[petsc-users] PCFieldSplit with MatNest
Manuel Colera Rico
m.colera at upm.es
Wed Mar 13 08:49:01 CDT 2019
The warning that Leak Sanitizer gives me is not what I wrote two
messages before (I apologize). It is:
Direct leak of 25920 byte(s) in 4 object(s) allocated from:
#0 0x7fa97e35aa38 in __interceptor_memalign
../../../../gcc-8.1.0/libsanitizer/asan/asan_malloc_linux.cc:111
#1 0x7fa97cc81213 in PetscMallocAlign
(/opt/PETSc_library/petsc-3.10.4/mcr_20190313/lib/libpetsc.so.3.10+0x150213)
which seems to be in accordance (at least in number of leaked bytes) to
-malloc_dump's output.
Manuel
On 3/13/19 2:44 PM, Manuel Colera Rico wrote:
> Yes:
> [ 0]8416 bytes MatCreateSeqSBAIJWithArrays() line 2431 in
> /opt/PETSc_library/petsc-3.10.4/src/mat/impls/sbaij/seq/sbaij.c
> [ 0]4544 bytes MatCreateSeqSBAIJWithArrays() line 2431 in
> I have checked that I have destroyed all the MatNest matrices and all
> the submatrices individually.
> Manuel
> On 3/13/19 2:28 PM, Jed Brown wrote:
>> Is there any output if you run with -malloc_dump?
>> Manuel Colera Rico via petsc-users <petsc-users at mcs.anl.gov> writes:
>>> Hi, Junchao,
>>> I have installed the newest version of PETSc and it works fine. I just
>>> get the following memory leak warning:
>>> Direct leak of 28608 byte(s) in 12 object(s) allocated from:
>>> #0 0x7f1ddd5caa38 in __interceptor_memalign
>>> #1 0x7f1ddbef1213 in PetscMallocAlign
>>> Thank you,
>>> Manuel
>>> On 3/12/19 7:08 PM, Zhang, Junchao wrote:
>>>> Hi, Manuel,
>>>> I recently fixed a problem in VecRestoreArrayRead. Basically, I
>>>> added VecRestoreArrayRead_Nest. Could you try the master branch of
>>>> PETSc to see if it fixes your problem?
>>>> Thanks.
>>>> --Junchao Zhang
>>>> On Mon, Mar 11, 2019 at 6:56 AM Manuel Colera Rico via petsc-users
>>>> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>>>> Hello,
>>>> I need to solve a 2*2 block linear system. The matrices A_00,
>>>> A_01,
>>>> A_10, A_11 are constructed separately via
>>>> MatCreateSeqAIJWithArrays and
>>>> MatCreateSeqSBAIJWithArrays. Then, I construct the full system
>>>> matrix
>>>> with MatCreateNest, and use MatNestGetISs and
>>>> PCFieldSplitSetIS to
>>>> set
>>>> up the PC, trying to follow the procedure described here:
>>>> https://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex70.c.html.
>>>> However, when I run the code with Leak Sanitizer, I get the
>>>> following error:
>>>> ==54927==ERROR: AddressSanitizer: attempting free on address
>>>> which
>>>> was
>>>> not malloc()-ed: 0x627000051ab8 in thread T0
>>>> #0 0x7fbd95c08f30 in __interceptor_free
>>>> ../../../../gcc-8.1.0/libsanitizer/asan/asan_malloc_linux.cc:66
>>>> #1 0x7fbd92b99dcd in PetscFreeAlign
>>>> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x146dcd)
>>>> #2 0x7fbd92ce0178 in VecRestoreArray_Nest
>>>> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x28d178)
>>>> #3 0x7fbd92cd627d in VecRestoreArrayRead
>>>> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x28327d)
>>>> #4 0x7fbd92d1189e in VecScatterBegin_SSToSS
>>>> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x2be89e)
>>>> #5 0x7fbd92d1a414 in VecScatterBegin
>>>> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x2c7414)
>>>> #6 0x7fbd934a999c in PCApply_FieldSplit
>>>> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xa5699c)
>>>> #7 0x7fbd93369071 in PCApply
>>>> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x916071)
>>>> #8 0x7fbd934efe77 in KSPInitialResidual
>>>> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xa9ce77)
>>>> #9 0x7fbd9350272c in KSPSolve_GMRES
>>>> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xaaf72c)
>>>> #10 0x7fbd934e3c01 in KSPSolve
>>>> (/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xa90c01)
>>>> Disabling Leak Sanitizer also outputs an "invalid pointer" error.
>>>> Did I forget something when writing the code?
>>>> Thank you,
>>>> Manuel
