[petsc-users] Bad memory scaling with PETSc 3.10
Myriam Peyrounette
myriam.peyrounette at idris.fr
Fri Mar 8 03:10:30 CST 2019
Hi all,
thanks a lot for all your suggestions. I followed Jed's advice and
focused on the smallest case (problem size = 1e5) to find the origin of
the memory gap. And I ran my jobs on a single core.
I first used a homemade script to plot memory and time consumption: see
mem_consumption.png and time_consumption.png attached. The steps
displayed correspond to checkpoints I defined in the main file (search
for keyword "STEP" in the attached main file if you need to locate them).
We can see that both the time and the memory needs increase while using
petsc 3.10. With regard to memory consumption, the memory gap (of
~135,000,000B) is not critical yet for such a problem size, but will be
for larger problems. According to these graphs, something clearly
happens while calling KSPSolve. The code also spends more time building
the matrix.
To dig deeper, I printed the LogView outputs (logView_petsc3XX.log). In
particular, we see that the memory distribution among the petsc object
types is very different depending on the petsc version. I highlighted
this in log_view_mem_distr.pdf by sorting the petsc object types
according to their memory use, and computing the difference between
petsc 3.10 and petsc 3.6 (column on the rigth). But I don't know how to
understand that...
Finally, I used Massif (massif_petscXX.out). The total memory gap of
~135,000,000B is verified. The outputs further indicate that most of the
memory space is required by DMCreateMatrix (1,174,436,836B). This value
is almost the same is both versions so I don't think this is the problem.
You mentioned PtAP: MatPtAPSymbolic_SeqAIJ_SeqMAIJ needs 56,277,776B
with petsc 3.6, and 112,562,000B in petsc 3.10 (twice more). So it is a
good start but it does not correspond to the total memory gap. I will
try the option "-matptap via scalable" to see if there is an improvement.
I also find a gap at KSPSolve, which needs up to 173,253,112B with petsc
3.10 (line 461 in massif_petsc310.out), and no more than 146,825,952B
(line 1534 in massif_petsc36.out) with petsc 3.6. But again, the sum of
these gaps does not fit the total gap.
I am not very familiar with massif, so maybe you'll see additional
relevant information?
Best,
Myriam
Le 03/06/19 à 05:35, Jed Brown a écrit :
> Myriam, in your first message, there was a significant (about 50%)
> increase in memory consumption already on 4 cores. Before attacking
> scaling, it may be useful to trace memory usage for that base case.
> Even better if you can reduce to one process. Anyway, I would start by
> running both cases with -log_view and looking at the memory summary. I
> would then use Massif (the memory profiler/tracer component in Valgrind)
> to obtain stack traces for the large allocations. Comparing those
> traces should help narrow down which part of the code has significantly
> different memory allocation behavior. It might also point to the
> unacceptable memory consumption under weak scaling, but it's something
> we should try to fix.
> If I had to guess, it may be in intermediate data structures for the
> different PtAP algorithms in GAMG. The option "-matptap_via scalable"
> may be helpful.
> "Smith, Barry F. via petsc-users" <petsc-users at mcs.anl.gov> writes:
>> Myriam,
>> Sorry we have not been able to resolve this problem with memory scaling yet.
>> The best tool to determine the change in a code that results in large differences in a program's run is git bisect. Basically you tell git bisect
>> the git commit of the code that is "good" and the git commit of the code that is "bad" and it gives you additional git commits for you to check your code on each time telling git if it is "good" or "bad", eventually git bisect tells you exactly the git commit that "broke" the code. No guess work, no endless speculation.
>> The draw back is that you have to ./configure && make PETSc for each "test" commit and then compile and run your code for that commit. I can understand if you have to run your code on 10,000 processes to check if it is "good" or "bad" that can be very daunting. But all I can suggest is to find a problem size that is manageable and do the git bisect process (yeah it may take several hours but that beats days of head banging).
>> Good luck,
>> Barry
>>> On Mar 5, 2019, at 12:42 PM, Matthew Knepley via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>> On Tue, Mar 5, 2019 at 11:53 AM Myriam Peyrounette <myriam.peyrounette at idris.fr> wrote:
>>> I used PCView to display the size of the linear system in each level of the MG. You'll find the outputs attached to this mail (zip file) for both the default threshold value and a value of 0.1, and for both 3.6 and 3.10 PETSc versions.
>>> For convenience, I summarized the information in a graph, also attached (png file).
>>> Great! Can you draw lines for the different runs you did? My interpretation was that memory was increasing
>>> as you did larger runs, and that you though that was coming from GAMG. That means the curves should
>>> be pushed up for larger runs. Do you see that?
>>> Thanks,
>>> Matt
>>> As you can see, there are slight differences between the two versions but none is critical, in my opinion. Do you see anything suspicious in the outputs?
>>> + I can't find the default threshold value. Do you know where I can find it?
>>> Thanks for the follow-up
>>> Myriam
>>> Le 03/05/19 à 14:06, Matthew Knepley a écrit :
>>>> On Tue, Mar 5, 2019 at 7:14 AM Myriam Peyrounette <myriam.peyrounette at idris.fr> wrote:
>>>> Hi Matt,
>>>> I plotted the memory scalings using different threshold values. The two scalings are slightly translated (from -22 to -88 mB) but this gain is neglectable. The 3.6-scaling keeps being robust while the 3.10-scaling deteriorates.
>>>> Do you have any other suggestion?
>>>> Mark, what is the option she can give to output all the GAMG data?
>>>> Also, run using -ksp_view. GAMG will report all the sizes of its grids, so it should be easy to see
>>>> if the coarse grid sizes are increasing, and also what the effect of the threshold value is.
>>>> Thanks,
>>>> Matt
>>>> Thanks
>>>> Myriam
>>>> Le 03/02/19 à 02:27, Matthew Knepley a écrit :
>>>>> On Fri, Mar 1, 2019 at 10:53 AM Myriam Peyrounette via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>>>> Hi,
>>>>> I used to run my code with PETSc 3.6. Since I upgraded the PETSc version
>>>>> to 3.10, this code has a bad memory scaling.
>>>>> To report this issue, I took the PETSc script ex42.c and slightly
>>>>> modified it so that the KSP and PC configurations are the same as in my
>>>>> code. In particular, I use a "personnalised" multi-grid method. The
>>>>> modifications are indicated by the keyword "TopBridge" in the attached
>>>>> scripts.
>>>>> To plot the memory (weak) scaling, I ran four calculations for each
>>>>> script with increasing problem sizes and computations cores:
>>>>> 1. 100,000 elts on 4 cores
>>>>> 2. 1 million elts on 40 cores
>>>>> 3. 10 millions elts on 400 cores
>>>>> 4. 100 millions elts on 4,000 cores
>>>>> The resulting graph is also attached. The scaling using PETSc 3.10
>>>>> clearly deteriorates for large cases, while the one using PETSc 3.6 is
>>>>> robust.
>>>>> After a few tests, I found that the scaling is mostly sensitive to the
>>>>> use of the AMG method for the coarse grid (line 1780 in
>>>>> main_ex42_petsc36.cc). In particular, the performance strongly
>>>>> deteriorates when commenting lines 1777 to 1790 (in main_ex42_petsc36.cc).
>>>>> Do you have any idea of what changed between version 3.6 and version
>>>>> 3.10 that may imply such degradation?
>>>>> I believe the default values for PCGAMG changed between versions. It sounds like the coarsening rate
>>>>> is not great enough, so that these grids are too large. This can be set using:
>>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
>>>>> There is some explanation of this effect on that page. Let us know if setting this does not correct the situation.
>>>>> Thanks,
>>>>> Matt
>>>>> Let me know if you need further information.
