[petsc-users] DMPlexComputeCellGeometryFVM: "Cannot handle faces with 1 vertices"
Tue Mar 12 12:11:26 CDT 2019
On Tue, Mar 12, 2019 at 10:09 AM <finnkochinski at keemail.me> wrote:
> Next try:
> Vertex and face numbering corrected (I hope), code and full output
> attached.
> Orientations still wrong, but the crash is elsewhere:
> reconstructed depth,dim: 1 3
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Mesh must be interpolated
> DMPlexComputeCellGeometryFVM() checks depth and dim in the beginning,
> finds they are different and quits because mesh seems not interpolated.
> Actually, DMPlexGetDepth and DMGetDimension return 1 and 3 with this
> vertex/face numbering. They returned the correct 3 and 3 with my previous
> wrong numbering.
> It can't be so difficult to create a simplex from scratch?
Well, it is difficult to get everything right. Here is me doing making a
reference tetrahedron:
https://bitbucket.org/petsc/petsc/src/e551bc0b4a184f2209a31a59ea3fbdc3edbf3863/src/dm/impls/plex/plexcreate.c#lines-3404
I use CreateFormDAG() only to get the topology right, and then call
DMInterpolate() to get the edges/faces/orientations correct.
I can debug this code if you want, or you can use this method. Either way.
    Matt
regards
> Chris
> Mar 12, 2019, 1:38 PM by knepley at gmail.com:
> On Tue, Mar 12, 2019 at 9:25 AM <finnkochinski at keemail.me> wrote:
> Thank you,
> I added DMPlexInterpolate(). Now I get a different error in
> DMPlexInterpolate():
> Okay, you did not need interpolate. You already specified all the levels.
> However, your orientations are wrong.
> Get rid of that code.
> [0]PETSC ERROR: Dimension 0 not supported
> The source code and full output are attached. Anybody able to fix this?
> The problem is a numbering convention in the library. Plex will accept any
> consistent DAG. However, if you
> want to use other things in the library, like geometry routines, then
> there is a convention on numbering (which
> makes many things simpler). We require that you number contiguously:
>   Cells:      [0, Nc)
>   Vertices: [Nc, Nc+Nv)
>   Edges:    [Nc+Nv, Nc+Nv+Ne)
>   Faces:    [Nc+Nv+Ne, Nc+Nv+Ne+Nf)
> You numbered the faces in the vertices slot,  so the geometry routines got
> confused.
>   Thanks,
>     Matt
> regards
> Chris
> Securely sent with Tutanota. Get your own encrypted, ad-free mailbox:
> https://tutanota.com
> Mar 12, 2019, 1:08 PM by knepley at gmail.com:
> On Tue, Mar 12, 2019 at 9:03 AM Chris Finn via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hello,
> with the code below, I create a tetrahedron using DMPlexCreateFromDAG,
> then I try to run DMPlexComputeCellGeometryFVM on this cell. The latter
> call fails with output:
> All the geometry stuff requires that you interpolate the mesh I think,
> Just use DMPlexInterpolate().
>   Thanks,
>     Matt
> [0]PETSC ERROR: --------------------- Error Message -----------------
> [0]PETSC ERROR: Argument out of range
> [0]PETSC ERROR: Cannot handle faces with 1 vertices
> (full output is attached).
> What am I doing wrong?
> regards
> Chris
> Here is the code:
> static char help[] = "No help \n";
> #include <petscdmplex.h>
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **args)
>   PetscErrorCode ierr;
>   PetscInitialize(&argc,&args,(char*)0,help);
>   DM                dm;
>   int cStart,cEnd;
>   int fStart,fEnd;
>   int depth = 3;
>   int dim = 3;
>   PetscInt    numPoints[4]        = {1,4,6,4};
>   PetscInt    coneSize[15]         = {4,3,3,3,3,2,2,2,2,2,2,0,0,0,0};
>   PetscInt    cones[28]            = {1,2,3,4, 5,9,8, 9,6,10, 10,8,7,
> 5,6,7, 11,12, 12,13, 13,11, 11,14, 12,14, 13,14};
>   PetscInt    coneOrientations[28] = {0 };
>   PetscScalar vertexCoords[12]     = {0,0,0, 1,0,0, 0,1,0, 0,0,1};
>   DMCreate(PETSC_COMM_WORLD, &dm);
>   DMSetType(dm, DMPLEX);
>   DMSetDimension(dm,dim);
>   DMPlexCreateFromDAG(dm, depth, numPoints, coneSize, cones,
> coneOrientations, vertexCoords);
>   DMPlexGetHeightStratum(dm, 0, &cStart, &cEnd);
>   DMPlexGetHeightStratum(dm, 1, &fStart, &fEnd);
>   for (int k =cStart;k<cEnd;k++){
>     double vol;
>     double centroid[3];
>     double normal[3];
>     ierr = DMPlexComputeCellGeometryFVM(dm, k, &vol,
> centroid,NULL);CHKERRQ(ierr);
>     printf("FVM: V=%f c=(%f %f %f) n=(%f %f
> %f)\n",vol,centroid[0],centroid[1],centroid[2],
>       normal[0],normal[1],normal[2]);
>   ierr = PetscFinalize();
>   return 0;
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190312/7ead4c23/attachment.html>
