[petsc-users] PCFieldSplit with MatNest
Zhang, Junchao jczhang at mcs.anl.gov
Tue Mar 12 13:08:10 CDT 2019
Hi, Manuel,
  I recently fixed a problem in VecRestoreArrayRead. Basically, I added VecRestoreArrayRead_Nest. Could you try the master branch of PETSc to see if it fixes your problem?
  Thanks.
--Junchao Zhang
On Mon, Mar 11, 2019 at 6:56 AM Manuel Colera Rico via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I need to solve a 2*2 block linear system. The matrices A_00, A_01,
A_10, A_11 are constructed separately via MatCreateSeqAIJWithArrays and
MatCreateSeqSBAIJWithArrays. Then, I construct the full system matrix
with MatCreateNest, and use MatNestGetISs and PCFieldSplitSetIS to set
up the PC, trying to follow the procedure described here:
https://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex70.c.html.
However, when I run the code with Leak Sanitizer, I get the following error:
==54927==ERROR: AddressSanitizer: attempting free on address which was
not malloc()-ed: 0x627000051ab8 in thread T0
     #0 0x7fbd95c08f30 in __interceptor_free
../../../../gcc-8.1.0/libsanitizer/asan/asan_malloc_linux.cc:66
     #1 0x7fbd92b99dcd in PetscFreeAlign
(/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x146dcd)
     #2 0x7fbd92ce0178 in VecRestoreArray_Nest
(/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x28d178)
     #3 0x7fbd92cd627d in VecRestoreArrayRead
(/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x28327d)
     #4 0x7fbd92d1189e in VecScatterBegin_SSToSS
(/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x2be89e)
     #5 0x7fbd92d1a414 in VecScatterBegin
(/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x2c7414)
     #6 0x7fbd934a999c in PCApply_FieldSplit
(/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xa5699c)
     #7 0x7fbd93369071 in PCApply
(/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0x916071)
     #8 0x7fbd934efe77 in KSPInitialResidual
(/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xa9ce77)
     #9 0x7fbd9350272c in KSPSolve_GMRES
(/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xaaf72c)
     #10 0x7fbd934e3c01 in KSPSolve
(/opt/PETSc_library/petsc/manuel_OpenBLAS_petsc/lib/libpetsc.so.3.8+0xa90c01)
Disabling Leak Sanitizer also outputs an "invalid pointer" error.
Did I forget something when writing the code?
Thank you,
Manuel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190312/2422f2da/attachment.html>