>>>>> Best,
>>>>> Myriam Peyrounette
>>>>> Myriam Peyrounette
>>>>> CNRS/IDRIS - HLST
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>> Myriam Peyrounette
>>>> CNRS/IDRIS - HLST
>>>> -- Norbert Wiener
>>> Myriam Peyrounette
>>> CNRS/IDRIS - HLST
>>> -- Norbert Wiener
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190308/99d1b272/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190308/99d1b272/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190308/99d1b272/attachment-0003.png>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190308/99d1b272/attachment-0003.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190308/99d1b272/attachment-0004.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190308/99d1b272/attachment-0005.bin>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190308/99d1b272/attachment-0001.pdf>
Command: ./ex42 -mx 48 -my 48 -mz 48 -stokes_ksp_monitor_blocks 0 -model 0 -levels 3
Massif arguments: (none)
ms_print arguments: massif.out.33309
GB
1.547^ :
0 +----------------------------------------------------------------------->Gi
0 304.7
Number of snapshots: 82
Detailed snapshots: [3, 5, 11, 37, 40, 43, 46, 50, 53, 57, 60, 64, 67 (peak), 77]
n time(i) total(B) useful-heap(B) extra-heap(B) stacks(B)
0 0 0 0 0 0
1 35,834,612 71,737,416 71,723,119 14,297 0
2 327,760,951 71,715,056 71,700,775 14,281 0
3 328,278,660 75,486,720 75,471,765 14,955 0
99.98% (75,471,765B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->88.82% (67,049,927B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->75.01% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->75.01% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->75.01% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->07.48% (5,647,152B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->07.48% (5,647,152B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->07.48% (5,647,152B) 0x4FF8EA3: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.74% (2,823,576B) 0x53C0070: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->03.74% (2,823,576B) 0x553D255: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->03.74% (2,823,576B) 0x53C5B4C: DMDASetUniformCoordinates (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->03.74% (2,823,576B) 0x404C6C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1854)
| | | ->03.74% (2,823,576B) 0x4048AA: main (main_petsc36.cc:2255)
| | ->03.74% (2,823,576B) 0x53B5985: DMCreateLocalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.74% (2,823,576B) 0x5542B05: DMCreateLocalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.74% (2,823,576B) 0x5543B56: DMGetCoordinatesLocal (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.74% (2,823,576B) 0x404D00: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1864)
| ->04.99% (3,764,783B) 0x53EE8A9: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->04.99% (3,764,783B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->04.99% (3,764,783B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->04.99% (3,764,783B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | ->04.99% (3,764,783B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.25% (941,192B) 0x53A4C31: DMSetUp_DA_3D (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.25% (941,192B) 0x53E0AB6: DMSetUp_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.25% (941,192B) 0x553972E: DMSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.25% (941,192B) 0x53AE57B: DMDACreate3d (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.25% (941,192B) in 2 places, all below massif's threshold (01.00%)
| ->00.10% (73,696B) in 1+ places, all below ms_print's threshold (01.00%)
->11.12% (8,391,248B) 0xA051F04: MPIDI_CH3I_Seg_commit (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->11.12% (8,391,248B) 0xA05E0D2: MPID_nem_init_ckpt (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->11.12% (8,391,248B) 0xA05FCA5: MPID_nem_init (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->11.12% (8,391,248B) 0x9F1106E: MPIDI_CH3_Init (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->11.12% (8,391,248B) 0xA04EBAB: MPID_Init (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->11.12% (8,391,248B) 0xA02538D: MPIR_Init_thread (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->11.12% (8,391,248B) 0xA024D98: PMPI_Init_thread (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->11.12% (8,391,248B) 0x4F1D607: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->11.12% (8,391,248B) 0x404761: main (main_petsc36.cc:2242)
->00.04% (30,590B) in 1+ places, all below ms_print's threshold (01.00%)
4 1,499,136,193 75,486,696 75,471,765 14,931 0
5 1,516,554,677 666,470,400 666,454,974 15,426 0
100.00% (666,454,974B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->98.73% (658,033,144B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->88.11% (587,218,418B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->88.11% (587,218,418B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->88.11% (587,218,418B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->88.11% (587,218,418B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->88.11% (587,218,418B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->88.11% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | ->88.11% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| ->08.50% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->08.50% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->08.50% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->02.13% (14,191,622B) in 69 places, all below massif's threshold (01.00%)
->01.26% (8,391,248B) 0xA051F04: MPIDI_CH3I_Seg_commit (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->01.26% (8,391,248B) 0xA05E0D2: MPID_nem_init_ckpt (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->01.26% (8,391,248B) 0xA05FCA5: MPID_nem_init (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->01.26% (8,391,248B) 0x9F1106E: MPIDI_CH3_Init (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->01.26% (8,391,248B) 0xA04EBAB: MPID_Init (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->01.26% (8,391,248B) 0xA02538D: MPIR_Init_thread (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->01.26% (8,391,248B) 0xA024D98: PMPI_Init_thread (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->01.26% (8,391,248B) 0x4F1D607: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->01.26% (8,391,248B) 0x404761: main (main_petsc36.cc:2242)
->00.00% (30,582B) in 1+ places, all below ms_print's threshold (01.00%)
6 16,261,614,710 662,705,608 662,690,191 15,417 0
7 16,273,177,611 664,588,000 664,572,575 15,425 0
8 16,453,080,876 666,470,408 666,454,963 15,445 0
9 16,592,550,759 670,240,048 670,224,014 16,034 0
10 17,763,405,488 670,240,024 670,224,014 16,010 0
11 17,780,820,810 1,261,223,728 1,261,207,223 16,505 0
100.00% (1,261,207,223B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.33% (1,252,785,393B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->93.12% (1,174,436,836B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->93.12% (1,174,436,836B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->93.12% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->93.12% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->93.12% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->46.56% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | ->46.56% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | ->46.56% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| ->04.49% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->04.49% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->04.49% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.72% (21,725,453B) in 72 places, all below massif's threshold (01.00%)
->00.67% (8,421,830B) in 1+ places, all below ms_print's threshold (01.00%)
12 32,525,877,843 1,257,458,936 1,257,442,440 16,496 0
13 32,717,337,805 1,261,223,736 1,261,207,212 16,524 0
14 32,856,396,640 1,261,221,968 1,261,205,453 16,515 0
15 32,930,640,810 1,268,778,168 1,268,761,389 16,779 0
16 58,569,488,720 1,268,755,808 1,268,739,045 16,763 0
17 80,399,203,865 1,268,755,808 1,268,739,045 16,763 0
18 80,399,942,978 1,272,567,448 1,272,550,529 16,919 0
19 81,763,811,939 1,272,545,088 1,272,528,185 16,903 0
20 81,893,298,331 1,305,332,968 1,305,305,169 27,799 0
21 85,163,552,026 1,356,110,968 1,356,077,261 33,707 0
22 85,215,698,411 1,376,145,504 1,376,117,065 28,439 0
23 93,174,834,293 1,375,145,464 1,375,117,035 28,429 0
24 93,176,062,194 1,375,962,496 1,375,933,984 28,512 0
25 93,593,897,813 1,382,701,952 1,382,673,404 28,548 0
26 93,600,805,445 1,385,254,232 1,385,224,814 29,418 0
27 94,611,634,258 1,385,051,600 1,385,022,202 29,398 0
28 94,632,051,286 1,404,694,096 1,404,662,417 31,679 0
29 94,883,287,158 1,404,702,920 1,404,671,205 31,715 0
30 95,007,514,066 1,407,559,152 1,407,523,721 35,431 0
31 95,167,535,043 1,405,947,776 1,405,915,815 31,961 0
32 95,349,461,781 1,413,587,144 1,413,552,928 34,216 0
33 95,639,044,739 1,405,736,760 1,405,704,162 32,598 0
34 95,674,406,759 1,458,922,280 1,458,880,871 41,409 0
35 96,600,728,596 1,458,922,544 1,458,881,127 41,417 0
36 97,102,450,577 1,458,922,632 1,458,881,207 41,425 0
37 97,105,663,401 1,492,821,480 1,492,779,339 42,141 0
100.00% (1,492,779,339B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.43% (1,484,354,449B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->79.06% (1,180,246,040B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->79.06% (1,180,246,040B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->78.67% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->78.67% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->78.67% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->39.34% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | | ->39.34% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->39.34% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| | ->00.39% (5,809,204B) in 1+ places, all below ms_print's threshold (01.00%)
| ->07.18% (107,177,936B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->07.18% (107,177,936B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->04.78% (71,412,640B) 0x4FF1C5F: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->04.78% (71,412,640B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->04.71% (70,337,984B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->04.71% (70,337,984B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->04.71% (70,337,984B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.27% (33,882,912B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.27% (33,882,912B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.27% (33,882,912B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.27% (33,882,912B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.27% (33,882,912B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.27% (33,882,912B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.27% (33,882,912B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.27% (33,882,912B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.27% (33,882,912B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.27% (33,882,912B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.27% (33,882,912B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | ->02.27% (33,882,912B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | ->00.00% (0B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.26% (18,825,120B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.26% (18,825,120B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.26% (18,823,840B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.26% (18,823,840B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.26% (18,823,840B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.26% (18,823,840B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.26% (18,823,840B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.26% (18,823,840B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.26% (18,823,840B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.26% (18,823,840B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.26% (18,823,840B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | ->01.26% (18,823,840B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | ->00.00% (1,280B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.18% (17,629,952B) in 3 places, all below massif's threshold (01.00%)
| | | ->00.07% (1,074,656B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->02.40% (35,765,296B) 0x4FF8EA3: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.40% (35,765,296B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.14% (32,000,528B) 0x53C0070: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.14% (32,000,528B) 0x553D255: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->01.26% (18,823,840B) 0x53BFE5F: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.26% (18,823,840B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.26% (18,823,840B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.26% (18,823,840B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.26% (18,823,840B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.26% (18,823,840B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.26% (18,823,840B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->00.88% (13,176,688B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->00.25% (3,764,768B) in 1+ places, all below ms_print's threshold (01.00%)
| ->03.79% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->03.79% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->03.79% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->03.77% (56,277,776B) 0x51F256F: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.77% (56,277,776B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.77% (56,277,776B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.77% (56,277,776B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.77% (56,277,776B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.77% (56,277,776B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.77% (56,277,776B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.77% (56,277,776B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->03.77% (56,277,776B) 0x4048AA: main (main_petsc36.cc:2255)
| ->02.27% (33,882,942B) 0x5307655: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.27% (33,882,942B) 0x508F2F7: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.27% (33,882,942B) 0x5603367: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.27% (33,882,942B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.27% (33,882,942B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.27% (33,882,942B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.27% (33,882,942B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.27% (33,882,942B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.27% (33,882,942B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.27% (33,882,942B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.27% (33,882,942B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->02.27% (33,882,942B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.88% (28,138,888B) 0x51F2440: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.88% (28,138,888B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.88% (28,138,888B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.88% (28,138,888B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.88% (28,138,888B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.88% (28,138,888B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.88% (28,138,888B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.88% (28,138,888B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->01.88% (28,138,888B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.47% (22,007,763B) in 162 places, all below massif's threshold (01.00%)
->00.56% (8,424,890B) in 1+ places, all below ms_print's threshold (01.00%)
38 101,238,965,269 1,496,588,096 1,496,545,902 42,194 0
39 103,718,453,406 1,496,637,272 1,496,595,059 42,213 0
40 103,903,351,997 1,508,176,464 1,508,131,617 44,847 0
