[petsc-users] DMPlexComputeCellGeometryFVM: "Cannot handle faces with 1 vertices"
    finnkochinski at keemail.me
    Tue Mar 12 08:25:50 CDT 2019
Thank you,
I added DMPlexInterpolate(). Now I get a different error in DMPlexInterpolate():
[0]PETSC ERROR: Dimension 0 not supported
The source code and full output are attached. Anybody able to fix this?
regards
Chris
 Securely sent with Tutanota. Get your own encrypted, ad-free mailbox:
 https://tutanota.com
Mar 12, 2019, 1:08 PM by knepley at gmail.com:
> On Tue, Mar 12, 2019 at 9:03 AM Chris Finn via petsc-users <> petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> > wrote:
>> Hello,
>> with the code below, I create a tetrahedron using DMPlexCreateFromDAG, then I try to run DMPlexComputeCellGeometryFVM on this cell. The latter call fails with output:
> All the geometry stuff requires that you interpolate the mesh I think, Just use DMPlexInterpolate().
>   Thanks,
>     Matt
>> [0]PETSC ERROR: --------------------- Error Message -----------------
>> [0]PETSC ERROR: Argument out of range
>> [0]PETSC ERROR: Cannot handle faces with 1 vertices
>> (full output is attached).
>> What am I doing wrong?
>> regards
>> Chris
>> Here is the code:
>> static char help[] = "No help \n";
>> #include <petscdmplex.h>
>> #undef __FUNCT__
>> #define __FUNCT__ "main"
>> int main(int argc,char **args)
>>   PetscErrorCode ierr;
>>   PetscInitialize(&argc,&args,(char*)0,help);
>>   DM                dm;
>>   int cStart,cEnd;
>>   int fStart,fEnd;
>>   int depth = 3;
>>   int dim = 3;
>>   PetscInt    numPoints[4]        = {1,4,6,4};
>>   PetscInt    coneSize[15]         = {4,3,3,3,3,2,2,2,2,2,2,0,0,0,0};
>>   PetscInt    cones[28]            = {1,2,3,4, 5,9,8, 9,6,10, 10,8,7, 5,6,7, 11,12, 12,13, 13,11, 11,14, 12,14, 13,14};
>>   PetscInt    coneOrientations[28] = {0 };
>>   PetscScalar vertexCoords[12]     = {0,0,0, 1,0,0, 0,1,0, 0,0,1};
>>   DMCreate(PETSC_COMM_WORLD, &dm);
>>   DMSetType(dm, DMPLEX);
>>   DMSetDimension(dm,dim);
>>   DMPlexCreateFromDAG(dm, depth, numPoints, coneSize, cones, coneOrientations, vertexCoords);
>>   DMPlexGetHeightStratum(dm, 0, &cStart, &cEnd);
>>   DMPlexGetHeightStratum(dm, 1, &fStart, &fEnd);
>>   for (int k =cStart;k<cEnd;k++){
>>     double vol;
>>     double centroid[3];
>>     double normal[3];
>>     ierr = DMPlexComputeCellGeometryFVM(dm, k, &vol, centroid,NULL);CHKERRQ(ierr);
>>     printf("FVM: V=%f c=(%f %f %f) n=(%f %f %f)\n",vol,centroid[0],centroid[1],centroid[2],
>>       normal[0],normal[1],normal[2]);
>>   ierr = PetscFinalize();
>>   return 0;
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190312/33a517c4/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190312/33a517c4/attachment-0001.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190312/33a517c4/attachment-0001.obj>
