malloc()-ed: 0x627000051ab8 in thread T0
> >>> #0 0x7fbd95c08f30 in __interceptor_free
> ../../../../gcc-8.1.0/libsanitizer/asan/asan_malloc_linux.cc:66
> >>> #1 0x7fbd92b99dcd in PetscFreeAlign
> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x146dcd)
> >>> #2 0x7fbd92ce0178 in VecRestoreArray_Nest
> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x28d178)
> >>> #3 0x7fbd92cd627d in VecRestoreArrayRead
> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x28327d)
> >>> #4 0x7fbd92d1189e in VecScatterBegin_SSToSS
> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x2be89e)
> >>> #5 0x7fbd92d1a414 in VecScatterBegin
> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x2c7414)
> >>> #6 0x7fbd934a999c in PCApply_FieldSplit
> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xa5699c)
> >>> #7 0x7fbd93369071 in PCApply
> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x916071)
> >>> #8 0x7fbd934efe77 in KSPInitialResidual
> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xa9ce77)
> >>> #9 0x7fbd9350272c in KSPSolve_GMRES
> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xaaf72c)
> >>> #10 0x7fbd934e3c01 in KSPSolve
> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xa90c01)
> >>> Disabling Leak Sanitizer also outputs an "invalid
> pointer" error.
> >>> Did I forget something when writing the code?
> >>> Thank you,
> >>> Manuel
> experiments is infinitely more interesting than any results to
> which their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190313/34766afd/attachment.html>