100.00% (1,508,131,617B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.44% (1,499,673,831B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->78.26% (1,180,246,040B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->78.26% (1,180,246,040B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->77.87% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->77.87% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->77.87% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->38.94% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | | ->38.94% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->38.94% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| ->07.82% (117,942,704B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->07.82% (117,942,704B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.45% (82,177,408B) 0x4FF1C5F: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.45% (82,177,408B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.38% (81,102,752B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->05.38% (81,102,752B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->05.38% (81,102,752B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.79% (42,147,680B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.79% (42,147,680B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.79% (42,147,680B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.79% (42,147,680B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.79% (42,147,680B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.79% (42,147,680B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.50% (37,647,680B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.50% (37,647,680B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.50% (37,647,680B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.50% (37,647,680B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.50% (37,647,680B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.50% (37,647,680B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | ->02.50% (37,647,680B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | | ->00.30% (4,500,000B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.41% (21,325,120B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.41% (21,325,120B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.41% (21,323,840B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.41% (21,323,840B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.41% (21,323,840B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.41% (21,323,840B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.25% (18,823,840B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.25% (18,823,840B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.25% (18,823,840B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.25% (18,823,840B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.25% (18,823,840B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.25% (18,823,840B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | | ->01.25% (18,823,840B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | | | ->00.17% (2,500,000B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.17% (17,629,952B) in 3 places, all below massif's threshold (01.00%)
| | ->02.37% (35,765,296B) 0x4FF8EA3: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.37% (35,765,296B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.12% (32,000,528B) 0x53C0070: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.12% (32,000,528B) 0x553D255: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->01.25% (18,823,840B) 0x53BFE5F: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.25% (18,823,840B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.25% (18,823,840B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.25% (18,823,840B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.25% (18,823,840B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.25% (18,823,840B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.25% (18,823,840B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.25% (18,823,840B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->00.87% (13,176,688B) in 1+ places, all below ms_print's threshold (01.00%)
| ->03.75% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->03.75% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->03.75% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->03.73% (56,277,776B) 0x51F256F: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.73% (56,277,776B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.73% (56,277,776B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.73% (56,277,776B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.73% (56,277,776B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.73% (56,277,776B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.73% (56,277,776B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.73% (56,277,776B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->03.73% (56,277,776B) 0x4048AA: main (main_petsc36.cc:2255)
| ->02.54% (38,382,972B) 0x5307655: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.54% (38,382,972B) 0x508F2F7: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.54% (38,382,972B) 0x5603367: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.54% (38,382,972B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.54% (38,382,972B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.54% (38,382,972B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.54% (38,382,972B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.54% (38,382,972B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.54% (38,382,972B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.25% (33,882,942B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.25% (33,882,942B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.25% (33,882,942B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.25% (33,882,942B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.25% (33,882,942B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.25% (33,882,942B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | ->02.25% (33,882,942B) 0x4048AA: main (main_petsc36.cc:2255)
| | ->00.30% (4,500,030B) in 1+ places, all below ms_print's threshold (01.00%)
| ->01.87% (28,138,888B) 0x51F2440: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.87% (28,138,888B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.87% (28,138,888B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.87% (28,138,888B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.87% (28,138,888B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.87% (28,138,888B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.87% (28,138,888B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.87% (28,138,888B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->01.87% (28,138,888B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.46% (22,062,347B) in 164 places, all below massif's threshold (01.00%)
->00.56% (8,457,786B) in 1+ places, all below ms_print's threshold (01.00%)
41 104,434,019,902 1,508,678,312 1,508,633,412 44,900 0
42 104,751,975,500 1,508,694,584 1,508,649,673 44,911 0
43 104,877,346,163 1,510,547,792 1,510,499,343 48,449 0
100.00% (1,510,499,343B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.44% (1,502,041,557B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->78.13% (1,180,246,040B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->78.13% (1,180,246,040B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->77.75% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->77.75% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->77.75% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->38.87% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | | ->38.87% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->38.87% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| | ->00.38% (5,809,204B) in 1+ places, all below ms_print's threshold (01.00%)
| ->07.91% (119,527,984B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->07.91% (119,527,984B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.55% (83,762,688B) 0x4FF1C5F: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.55% (83,762,688B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.47% (82,688,032B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->05.47% (82,688,032B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->05.47% (82,688,032B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.87% (43,371,200B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.87% (43,371,200B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.87% (43,371,200B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.87% (43,371,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.87% (43,371,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.87% (43,371,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.54% (38,350,720B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.54% (38,350,720B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.49% (37,647,680B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->02.49% (37,647,680B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->02.49% (37,647,680B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->02.49% (37,647,680B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | | ->02.49% (37,647,680B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | | | ->00.05% (703,040B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | | | ->00.33% (5,020,480B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.44% (21,686,880B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.44% (21,686,880B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.44% (21,685,600B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.44% (21,685,600B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.44% (21,685,600B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.44% (21,685,600B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.27% (19,175,360B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.27% (19,175,360B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->00.02% (351,520B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | | | | ->00.17% (2,510,240B) in 1+ places, all below ms_print's threshold (01.00%)
| ->02.58% (39,034,200B) 0x5307655: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.58% (39,034,200B) 0x508F2F7: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.58% (39,034,200B) 0x5603367: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.58% (39,034,200B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.58% (39,034,200B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.58% (39,034,200B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.58% (39,034,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.58% (39,034,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.58% (39,034,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.28% (34,515,708B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.28% (34,515,708B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.24% (33,882,942B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.24% (33,882,942B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.24% (33,882,942B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.24% (33,882,942B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | ->02.24% (33,882,942B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->00.04% (632,766B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->00.30% (4,518,492B) in 1+ places, all below ms_print's threshold (01.00%)
| ->01.86% (28,138,888B) 0x51F2440: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.86% (28,138,888B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.86% (28,138,888B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.86% (28,138,888B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.86% (28,138,888B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.86% (28,138,888B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.86% (28,138,888B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.86% (28,138,888B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->01.86% (28,138,888B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.47% (22,193,565B) in 189 places, all below massif's threshold (01.00%)
44 114,000,025,261 1,510,549,016 1,510,500,559 48,457 0
45 120,086,777,602 1,510,549,104 1,510,500,639 48,465 0
46 120,089,651,044 1,544,450,152 1,544,400,843 49,309 0
100.00% (1,544,400,843B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.45% (1,535,943,053B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->76.42% (1,180,246,040B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->76.42% (1,180,246,040B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->76.04% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->76.04% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->76.04% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->38.02% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | | ->38.02% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->38.02% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| ->09.93% (153,410,896B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->09.93% (153,410,896B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.42% (83,762,688B) 0x4FF1C5F: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.42% (83,762,688B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.35% (82,688,032B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->05.35% (82,688,032B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->05.35% (82,688,032B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.81% (43,371,200B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.81% (43,371,200B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.81% (43,371,200B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.81% (43,371,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.81% (43,371,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.81% (43,371,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.48% (38,350,720B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.48% (38,350,720B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.44% (37,647,680B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->02.44% (37,647,680B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->02.44% (37,647,680B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->02.44% (37,647,680B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | | ->02.44% (37,647,680B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | ->01.40% (21,686,880B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.40% (21,686,880B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.40% (21,685,600B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.40% (21,685,600B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.40% (21,685,600B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.40% (21,685,600B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.24% (19,175,360B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.24% (19,175,360B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.22% (18,823,840B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | | ->01.22% (18,823,840B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | | ->01.22% (18,823,840B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | | ->01.22% (18,823,840B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | | | ->01.22% (18,823,840B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | | | ->00.16% (2,510,240B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.14% (17,629,952B) in 3 places, all below massif's threshold (01.00%)
| | ->04.51% (69,648,208B) 0x4FF8EA3: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->04.51% (69,648,208B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->04.27% (65,883,440B) 0x53C0070: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->04.27% (65,883,440B) 0x553D255: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->03.41% (52,706,752B) 0x53BFE5F: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->03.41% (52,706,752B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->03.41% (52,706,752B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->03.41% (52,706,752B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->03.41% (52,706,752B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.19% (33,882,912B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.19% (33,882,912B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.19% (33,882,912B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.19% (33,882,912B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.19% (33,882,912B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | ->02.19% (33,882,912B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | ->01.22% (18,823,840B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.22% (18,823,840B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.22% (18,823,840B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->00.85% (13,176,688B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->00.24% (3,764,768B) in 1+ places, all below ms_print's threshold (01.00%)
| ->03.67% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->03.67% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->03.67% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->03.64% (56,277,776B) 0x51F256F: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.64% (56,277,776B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.64% (56,277,776B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.64% (56,277,776B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.64% (56,277,776B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.64% (56,277,776B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.64% (56,277,776B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.64% (56,277,776B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->03.64% (56,277,776B) 0x4048AA: main (main_petsc36.cc:2255)
