[petsc-users] DMDA and ksp(ex46.c & ex22f.F90)
Matthew Knepley
knepley at gmail.com
Mon Mar 11 20:56:08 CDT 2019
On Mon, Mar 11, 2019 at 8:09 PM Maahi Talukder via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Thank you for your reply.
> I still have some confusion. So if (i,j) is a point on the structured
> grid( Where "i" is the column and "j" is the row), and the information
> associated with the (i,j) point on the grid is stored in some (m,n)
> location of the matrix A (Where Ax =b), I still don't
> understand why both of row(MatStencil_i,1) and row(MatStencil_j,1) are
> necessary? I mean is it something like mapping "i" from grid to its
> location in the matrix? Would you please explain that?
I don't think you are understanding. (i, j) is a grid location, so it
corresponds to a dof number n. A location (m, n) in the Jacobian
relates two variables, one at some location (i_m, j_m) in the grid and
another at location (i_n, j_n) in the grid. The matrix grid
and spatial grid are completely different things. For example, you could
have a 3D spatial grid, but you still have a 2D matrix.
Matt
> Regards,
> Maahi
> On Mon, Mar 11, 2019 at 4:41 PM Patrick Sanan <patrick.sanan at gmail.com>
> wrote:
>> There are two different types of rows and columns:
>> 1. Rows and columns in a grid
>> 2. Rows and columns in a matrix
>> "i" and "j" refer to rows and columns in the grid, but "row" and "col"
>> refer to rows and columns in the matrix.
>> Am Mo., 11. März 2019 um 21:18 Uhr schrieb Maahi Talukder via petsc-users
>> <petsc-users at mcs.anl.gov>:
>>> Hello all,
>>> I am trying to solve Poisson Equation on structured grid using 9-point
>>> stencil in 2D. Now to setup my matrix, I came across C structure MatStencil
>>> in ex22f.F90
>>> call DMDAGetCorners <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDAGetCorners.html#DMDAGetCorners>(da,xs,ys,zs,xm,ym,zm,ierr)
>>> 107: do 10,k=zs,zs+zm-1108: do 20,j=ys,ys+ym-1109: do 30,i=xs,xs+xm-1110: row(MatStencil_i) = i111: row(MatStencil_j) = j112: row(MatStencil_k) = k113: if (i.eq.0 .or. j.eq.0 .or. k.eq.0 .or. i.eq.mx-1 .or. j.eq.my-1 .or. k.eq.mz-1) then114: v(1) = 2.0*(HxHydHz + HxHzdHy + HyHzdHx)115: call MatSetValuesStencil <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetValuesStencil.html#MatSetValuesStencil>(jac,i1,row,i1,row,v,INSERT_VALUES <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/INSERT_VALUES.html#INSERT_VALUES>,ierr)116: else117: v(1) = -HxHydHz118: col(MatStencil_i,1) = i119: col(MatStencil_j,1) = j120: col(MatStencil_k,1) = k-1121: v(2) = -HxHzdHy122: col(MatStencil_i,2) = i123: col(MatStencil_j,2) = j-1124: col(MatStencil_k,2) = k125: v(3) = -HyHzdHx126: col(MatStencil_i,3) = i-1127: col(MatStencil_j,3) = j128: col(MatStencil_k,3) = k129: v(4) = 2.0*(HxHydHz + HxHzdHy + HyHzdHx)130: col(MatStencil_i,4) = i131: col(MatStencil_j,4) = j132: col(MatStencil_k,4) = k133: v(5) = -HyHzdHx134: col(MatStencil_i,5) = i+1135: col(MatStencil_j,5) = j136: col(MatStencil_k,5) = k137: v(6) = -HxHzdHy138: col(MatStencil_i,6) = i139: col(MatStencil_j,6) = j+1140: col(MatStencil_k,6) = k141: v(7) = -HxHydHz142: col(MatStencil_i,7) = i143: col(MatStencil_j,7) = j144: col(MatStencil_k,7) = k+1145: call MatSetValuesStencil <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetValuesStencil.html#MatSetValuesStencil>(jac,i1,row,i7,col,v,INSERT_VALUES <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/INSERT_VALUES.html#INSERT_VALUES>,ierr)146: endif
>>> What I am confused about is what it means to have the value of row in i and j directions(row(MatStencil_i,1) & row(MatStencil_j,1)).
>>> Same confusion goes for the column values as well. I mean generally in a 2D Matrix row values are in j/y direction and column values are in i/x direction.
>>> Could you please explain that?
>>> Regards,
>>> Maahi Talukder
>>> Department of Mechanical Engineering
>>> Clarkson University
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/e26fd8ef/attachment-0001.html>
