[petsc-users] MatCompositeMerge + MatCreateRedundantMatrix
Matthew Knepley
knepley at gmail.com
Wed Mar 13 05:35:48 CDT 2019
On Wed, Mar 13, 2019 at 3:37 AM Marius Buerkle <mbuerkle at web.de> wrote:
> Indeed, was very easy to add. Are you going to include the Fortran
> interface for MPICreateSubMatricesMPI in future releases of PETSC ?
> Yes. You can either make a PR yourself at Bitbucket, or send me the diff
and I will make a PR with your name.
> Regarding my initial problem, thanks a lot. It works very well with
> MPICreateSubMatricesMPI and the solution can be implemented in a few
> lines.
> Glad its working. If you want that incorporated into the source, we can do
another PR.
Matt
> Thanks and Best,
> Marius
> On Tue, Mar 12, 2019 at 4:50 AM Marius Buerkle <mbuerkle at web.de> wrote:
>> I tried to follow your suggestions but it seems there is
>> no MPICreateSubMatricesMPI for Fortran. Is this correct?
> We just have to write the binding. Its almost identical to
> MatCreateSubMatrices() in src/mat/interface/ftn-custom/zmatrixf.c
> Matt
>> On Wed, Feb 20, 2019 at 6:57 PM Marius Buerkle <mbuerkle at web.de> wrote:
>>> ok, I think I understand now. I will give it a try and if there is some
>>> trouble comeback to you. thanks.
>> Cool.
>> Matt
>>> marius
>>> On Tue, Feb 19, 2019 at 8:42 PM Marius Buerkle <mbuerkle at web.de> wrote:
>>>> ok, so it seems there is no straight forward way to transfer data
>>>> between PETSc matrices on different subcomms. Probably doing it by "hand"
>>>> extracting the matricies on the subcomms create a MPI_INTERCOMM transfering
>>>> the data to PETSC_COMM_WORLD and assembling them in a new PETSc matrix
>>>> would be possible, right?
>>> That sounds too complicated. Why not just reverse
>>> MPICreateSubMatricesMPI()? Meaning make it collective on the whole big
>>> communicator, so that you can swap out all the subcommunicator for the
>>> aggregation call, just like we do in that function.
>>> Then its really just a matter of reversing the communication call.
>>> Matt
>>>> On Tue, Feb 19, 2019 at 7:12 PM Marius Buerkle <mbuerkle at web.de> wrote:
>>>>> I see. This would work if the matrices are on different
>>>>> subcommumicators ? Is it possible to add this functionality ?
>>>> Hmm, no. That is specialized to serial matrices. You need the inverse
>>>> of MatCreateSubMatricesMPI().
>>>> Thanks,
>>>> Matt
>>>>> marius
>>>>> You basically need the inverse of MatCreateSubmatrices(). I do not
>>>>> think we have that right now, but it could probably be done without too
>>>>> much trouble by looking at that code.
>>>>> Thanks,
>>>>> Matt
>>>>> On Tue, Feb 19, 2019 at 6:15 AM Marius Buerkle via petsc-users <
>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>> Hi !
>>>>>> Is there some way to combine MatCompositeMerge
>>>>>> with MatCreateRedundantMatrix? I basically want to create copies of a
>>>>>> matrix from PETSC_COMM_WORLD to subcommunicators, do some work on each
>>>>>> subcommunicator and than gather the results back to PETSC_COMM_WORLD,
>>>>>> namely I want to sum the the invidual matrices from the subcommunicatos
>>>>>> component wise and get the resulting matrix on PETSC_COMM_WORLD. Is this
>>>>>> somehow possible without going through all the hassle of using MPI
>>>>>> directly?
>>>>>> marius
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190313/4ea0bae7/attachment.html>