| ->02.53% (39,034,200B) 0x5307655: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.53% (39,034,200B) 0x508F2F7: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.53% (39,034,200B) 0x5603367: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.53% (39,034,200B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.53% (39,034,200B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.53% (39,034,200B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.53% (39,034,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.53% (39,034,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.53% (39,034,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.23% (34,515,708B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.23% (34,515,708B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.19% (33,882,942B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.19% (33,882,942B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.19% (33,882,942B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.19% (33,882,942B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | ->02.19% (33,882,942B) 0x4048AA: main (main_petsc36.cc:2255)
| | ->00.29% (4,518,492B) in 1+ places, all below ms_print's threshold (01.00%)
| ->01.82% (28,138,888B) 0x51F2440: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.82% (28,138,888B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.82% (28,138,888B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.82% (28,138,888B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.82% (28,138,888B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.82% (28,138,888B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.82% (28,138,888B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.82% (28,138,888B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->01.82% (28,138,888B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.44% (22,212,149B) in 189 places, all below massif's threshold (01.00%)
->00.55% (8,457,790B) in 1+ places, all below ms_print's threshold (01.00%)
47 120,090,364,653 1,548,217,088 1,548,167,663 49,425 0
48 180,882,674,722 1,548,217,448 1,548,168,039 49,409 0
49 180,883,391,417 1,555,750,808 1,555,701,207 49,601 0
50 180,883,754,195 1,563,284,344 1,563,234,583 49,761 0
100.00% (1,563,234,583B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.46% (1,554,776,793B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->75.50% (1,180,246,040B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->75.50% (1,180,246,040B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->75.13% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->75.13% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->75.13% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->37.56% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | | ->37.56% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->37.56% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| | ->00.37% (5,809,204B) in 1+ places, all below ms_print's threshold (01.00%)
| ->11.02% (172,234,736B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->11.02% (172,234,736B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.66% (88,472,048B) 0x4FF8EA3: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.66% (88,472,048B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.42% (84,707,280B) 0x53C0070: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->05.42% (84,707,280B) 0x553D255: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->04.58% (71,530,592B) 0x53BFE5F: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->04.58% (71,530,592B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->04.58% (71,530,592B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->04.58% (71,530,592B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->04.58% (71,530,592B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->03.37% (52,706,752B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->03.37% (52,706,752B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->03.37% (52,706,752B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->03.37% (52,706,752B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->03.37% (52,706,752B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | ->03.37% (52,706,752B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | ->01.20% (18,823,840B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.20% (18,823,840B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.20% (18,823,840B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.20% (18,823,840B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | ->01.20% (18,823,840B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | ->00.84% (13,176,688B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->05.36% (83,762,688B) 0x4FF1C5F: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.36% (83,762,688B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.29% (82,688,032B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.29% (82,688,032B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.29% (82,688,032B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.77% (43,371,200B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.77% (43,371,200B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.77% (43,371,200B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.77% (43,371,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.77% (43,371,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.77% (43,371,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.45% (38,350,720B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.45% (38,350,720B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.41% (37,647,680B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.41% (37,647,680B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.41% (37,647,680B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.41% (37,647,680B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | ->02.41% (37,647,680B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | | ->00.04% (703,040B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | | ->00.32% (5,020,480B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->01.39% (21,686,880B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.39% (21,686,880B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.39% (21,685,600B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.39% (21,685,600B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.39% (21,685,600B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.39% (21,685,600B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.23% (19,175,360B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.23% (19,175,360B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.20% (18,823,840B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.20% (18,823,840B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.20% (18,823,840B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->01.13% (17,629,952B) in 3 places, all below massif's threshold (01.00%)
| ->03.62% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->03.62% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->03.62% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->03.60% (56,277,776B) 0x51F256F: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.60% (56,277,776B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.60% (56,277,776B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.60% (56,277,776B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.60% (56,277,776B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.60% (56,277,776B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.60% (56,277,776B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.60% (56,277,776B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->03.60% (56,277,776B) 0x4048AA: main (main_petsc36.cc:2255)
| ->02.50% (39,034,200B) 0x5307655: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.50% (39,034,200B) 0x508F2F7: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.50% (39,034,200B) 0x5603367: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.50% (39,034,200B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.50% (39,034,200B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.50% (39,034,200B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.50% (39,034,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.50% (39,034,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.50% (39,034,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.21% (34,515,708B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.21% (34,515,708B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.17% (33,882,942B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.17% (33,882,942B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.17% (33,882,942B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.17% (33,882,942B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | ->02.17% (33,882,942B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.80% (28,138,888B) 0x51F2440: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.80% (28,138,888B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.80% (28,138,888B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.80% (28,138,888B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.80% (28,138,888B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.80% (28,138,888B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.80% (28,138,888B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.80% (28,138,888B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->01.80% (28,138,888B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.42% (22,222,049B) in 189 places, all below massif's threshold (01.00%)
->00.54% (8,457,790B) in 1+ places, all below ms_print's threshold (01.00%)
n time(i) total(B) useful-heap(B) extra-heap(B) stacks(B)
51 180,884,467,808 1,567,051,280 1,567,001,403 49,877 0
52 180,885,185,402 1,574,584,928 1,574,534,867 50,061 0
53 180,885,548,180 1,582,118,464 1,582,068,243 50,221 0
100.00% (1,582,068,243B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.46% (1,573,610,453B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->74.60% (1,180,246,040B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->74.60% (1,180,246,040B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->74.23% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->74.23% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->74.23% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->37.12% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | | ->37.12% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->37.12% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| ->12.08% (191,058,576B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->12.08% (191,058,576B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->06.78% (107,295,888B) 0x4FF8EA3: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->06.78% (107,295,888B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->06.54% (103,531,120B) 0x53C0070: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->06.54% (103,531,120B) 0x553D255: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->05.71% (90,354,432B) 0x53BFE5F: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->05.71% (90,354,432B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->05.71% (90,354,432B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->05.71% (90,354,432B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->05.71% (90,354,432B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->04.52% (71,530,592B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->04.52% (71,530,592B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->04.52% (71,530,592B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->04.52% (71,530,592B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->04.52% (71,530,592B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | ->04.52% (71,530,592B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | ->01.19% (18,823,840B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.19% (18,823,840B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.19% (18,823,840B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.19% (18,823,840B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | ->01.19% (18,823,840B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | ->00.83% (13,176,688B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->05.29% (83,762,688B) 0x4FF1C5F: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.29% (83,762,688B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.23% (82,688,032B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.23% (82,688,032B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.23% (82,688,032B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.74% (43,371,200B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.74% (43,371,200B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.74% (43,371,200B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.74% (43,371,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.74% (43,371,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.74% (43,371,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.42% (38,350,720B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.42% (38,350,720B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.38% (37,647,680B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.38% (37,647,680B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.38% (37,647,680B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.38% (37,647,680B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | ->02.38% (37,647,680B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->01.37% (21,686,880B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.37% (21,686,880B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.37% (21,685,600B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.37% (21,685,600B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.37% (21,685,600B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.37% (21,685,600B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.21% (19,175,360B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.21% (19,175,360B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.19% (18,823,840B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.19% (18,823,840B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.19% (18,823,840B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->01.11% (17,629,952B) in 3 places, all below massif's threshold (01.00%)
| ->03.58% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->03.58% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->03.58% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->03.56% (56,277,776B) 0x51F256F: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.56% (56,277,776B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.56% (56,277,776B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.56% (56,277,776B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.56% (56,277,776B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.56% (56,277,776B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.56% (56,277,776B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.56% (56,277,776B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->03.56% (56,277,776B) 0x4048AA: main (main_petsc36.cc:2255)
| ->02.47% (39,034,200B) 0x5307655: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.47% (39,034,200B) 0x508F2F7: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.47% (39,034,200B) 0x5603367: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.47% (39,034,200B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.47% (39,034,200B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.47% (39,034,200B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.47% (39,034,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.47% (39,034,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.47% (39,034,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.18% (34,515,708B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.18% (34,515,708B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.14% (33,882,942B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.14% (33,882,942B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.14% (33,882,942B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.14% (33,882,942B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | ->02.14% (33,882,942B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.78% (28,138,888B) 0x51F2440: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.78% (28,138,888B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.78% (28,138,888B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.78% (28,138,888B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.78% (28,138,888B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.78% (28,138,888B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.78% (28,138,888B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.78% (28,138,888B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->01.78% (28,138,888B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.41% (22,231,869B) in 189 places, all below massif's threshold (01.00%)
