[petsc-users] Bad memory scaling with PETSc 3.10
Myriam Peyrounette myriam.peyrounette at idris.fr
Mon Mar 11 08:32:07 CDT 2019
The code I am using here is the example 42 of PETSc
(https://www.mcs.anl.gov/petsc/petsc-3.9/src/ksp/ksp/examples/tutorials/ex42.c.html).
Indeed it solves the Stokes equation. I thought it was a good idea to
use an example you might know (and didn't find any that uses GAMG
functions). I just changed the PCMG setup so that the memory problem
appears. And it appears when adding PCGAMG.
I don't care about the performance or even the result rightness here,
but only about the difference in memory use between 3.6 and 3.10. Do you
think finding a more adapted script would help?
I used the threshold of 0.1 only once, at the beginning, to test its
influence. I used the default threshold (of 0, I guess) for all the
other runs.
Myriam
Le 03/11/19 à 13:52, Mark Adams a écrit :
> In looking at this larger scale run ...
> * Your eigen estimates are much lower than your tiny test problem.
> But this is Stokes apparently and it should not work anyway. Maybe you
> have a small time step that adds a lot of mass that brings the eigen
> estimates down. And your min eigenvalue (not used) is positive. I
> would expect negative for Stokes ...
> * You seem to be setting a threshold value of 0.1 -- that is very high
> * v3.6 says "using nonzero initial guess" but this is not in v3.10.
> Maybe we just stopped printing that.
> * There were some changes to coasening parameters in going from v3.6
> but it does not look like your problem was effected. (The coarsening
> algo is non-deterministic by default and you can see small difference
> on different runs)
> * We may have also added a "noisy" RHS for eigen estimates by default
> from v3.6.
> * And for non-symetric problems you can try -pc_gamg_agg_nsmooths 0,
> but again GAMG is not built for Stokes anyway.
> On Tue, Mar 5, 2019 at 11:53 AM Myriam Peyrounette
> <myriam.peyrounette at idris.fr <mailto:myriam.peyrounette at idris.fr>> wrote:
>     I used PCView to display the size of the linear system in each
>     level of the MG. You'll find the outputs attached to this mail
>     (zip file) for both the default threshold value and a value of
>     0.1, and for both 3.6 and 3.10 PETSc versions.
>     For convenience, I summarized the information in a graph, also
>     attached (png file).
>     As you can see, there are slight differences between the two
>     versions but none is critical, in my opinion. Do you see anything
>     suspicious in the outputs?
>     + I can't find the default threshold value. Do you know where I
>     can find it?
>     Thanks for the follow-up
>     Myriam
>     Le 03/05/19 à 14:06, Matthew Knepley a écrit :
>>     On Tue, Mar 5, 2019 at 7:14 AM Myriam Peyrounette
>>         Hi Matt,
>>         I plotted the memory scalings using different threshold
>>         values. The two scalings are slightly translated (from -22 to
>>         -88 mB) but this gain is neglectable. The 3.6-scaling keeps
>>         being robust while the 3.10-scaling deteriorates.
>>         Do you have any other suggestion?
>>     Mark, what is the option she can give to output all the GAMG data?
>>     Also, run using -ksp_view. GAMG will report all the sizes of its
>>     grids, so it should be easy to see
>>     if the coarse grid sizes are increasing, and also what the effect
>>     of the threshold value is.
>>       Thanks,
>>          Matt
>>         Thanks
>>         Myriam
>>         Le 03/02/19 à 02:27, Matthew Knepley a écrit :
>>>         On Fri, Mar 1, 2019 at 10:53 AM Myriam Peyrounette via
>>>         petsc-users <petsc-users at mcs.anl.gov
>>>         <mailto:petsc-users at mcs.anl.gov>> wrote:
>>>             Hi,
>>>             I used to run my code with PETSc 3.6. Since I upgraded
>>>             the PETSc version
>>>             to 3.10, this code has a bad memory scaling.
>>>             To report this issue, I took the PETSc script ex42.c and
>>>             slightly
>>>             modified it so that the KSP and PC configurations are
>>>             the same as in my
>>>             code. In particular, I use a "personnalised" multi-grid
>>>             method. The
>>>             modifications are indicated by the keyword "TopBridge"
>>>             in the attached
>>>             scripts.
>>>             To plot the memory (weak) scaling, I ran four
>>>             calculations for each
>>>             script with increasing problem sizes and computations cores:
>>>             1. 100,000 elts on 4 cores
>>>             2. 1 million elts on 40 cores
>>>             3. 10 millions elts on 400 cores
>>>             4. 100 millions elts on 4,000 cores
>>>             The resulting graph is also attached. The scaling using
>>>             PETSc 3.10
>>>             clearly deteriorates for large cases, while the one
>>>             using PETSc 3.6 is
>>>             robust.
>>>             After a few tests, I found that the scaling is mostly
>>>             sensitive to the
>>>             use of the AMG method for the coarse grid (line 1780 in
>>>             main_ex42_petsc36.cc). In particular, the performance
>>>             strongly
>>>             deteriorates when commenting lines 1777 to 1790 (in
>>>             Do you have any idea of what changed between version 3.6
>>>             and version
>>>             3.10 that may imply such degradation?
>>>         I believe the default values for PCGAMG changed between
>>>         versions. It sounds like the coarsening rate
>>>         is not great enough, so that these grids are too large. This
>>>         can be set using:
>>>           https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
>>>         There is some explanation of this effect on that page. Let
>>>         us know if setting this does not correct the situation.
>>>           Thanks,
>>>              Matt
>>>             Let me know if you need further information.
>>>             Best,
>>>             Myriam Peyrounette
>>>             Myriam Peyrounette
>>>             CNRS/IDRIS - HLST
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>>         https://www.cse.buffalo.edu/~knepley/
>>>         <http://www.cse.buffalo.edu/%7Eknepley/>
>>         Myriam Peyrounette
>>         CNRS/IDRIS - HLST
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
>     Myriam Peyrounette
>     CNRS/IDRIS - HLST
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/58a8d1b6/attachment-0001.html>
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190311/58a8d1b6/attachment-0001.p7s>