->00.53% (8,457,790B) in 1+ places, all below ms_print's threshold (01.00%)
54 180,886,261,793 1,585,885,400 1,585,835,063 50,337 0
55 241,478,135,876 1,585,885,776 1,585,835,439 50,337 0
56 241,478,852,571 1,593,419,136 1,593,368,607 50,529 0
57 241,479,215,349 1,600,952,672 1,600,901,983 50,689 0
100.00% (1,600,901,983B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.47% (1,592,444,193B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->73.72% (1,180,246,040B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->73.72% (1,180,246,040B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->73.36% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->73.36% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->73.36% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->36.68% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | | ->36.68% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->36.68% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| | ->00.36% (5,809,204B) in 1+ places, all below ms_print's threshold (01.00%)
| ->13.11% (209,882,416B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->13.11% (209,882,416B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->07.88% (126,119,728B) 0x4FF8EA3: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->07.88% (126,119,728B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->07.64% (122,354,960B) 0x53C0070: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->07.64% (122,354,960B) 0x553D255: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->06.82% (109,178,272B) 0x53BFE5F: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->06.82% (109,178,272B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->06.82% (109,178,272B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->06.82% (109,178,272B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->06.82% (109,178,272B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->05.64% (90,354,432B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->05.64% (90,354,432B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->05.64% (90,354,432B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->05.64% (90,354,432B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->05.64% (90,354,432B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | ->05.64% (90,354,432B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | ->01.18% (18,823,840B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.18% (18,823,840B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.18% (18,823,840B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.18% (18,823,840B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | ->01.18% (18,823,840B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | ->00.82% (13,176,688B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->05.23% (83,762,688B) 0x4FF1C5F: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.23% (83,762,688B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.16% (82,688,032B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.16% (82,688,032B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.16% (82,688,032B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.71% (43,371,200B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.71% (43,371,200B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.71% (43,371,200B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.71% (43,371,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.71% (43,371,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.71% (43,371,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.40% (38,350,720B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.40% (38,350,720B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.35% (37,647,680B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.35% (37,647,680B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.35% (37,647,680B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.35% (37,647,680B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | ->02.35% (37,647,680B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | ->00.31% (5,020,480B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->00.00% (0B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->01.35% (21,686,880B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.35% (21,686,880B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.35% (21,685,600B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.35% (21,685,600B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.35% (21,685,600B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.35% (21,685,600B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.20% (19,175,360B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.20% (19,175,360B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.18% (18,823,840B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.18% (18,823,840B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.18% (18,823,840B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->00.00% (1,280B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->01.10% (17,629,952B) in 3 places, all below massif's threshold (01.00%)
| | ->00.07% (1,074,656B) in 1+ places, all below ms_print's threshold (01.00%)
| ->03.54% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->03.54% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->03.54% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->03.52% (56,277,776B) 0x51F256F: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.52% (56,277,776B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.52% (56,277,776B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.52% (56,277,776B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.52% (56,277,776B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.52% (56,277,776B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.52% (56,277,776B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.52% (56,277,776B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->03.52% (56,277,776B) 0x4048AA: main (main_petsc36.cc:2255)
| ->02.44% (39,034,200B) 0x5307655: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.44% (39,034,200B) 0x508F2F7: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.44% (39,034,200B) 0x5603367: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.44% (39,034,200B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.44% (39,034,200B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.44% (39,034,200B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.44% (39,034,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.44% (39,034,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.44% (39,034,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.16% (34,515,708B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.16% (34,515,708B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.12% (33,882,942B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.12% (33,882,942B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.12% (33,882,942B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.12% (33,882,942B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | ->02.12% (33,882,942B) 0x4048AA: main (main_petsc36.cc:2255)
| | ->00.28% (4,518,492B) in 1+ places, all below ms_print's threshold (01.00%)
| ->01.76% (28,138,888B) 0x51F2440: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.76% (28,138,888B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.76% (28,138,888B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.76% (28,138,888B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.76% (28,138,888B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.76% (28,138,888B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.76% (28,138,888B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.76% (28,138,888B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->01.76% (28,138,888B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.39% (22,241,769B) in 189 places, all below massif's threshold (01.00%)
58 241,479,928,962 1,604,719,608 1,604,668,803 50,805 0
59 241,480,646,554 1,612,253,256 1,612,202,267 50,989 0
60 241,481,009,330 1,619,786,792 1,619,735,643 51,149 0
100.00% (1,619,735,643B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.47% (1,611,277,853B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->72.86% (1,180,246,040B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->72.86% (1,180,246,040B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->72.51% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->72.51% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->72.51% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->36.25% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | | ->36.25% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->36.25% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| ->14.12% (228,706,256B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->14.12% (228,706,256B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->08.95% (144,943,568B) 0x4FF8EA3: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->08.95% (144,943,568B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->08.72% (141,178,800B) 0x53C0070: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->08.72% (141,178,800B) 0x553D255: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->07.90% (128,002,112B) 0x53BFE5F: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->07.90% (128,002,112B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->07.90% (128,002,112B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->07.90% (128,002,112B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->07.90% (128,002,112B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->06.74% (109,178,272B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->06.74% (109,178,272B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->06.74% (109,178,272B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->06.74% (109,178,272B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->06.74% (109,178,272B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | ->06.74% (109,178,272B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | ->01.16% (18,823,840B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.16% (18,823,840B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.16% (18,823,840B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.16% (18,823,840B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | ->01.16% (18,823,840B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | ->00.81% (13,176,688B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->00.23% (3,764,768B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->05.17% (83,762,688B) 0x4FF1C5F: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.17% (83,762,688B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.10% (82,688,032B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.10% (82,688,032B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.10% (82,688,032B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.68% (43,371,200B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.68% (43,371,200B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.68% (43,371,200B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.68% (43,371,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.68% (43,371,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.68% (43,371,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.37% (38,350,720B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.37% (38,350,720B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.32% (37,647,680B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.32% (37,647,680B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.32% (37,647,680B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.32% (37,647,680B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | ->02.32% (37,647,680B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->01.34% (21,686,880B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.34% (21,686,880B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.34% (21,685,600B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.34% (21,685,600B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.34% (21,685,600B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.34% (21,685,600B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.18% (19,175,360B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.18% (19,175,360B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.16% (18,823,840B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.16% (18,823,840B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.16% (18,823,840B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->00.15% (2,510,240B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->01.09% (17,629,952B) in 3 places, all below massif's threshold (01.00%)
| ->03.50% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->03.50% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->03.50% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->03.47% (56,277,776B) 0x51F256F: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.47% (56,277,776B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.47% (56,277,776B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.47% (56,277,776B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.47% (56,277,776B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.47% (56,277,776B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.47% (56,277,776B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.47% (56,277,776B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->03.47% (56,277,776B) 0x4048AA: main (main_petsc36.cc:2255)
| ->02.41% (39,034,200B) 0x5307655: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.41% (39,034,200B) 0x508F2F7: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.41% (39,034,200B) 0x5603367: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.41% (39,034,200B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.41% (39,034,200B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.41% (39,034,200B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.41% (39,034,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.41% (39,034,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.41% (39,034,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.13% (34,515,708B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.13% (34,515,708B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.09% (33,882,942B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.09% (33,882,942B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.09% (33,882,942B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.09% (33,882,942B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | ->02.09% (33,882,942B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.74% (28,138,888B) 0x51F2440: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.74% (28,138,888B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.74% (28,138,888B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.74% (28,138,888B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.74% (28,138,888B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.74% (28,138,888B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.74% (28,138,888B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.74% (28,138,888B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->01.74% (28,138,888B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.37% (22,251,589B) in 189 places, all below massif's threshold (01.00%)
->00.52% (8,457,790B) in 1+ places, all below ms_print's threshold (01.00%)
61 241,481,722,939 1,623,553,728 1,623,502,463 51,265 0
62 302,564,355,117 1,623,554,104 1,623,502,839 51,265 0
63 302,565,071,808 1,631,087,464 1,631,036,007 51,457 0
64 302,565,434,584 1,638,621,000 1,638,569,383 51,617 0
100.00% (1,638,569,383B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.48% (1,630,111,593B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->72.03% (1,180,246,040B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->72.03% (1,180,246,040B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->71.67% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->71.67% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->71.67% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->35.84% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | | ->35.84% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->35.84% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| | ->00.35% (5,809,204B) in 1+ places, all below ms_print's threshold (01.00%)
| ->15.11% (247,530,096B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->15.11% (247,530,096B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->09.99% (163,767,408B) 0x4FF8EA3: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->09.99% (163,767,408B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->09.76% (160,002,640B) 0x53C0070: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->09.76% (160,002,640B) 0x553D255: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->08.96% (146,825,952B) 0x53BFE5F: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->08.96% (146,825,952B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->08.96% (146,825,952B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->08.96% (146,825,952B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->08.96% (146,825,952B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->07.81% (128,002,112B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->07.81% (128,002,112B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->07.81% (128,002,112B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->07.81% (128,002,112B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->07.81% (128,002,112B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | ->07.81% (128,002,112B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | ->01.15% (18,823,840B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.15% (18,823,840B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.15% (18,823,840B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.15% (18,823,840B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | ->01.15% (18,823,840B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | ->00.80% (13,176,688B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->05.11% (83,762,688B) 0x4FF1C5F: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.11% (83,762,688B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.05% (82,688,032B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.05% (82,688,032B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->05.05% (82,688,032B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.65% (43,371,200B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.65% (43,371,200B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.65% (43,371,200B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.65% (43,371,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.65% (43,371,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.65% (43,371,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.34% (38,350,720B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.34% (38,350,720B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.30% (37,647,680B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.30% (37,647,680B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.30% (37,647,680B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.30% (37,647,680B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | ->02.30% (37,647,680B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->01.32% (21,686,880B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.32% (21,686,880B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.32% (21,685,600B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.32% (21,685,600B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.32% (21,685,600B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.32% (21,685,600B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.17% (19,175,360B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.17% (19,175,360B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.15% (18,823,840B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.15% (18,823,840B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.15% (18,823,840B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->00.02% (351,520B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->01.08% (17,629,952B) in 3 places, all below massif's threshold (01.00%)
| ->03.46% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->03.46% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->03.46% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->03.43% (56,277,776B) 0x51F256F: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.43% (56,277,776B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.43% (56,277,776B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.43% (56,277,776B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.43% (56,277,776B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.43% (56,277,776B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.43% (56,277,776B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.43% (56,277,776B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->03.43% (56,277,776B) 0x4048AA: main (main_petsc36.cc:2255)
| ->02.38% (39,034,200B) 0x5307655: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.38% (39,034,200B) 0x508F2F7: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.38% (39,034,200B) 0x5603367: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.38% (39,034,200B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.38% (39,034,200B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.38% (39,034,200B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.38% (39,034,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.38% (39,034,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.38% (39,034,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.11% (34,515,708B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.11% (34,515,708B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.07% (33,882,942B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.07% (33,882,942B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.07% (33,882,942B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.07% (33,882,942B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | ->02.07% (33,882,942B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->00.04% (632,766B) in 1+ places, all below ms_print's threshold (01.00%)
| ->01.72% (28,138,888B) 0x51F2440: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.72% (28,138,888B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.72% (28,138,888B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.72% (28,138,888B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.72% (28,138,888B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.72% (28,138,888B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.72% (28,138,888B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.72% (28,138,888B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->01.72% (28,138,888B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.36% (22,261,489B) in 189 places, all below massif's threshold (01.00%)
65 302,566,148,193 1,642,387,936 1,642,336,203 51,733 0
66 302,566,865,783 1,649,921,584 1,649,869,667 51,917 0
67 302,567,228,559 1,657,455,120 1,657,403,043 52,077 0
100.00% (1,657,403,043B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.49% (1,648,945,253B) 0x4F3E598: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->71.21% (1,180,246,040B) 0x52B1D78: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->71.21% (1,180,246,040B) 0x52B3D19: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->70.86% (1,174,436,836B) 0x53EEE0C: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->70.86% (1,174,436,836B) 0x53E4FB5: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->70.86% (1,174,436,836B) 0x553AA24: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->35.43% (587,218,418B) 0x40614B: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2028)
| | | | ->35.43% (587,218,418B) 0x4048AA: main (main_petsc36.cc:2255)
| | | ->35.43% (587,218,418B) 0x40616C: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2029)
| ->16.07% (266,353,936B) 0x4FF7CFF: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->16.07% (266,353,936B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->11.02% (182,591,248B) 0x4FF8EA3: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->11.02% (182,591,248B) 0x5008681: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->10.79% (178,826,480B) 0x53C0070: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->10.79% (178,826,480B) 0x553D255: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->09.99% (165,649,792B) 0x53BFE5F: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->09.99% (165,649,792B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->09.99% (165,649,792B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->09.99% (165,649,792B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->09.99% (165,649,792B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->08.86% (146,825,952B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->08.86% (146,825,952B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->08.86% (146,825,952B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->08.86% (146,825,952B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->08.86% (146,825,952B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | ->08.86% (146,825,952B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | ->01.14% (18,823,840B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.14% (18,823,840B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.14% (18,823,840B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.14% (18,823,840B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | ->01.14% (18,823,840B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | ->00.79% (13,176,688B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->05.05% (83,762,688B) 0x4FF1C5F: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->05.05% (83,762,688B) 0x5007F69: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->04.99% (82,688,032B) 0x500832F: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->04.99% (82,688,032B) 0x50050D5: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->04.99% (82,688,032B) 0x570A400: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.62% (43,371,200B) 0x56AF984: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.62% (43,371,200B) 0x56AEFB0: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.62% (43,371,200B) 0x56AEC7A: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.62% (43,371,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.62% (43,371,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.62% (43,371,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->02.31% (38,350,720B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.31% (38,350,720B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->02.27% (37,647,680B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.27% (37,647,680B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.27% (37,647,680B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->02.27% (37,647,680B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | | | | ->02.27% (37,647,680B) 0x4048AA: main (main_petsc36.cc:2255)
| | | | | ->00.30% (5,020,480B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->01.31% (21,686,880B) 0x56AE79B: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.31% (21,686,880B) 0x5701286: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->01.31% (21,685,600B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | ->01.31% (21,685,600B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.31% (21,685,600B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.31% (21,685,600B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | ->01.16% (19,175,360B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.16% (19,175,360B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | ->01.14% (18,823,840B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.14% (18,823,840B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | | | | | ->01.14% (18,823,840B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->01.06% (17,629,952B) in 3 places, all below massif's threshold (01.00%)
| | ->00.06% (1,074,656B) in 1+ places, all below ms_print's threshold (01.00%)
| ->03.42% (56,623,104B) 0x417587: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc36.cc:75)
| | ->03.42% (56,623,104B) 0x404CBE: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:1860)
| | ->03.42% (56,623,104B) 0x4048AA: main (main_petsc36.cc:2255)
| ->03.40% (56,277,776B) 0x51F256F: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.40% (56,277,776B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.40% (56,277,776B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.40% (56,277,776B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.40% (56,277,776B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.40% (56,277,776B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.40% (56,277,776B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->03.40% (56,277,776B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->03.40% (56,277,776B) 0x4048AA: main (main_petsc36.cc:2255)
| ->02.36% (39,034,200B) 0x5307655: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.36% (39,034,200B) 0x508F2F7: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.36% (39,034,200B) 0x5603367: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.36% (39,034,200B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.36% (39,034,200B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.36% (39,034,200B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.36% (39,034,200B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.36% (39,034,200B) 0x56F6F73: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.36% (39,034,200B) 0x56818FA: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->02.08% (34,515,708B) 0x5682B76: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.08% (34,515,708B) 0x5698127: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | ->02.04% (33,882,942B) 0x570D0E0: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.04% (33,882,942B) 0x56AEC65: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.04% (33,882,942B) 0x56FDF2E: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | | | ->02.04% (33,882,942B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | | | ->02.04% (33,882,942B) 0x4048AA: main (main_petsc36.cc:2255)
| | ->00.27% (4,518,492B) in 1+ places, all below ms_print's threshold (01.00%)
| ->01.70% (28,138,888B) 0x51F2440: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.70% (28,138,888B) 0x51F192E: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.70% (28,138,888B) 0x509B68C: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.70% (28,138,888B) 0x568798E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.70% (28,138,888B) 0x5693D68: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.70% (28,138,888B) 0x57014F7: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.70% (28,138,888B) 0x56FDBFB: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| | ->01.70% (28,138,888B) 0x4069AB: solve_stokes_3d_coupled(int, int, int) (main_petsc36.cc:2133)
| | ->01.70% (28,138,888B) 0x4048AA: main (main_petsc36.cc:2255)
| ->01.34% (22,271,309B) in 189 places, all below massif's threshold (01.00%)
->00.51% (8,457,790B) in 1+ places, all below ms_print's threshold (01.00%)
68 302,567,942,168 1,661,222,056 1,661,169,863 52,193 0
69 327,133,263,563 1,661,222,384 1,661,170,189 52,195 0
70 327,134,801,224 1,661,225,528 1,661,172,873 52,655 0
71 327,135,484,200 1,661,226,648 1,661,173,805 52,843 0
72 327,136,002,907 1,320,812,376 1,320,775,719 36,657 0
73 327,136,533,387 8,543,760 8,531,809 11,951 0
74 327,137,076,493 8,543,856 8,531,825 12,031 0
75 327,137,613,732 8,543,856 8,531,825 12,031 0
76 327,138,154,123 8,543,856 8,531,825 12,031 0
77 327,138,673,343 8,543,856 8,531,825 12,031 0
99.86% (8,531,825B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->98.21% (8,391,248B) 0xA051F04: MPIDI_CH3I_Seg_commit (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->98.21% (8,391,248B) 0xA05E0D2: MPID_nem_init_ckpt (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->98.21% (8,391,248B) 0xA05FCA5: MPID_nem_init (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->98.21% (8,391,248B) 0x9F1106E: MPIDI_CH3_Init (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->98.21% (8,391,248B) 0xA04EBAB: MPID_Init (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->98.21% (8,391,248B) 0xA02538D: MPIR_Init_thread (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->98.21% (8,391,248B) 0xA024D98: PMPI_Init_thread (in /gpfs4l/smplocal/intel/impi/4.1.1.036/intel64/lib/libmpi.so.4.1)
| ->98.21% (8,391,248B) 0x4F1D607: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.6.2/ada-real/lib/libpetsc.so.3.6.2)
| ->98.21% (8,391,248B) 0x404761: main (main_petsc36.cc:2242)
->01.65% (140,577B) in 80 places, all below massif's threshold (01.00%)
78 327,139,191,175 8,543,832 8,531,817 12,015 0
79 327,139,714,049 8,543,856 8,531,825 12,031 0
80 327,140,232,002 8,543,832 8,531,817 12,015 0
81 327,140,755,852 49,600 47,540 2,060 0
Command: ./ex42 -mx 48 -my 48 -mz 48 -stokes_ksp_monitor_blocks 0 -model 0 -levels 3
Massif arguments: (none)
ms_print arguments: massif.out.47240
GB
1.674^ :::
0 +----------------------------------------------------------------------->Ti
0 1.100
Number of snapshots: 75
Detailed snapshots: [22, 36, 45 (peak), 54, 64, 74]
n time(i) total(B) useful-heap(B) extra-heap(B) stacks(B)
0 0 0 0 0 0
1 4,980,608,775 661,628,576 661,566,530 62,046 0
2 53,659,329,974 661,628,576 661,566,530 62,046 0
3 58,343,759,694 1,258,402,064 1,258,334,906 67,158 0
4 107,022,473,279 1,258,386,616 1,258,319,478 67,138 0
5 107,808,983,916 1,269,736,560 1,269,669,042 67,518 0
6 262,297,899,894 1,269,712,584 1,269,645,086 67,498 0
7 262,297,915,219 1,269,736,560 1,269,669,042 67,518 0
8 395,956,080,886 1,269,712,584 1,269,645,086 67,498 0
9 410,013,623,726 1,379,141,240 1,379,051,510 89,730 0
10 436,485,513,646 1,379,894,488 1,379,804,718 89,770 0
11 444,589,783,484 1,455,207,200 1,455,111,954 95,246 0
12 471,061,673,275 1,455,960,448 1,455,865,162 95,286 0
13 490,475,678,488 1,593,525,776 1,593,399,454 126,322 0
14 513,251,901,897 1,608,152,744 1,608,018,094 134,650 0
15 531,294,375,247 1,608,155,584 1,608,020,914 134,670 0
16 558,853,194,437 1,645,938,808 1,645,802,718 136,090 0
17 576,440,011,933 1,645,938,808 1,645,802,718 136,090 0
18 600,336,201,777 1,645,938,808 1,645,802,718 136,090 0
19 614,937,032,875 1,645,938,808 1,645,802,718 136,090 0
20 637,484,776,453 1,645,938,808 1,645,802,718 136,090 0
21 659,407,063,651 1,645,938,808 1,645,802,718 136,090 0
22 676,265,624,554 1,668,604,104 1,668,467,230 136,874 0
99.99% (1,668,467,230B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.73% (1,664,055,560B) 0x4FFCEA1: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->99.73% (1,664,055,560B) 0x50006E8: PetscTrMallocDefault (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->99.62% (1,662,324,180B) 0x4FFE767: PetscMallocA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->70.82% (1,181,786,648B) 0x583AC5B: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->70.73% (1,180,265,248B) 0x5839FF5: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->70.38% (1,174,446,424B) 0x5B6327B: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->70.38% (1,174,446,424B) 0x5B5951F: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->70.38% (1,174,446,424B) 0x5EBC894: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->35.19% (587,223,212B) 0x417497: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2026)
| | | | | | ->35.19% (587,223,212B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | ->35.19% (587,223,212B) 0x41750B: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2027)
| | | | ->00.35% (5,818,824B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->00.09% (1,521,400B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->10.84% (180,804,084B) 0x52A9E6E: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->10.84% (180,804,084B) 0x52EC6A1: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->05.81% (96,905,208B) 0x52C2880: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->05.81% (96,905,208B) 0x52EC6A1: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->05.58% (93,138,836B) 0x5B0C608: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->05.58% (93,138,836B) 0x5EB8BE6: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->04.74% (79,093,812B) 0x5B0BD6D: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->04.74% (79,093,812B) 0x52DBF2E: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->04.74% (79,093,812B) 0x52E058A: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->04.74% (79,093,812B) 0x52DCD2D: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->04.74% (79,093,812B) 0x635A9B1: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->03.61% (60,261,952B) 0x62C4F9F: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->03.61% (60,261,952B) 0x62C19CD: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->03.61% (60,261,952B) 0x62C2540: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->03.61% (60,261,952B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->03.61% (60,261,952B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | | | ->03.61% (60,261,952B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | | ->01.13% (18,831,860B) 0x62C0C8D: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.13% (18,831,860B) 0x633021B: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.13% (18,831,860B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.13% (18,831,860B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | | ->01.13% (18,831,860B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | ->00.84% (14,045,024B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->00.23% (3,766,372B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->05.03% (83,898,876B) 0x529E375: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->05.03% (83,898,876B) 0x52DBF2E: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->04.96% (82,814,820B) 0x52E058A: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->04.96% (82,814,820B) 0x52DCD2D: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->04.96% (82,814,820B) 0x635A9B1: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->02.60% (43,434,400B) 0x62C4F9F: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.60% (43,434,400B) 0x62C19CD: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.60% (43,434,400B) 0x62C2540: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.60% (43,434,400B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.60% (43,434,400B) 0x62A6082: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->02.60% (43,434,400B) 0x61990DE: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->02.30% (38,382,800B) 0x619E2A5: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->02.30% (38,382,800B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->02.26% (37,663,720B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.26% (37,663,720B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.26% (37,663,720B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.26% (37,663,720B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.26% (37,663,720B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | | | | ->02.26% (37,663,720B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | | | ->00.04% (719,080B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | | | ->00.30% (5,051,600B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.30% (21,717,200B) 0x62C0C8D: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.30% (21,717,200B) 0x633021B: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.30% (21,717,200B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.30% (21,717,200B) 0x62A6082: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.30% (21,717,200B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.30% (21,717,200B) 0x61990DE: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.15% (19,191,400B) 0x619E2A5: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->01.15% (19,191,400B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->01.13% (18,831,860B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->01.13% (18,831,860B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->01.13% (18,831,860B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->01.13% (18,831,860B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->00.02% (359,540B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | | | ->00.15% (2,525,800B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.06% (17,663,220B) in 3 places, all below massif's threshold (01.00%)
| | | ->00.06% (1,084,056B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->06.75% (112,562,000B) 0x56C4881: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->06.75% (112,562,000B) 0x56C5A3B: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->06.75% (112,562,000B) 0x541F3A9: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->06.75% (112,562,000B) 0x5433AEC: MatGalerkin (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.37% (56,281,000B) 0x61A23A0: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.37% (56,281,000B) 0x61ED10C: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.37% (56,281,000B) 0x6330A89: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.37% (56,281,000B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.37% (56,281,000B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | ->03.37% (56,281,000B) 0x419ADD: main (main_petsc310.cc:2254)
| | | ->03.37% (56,281,000B) 0x61A244E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->03.39% (56,624,708B) 0x403FE0: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc310.cc:75)
| | | ->03.39% (56,624,708B) 0x415FE6: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:1858)
| | | ->03.39% (56,624,708B) 0x419ADD: main (main_petsc310.cc:2254)
| | ->03.37% (56,284,240B) 0x56C46D6: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.37% (56,284,240B) 0x56C5A3B: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.37% (56,284,240B) 0x541F3A9: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.37% (56,284,240B) 0x5433AEC: MatGalerkin (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->01.69% (28,142,120B) 0x61A23A0: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.69% (28,142,120B) 0x61ED10C: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.69% (28,142,120B) 0x6330A89: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.69% (28,142,120B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.69% (28,142,120B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | ->01.69% (28,142,120B) 0x419ADD: main (main_petsc310.cc:2254)
| | | ->01.69% (28,142,120B) 0x61A244E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->02.34% (39,052,464B) 0x58AA01F: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.34% (39,052,464B) 0x53E6A04: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.34% (39,052,464B) 0x60260A2: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.34% (39,052,464B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.34% (39,052,464B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.34% (39,052,464B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.34% (39,052,464B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.34% (39,052,464B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.34% (39,052,464B) 0x62A6082: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.34% (39,052,464B) 0x61990DE: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.07% (34,525,272B) 0x619E2A5: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->02.07% (34,525,272B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->02.03% (33,887,724B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.03% (33,887,724B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.03% (33,887,724B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.03% (33,887,724B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.03% (33,887,724B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | ->02.03% (33,887,724B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | ->00.04% (637,548B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->00.27% (4,527,192B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->02.11% (35,210,036B) in 189 places, all below massif's threshold (01.00%)
| ->00.10% (1,731,380B) in 1+ places, all below ms_print's threshold (01.00%)
->00.26% (4,411,670B) in 1+ places, all below ms_print's threshold (01.00%)
23 688,869,472,856 1,683,722,032 1,683,584,522 137,510 0
24 706,846,779,285 1,683,722,032 1,683,584,522 137,510 0
25 734,772,531,658 1,683,722,032 1,683,584,522 137,510 0
26 753,089,886,037 1,683,722,032 1,683,584,522 137,510 0
27 770,117,739,409 1,683,722,032 1,683,584,522 137,510 0
28 794,894,660,656 1,683,722,032 1,683,584,522 137,510 0
29 808,203,400,071 1,683,722,032 1,683,584,522 137,510 0
30 826,475,260,753 1,721,505,256 1,721,366,326 138,930 0
31 851,341,932,673 1,721,505,256 1,721,366,326 138,930 0
32 878,754,667,235 1,721,505,256 1,721,366,326 138,930 0
33 892,704,562,674 1,721,505,256 1,721,366,326 138,930 0
34 907,360,934,944 1,721,505,256 1,721,366,326 138,930 0
35 934,847,264,351 1,721,505,256 1,721,366,326 138,930 0
36 955,723,849,888 1,744,170,552 1,744,030,838 139,714 0
99.99% (1,744,030,838B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.74% (1,739,619,168B) 0x4FFCEA1: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->99.74% (1,739,619,168B) 0x50006E8: PetscTrMallocDefault (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->99.64% (1,737,887,788B) 0x4FFE767: PetscMallocA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->67.76% (1,181,786,648B) 0x583AC5B: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->67.67% (1,180,265,248B) 0x5839FF5: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->67.34% (1,174,446,424B) 0x5B6327B: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->67.34% (1,174,446,424B) 0x5B5951F: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->67.34% (1,174,446,424B) 0x5EBC894: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->33.67% (587,223,212B) 0x417497: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2026)
| | | | | | ->33.67% (587,223,212B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | ->33.67% (587,223,212B) 0x41750B: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2027)
| | | | ->00.33% (5,818,824B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->14.69% (256,131,524B) 0x52A9E6E: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->14.69% (256,131,524B) 0x52EC6A1: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->09.87% (172,232,648B) 0x52C2880: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->09.87% (172,232,648B) 0x52EC6A1: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->09.66% (168,466,276B) 0x5B0C608: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->09.66% (168,466,276B) 0x5EB8BE6: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->08.85% (154,421,252B) 0x5B0BD6D: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->08.85% (154,421,252B) 0x52DBF2E: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->08.85% (154,421,252B) 0x52E058A: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->08.85% (154,421,252B) 0x52DCD2D: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->08.85% (154,421,252B) 0x635A9B1: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->07.77% (135,589,392B) 0x62C4F9F: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->07.77% (135,589,392B) 0x62C19CD: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->07.77% (135,589,392B) 0x62C2540: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->07.77% (135,589,392B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->07.77% (135,589,392B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | | | ->07.77% (135,589,392B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | | ->01.08% (18,831,860B) 0x62C0C8D: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.08% (18,831,860B) 0x633021B: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.08% (18,831,860B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.08% (18,831,860B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | | ->01.08% (18,831,860B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | ->00.81% (14,045,024B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->00.22% (3,766,372B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->04.81% (83,898,876B) 0x529E375: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->04.81% (83,898,876B) 0x52DBF2E: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->04.75% (82,814,820B) 0x52E058A: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->04.75% (82,814,820B) 0x52DCD2D: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->04.75% (82,814,820B) 0x635A9B1: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->02.49% (43,434,400B) 0x62C4F9F: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.49% (43,434,400B) 0x62C19CD: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.49% (43,434,400B) 0x62C2540: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.49% (43,434,400B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.49% (43,434,400B) 0x62A6082: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->02.49% (43,434,400B) 0x61990DE: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->02.20% (38,382,800B) 0x619E2A5: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->02.20% (38,382,800B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->02.16% (37,663,720B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.16% (37,663,720B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.16% (37,663,720B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.16% (37,663,720B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.16% (37,663,720B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | | | | ->02.16% (37,663,720B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | | ->00.29% (5,051,600B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | | ->00.00% (0B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.25% (21,717,200B) 0x62C0C8D: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.25% (21,717,200B) 0x633021B: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.25% (21,717,200B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.25% (21,717,200B) 0x62A6082: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.25% (21,717,200B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.25% (21,717,200B) 0x61990DE: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.10% (19,191,400B) 0x619E2A5: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->01.10% (19,191,400B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->01.08% (18,831,860B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->01.08% (18,831,860B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->01.08% (18,831,860B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->01.08% (18,831,860B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->00.14% (2,525,800B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.01% (17,663,220B) in 3 places, all below massif's threshold (01.00%)
| | ->06.45% (112,562,000B) 0x56C4881: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->06.45% (112,562,000B) 0x56C5A3B: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->06.45% (112,562,000B) 0x541F3A9: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->06.45% (112,562,000B) 0x5433AEC: MatGalerkin (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.23% (56,281,000B) 0x61A23A0: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.23% (56,281,000B) 0x61ED10C: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.23% (56,281,000B) 0x6330A89: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.23% (56,281,000B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.23% (56,281,000B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | ->03.23% (56,281,000B) 0x419ADD: main (main_petsc310.cc:2254)
| | | ->03.23% (56,281,000B) 0x61A244E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->03.25% (56,624,708B) 0x403FE0: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc310.cc:75)
| | | ->03.25% (56,624,708B) 0x415FE6: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:1858)
| | | ->03.25% (56,624,708B) 0x419ADD: main (main_petsc310.cc:2254)
| | ->03.23% (56,284,240B) 0x56C46D6: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.23% (56,284,240B) 0x56C5A3B: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.23% (56,284,240B) 0x541F3A9: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.23% (56,284,240B) 0x5433AEC: MatGalerkin (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->01.61% (28,142,120B) 0x61A23A0: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.61% (28,142,120B) 0x61ED10C: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.61% (28,142,120B) 0x6330A89: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.61% (28,142,120B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.61% (28,142,120B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | ->01.61% (28,142,120B) 0x419ADD: main (main_petsc310.cc:2254)
| | | ->01.61% (28,142,120B) 0x61A244E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->02.24% (39,052,464B) 0x58AA01F: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.24% (39,052,464B) 0x53E6A04: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.24% (39,052,464B) 0x60260A2: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.24% (39,052,464B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.24% (39,052,464B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.24% (39,052,464B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.24% (39,052,464B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.24% (39,052,464B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.24% (39,052,464B) 0x62A6082: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.24% (39,052,464B) 0x61990DE: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->01.98% (34,525,272B) 0x619E2A5: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.98% (34,525,272B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.94% (33,887,724B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.94% (33,887,724B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.94% (33,887,724B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.94% (33,887,724B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.94% (33,887,724B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | ->01.94% (33,887,724B) 0x419ADD: main (main_petsc310.cc:2254)
| | | ->00.26% (4,527,192B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->02.03% (35,446,204B) in 189 places, all below massif's threshold (01.00%)
->00.25% (4,411,670B) in 1+ places, all below ms_print's threshold (01.00%)
37 969,591,761,903 1,759,288,480 1,759,148,130 140,350 0
38 991,106,632,404 1,759,288,480 1,759,148,130 140,350 0
39 1,005,161,800,597 1,759,288,480 1,759,148,130 140,350 0
40 1,025,190,917,071 1,759,288,480 1,759,148,130 140,350 0
41 1,047,466,381,537 1,759,288,480 1,759,148,130 140,350 0
42 1,061,578,439,350 1,759,288,480 1,759,148,130 140,350 0
43 1,086,296,641,845 1,759,288,480 1,759,148,130 140,350 0
44 1,102,529,172,628 1,759,288,480 1,759,148,130 140,350 0
45 1,123,472,773,295 1,781,953,776 1,781,812,642 141,134 0
99.99% (1,781,812,642B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->99.74% (1,777,400,972B) 0x4FFCEA1: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->99.74% (1,777,400,972B) 0x50006E8: PetscTrMallocDefault (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->99.65% (1,775,669,592B) 0x4FFE767: PetscMallocA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->66.32% (1,181,786,648B) 0x583AC5B: MatSeqAIJSetPreallocation_SeqAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->66.23% (1,180,265,248B) 0x5839FF5: MatSeqAIJSetPreallocation (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->65.91% (1,174,446,424B) 0x5B6327B: DMCreateMatrix_DA_3d_MPIAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->65.91% (1,174,446,424B) 0x5B5951F: DMCreateMatrix_DA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->65.91% (1,174,446,424B) 0x5EBC894: DMCreateMatrix (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->32.95% (587,223,212B) 0x417497: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2026)
| | | | | | ->32.95% (587,223,212B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | ->32.95% (587,223,212B) 0x41750B: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2027)
| | ->16.49% (293,795,244B) 0x52A9E6E: VecCreate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->16.49% (293,795,244B) 0x52EC6A1: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->11.78% (209,896,368B) 0x52C2880: VecCreate_Standard (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->11.78% (209,896,368B) 0x52EC6A1: VecSetType (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->11.57% (206,129,996B) 0x5B0C608: DMCreateGlobalVector_DA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->11.57% (206,129,996B) 0x5EB8BE6: DMCreateGlobalVector (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->10.78% (192,084,972B) 0x5B0BD6D: VecDuplicate_MPI_DA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->10.78% (192,084,972B) 0x52DBF2E: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->10.78% (192,084,972B) 0x52E058A: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->10.78% (192,084,972B) 0x52DCD2D: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->10.78% (192,084,972B) 0x635A9B1: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->09.72% (173,253,112B) 0x62C4F9F: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->09.72% (173,253,112B) 0x62C19CD: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->09.72% (173,253,112B) 0x62C2540: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->09.72% (173,253,112B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->09.72% (173,253,112B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | | | ->09.72% (173,253,112B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | | ->01.06% (18,831,860B) 0x62C0C8D: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.06% (18,831,860B) 0x633021B: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.06% (18,831,860B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.06% (18,831,860B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | | ->01.06% (18,831,860B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | ->00.79% (14,045,024B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->00.21% (3,766,372B) in 1+ places, all below ms_print's threshold (01.00%)
| | | ->04.71% (83,898,876B) 0x529E375: VecDuplicate_Seq (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->04.71% (83,898,876B) 0x52DBF2E: VecDuplicate (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->04.65% (82,814,820B) 0x52E058A: VecDuplicateVecs_Default (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->04.65% (82,814,820B) 0x52DCD2D: VecDuplicateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->04.65% (82,814,820B) 0x635A9B1: KSPCreateVecs (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->02.44% (43,434,400B) 0x62C4F9F: KSPGMRESGetNewVectors (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.44% (43,434,400B) 0x62C19CD: KSPGMRESCycle (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.44% (43,434,400B) 0x62C2540: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.44% (43,434,400B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->02.44% (43,434,400B) 0x62A6082: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->02.44% (43,434,400B) 0x61990DE: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->02.15% (38,382,800B) 0x619E2A5: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->02.15% (38,382,800B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->02.11% (37,663,720B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.11% (37,663,720B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.11% (37,663,720B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.11% (37,663,720B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->02.11% (37,663,720B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | | | | ->02.11% (37,663,720B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | | ->00.28% (5,051,600B) in 1+ places, all below ms_print's threshold (01.00%)
| | | | ->01.22% (21,717,200B) 0x62C0C8D: KSPSetUp_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.22% (21,717,200B) 0x633021B: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.22% (21,717,200B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.22% (21,717,200B) 0x62A6082: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.22% (21,717,200B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.22% (21,717,200B) 0x61990DE: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.08% (19,191,400B) 0x619E2A5: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->01.08% (19,191,400B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | ->01.06% (18,831,860B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->01.06% (18,831,860B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->01.06% (18,831,860B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | | | ->01.06% (18,831,860B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->00.99% (17,663,220B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->06.32% (112,562,000B) 0x56C4881: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->06.32% (112,562,000B) 0x56C5A3B: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->06.32% (112,562,000B) 0x541F3A9: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->06.32% (112,562,000B) 0x5433AEC: MatGalerkin (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.16% (56,281,000B) 0x61A23A0: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.16% (56,281,000B) 0x61ED10C: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.16% (56,281,000B) 0x6330A89: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.16% (56,281,000B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.16% (56,281,000B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | ->03.16% (56,281,000B) 0x419ADD: main (main_petsc310.cc:2254)
| | | ->03.16% (56,281,000B) 0x61A244E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->03.18% (56,624,708B) 0x403FE0: CellPropertiesCreate(_p_DM*, _p_CellProperties**) (main_petsc310.cc:75)
| | | ->03.18% (56,624,708B) 0x415FE6: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:1858)
| | | ->03.18% (56,624,708B) 0x419ADD: main (main_petsc310.cc:2254)
| | ->03.16% (56,284,240B) 0x56C46D6: MatPtAPSymbolic_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.16% (56,284,240B) 0x56C5A3B: MatPtAP_SeqAIJ_SeqMAIJ (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.16% (56,284,240B) 0x541F3A9: MatPtAP (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.16% (56,284,240B) 0x5433AEC: MatGalerkin (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->01.58% (28,142,120B) 0x61A23A0: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.58% (28,142,120B) 0x61ED10C: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.58% (28,142,120B) 0x6330A89: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.58% (28,142,120B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.58% (28,142,120B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | ->01.58% (28,142,120B) 0x419ADD: main (main_petsc310.cc:2254)
| | | ->01.58% (28,142,120B) 0x61A244E: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->02.19% (39,052,464B) 0x58AA01F: MatSOR_SeqAIJ_Inode (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.19% (39,052,464B) 0x53E6A04: MatSOR (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.19% (39,052,464B) 0x60260A2: PCApply_SOR (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.19% (39,052,464B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.19% (39,052,464B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.19% (39,052,464B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.19% (39,052,464B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.19% (39,052,464B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.19% (39,052,464B) 0x62A6082: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.19% (39,052,464B) 0x61990DE: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->01.94% (34,525,272B) 0x619E2A5: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.94% (34,525,272B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->01.90% (33,887,724B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.90% (33,887,724B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.90% (33,887,724B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.90% (33,887,724B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.90% (33,887,724B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | | | | ->01.90% (33,887,724B) 0x419ADD: main (main_petsc310.cc:2254)
| | | ->00.25% (4,527,192B) in 1+ places, all below ms_print's threshold (01.00%)
| | ->02.00% (35,564,288B) in 189 places, all below massif's threshold (01.00%)
46 1,144,977,466,286 1,797,071,704 1,796,929,934 141,770 0
47 1,169,482,873,650 1,797,071,704 1,796,929,934 141,770 0
48 1,187,701,811,363 1,797,071,704 1,796,929,934 141,770 0
49 1,209,131,205,775 5,474,208 5,419,554 54,654 0
50 1,209,131,221,293 5,388,512 5,334,898 53,614 0
51 1,209,131,236,638 5,281,384 5,229,070 52,314 0
52 1,209,131,252,176 5,169,320 5,118,366 50,954 0
53 1,209,131,267,534 5,099,704 5,049,606 50,098 0
54 1,209,131,282,926 4,994,488 4,945,670 48,818 0
99.02% (4,945,670B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->55.11% (2,752,512B) 0xB6B4A75: MPIDI_RMA_init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->55.11% (2,752,512B) 0xB69B950: MPID_Init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->55.11% (2,752,512B) 0xB5031EE: MPIR_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->55.11% (2,752,512B) 0xB5036EE: PMPI_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->55.11% (2,752,512B) 0x4FAB272: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->55.11% (2,752,512B) 0x41983C: main (main_petsc310.cc:2241)
->26.24% (1,310,720B) 0xB6B4CFD: MPIDI_RMA_init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->26.24% (1,310,720B) 0xB69B950: MPID_Init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->26.24% (1,310,720B) 0xB5031EE: MPIR_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->26.24% (1,310,720B) 0xB5036EE: PMPI_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->26.24% (1,310,720B) 0x4FAB272: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->26.24% (1,310,720B) 0x41983C: main (main_petsc310.cc:2241)
->10.74% (536,488B) 0x4FFCEA1: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->10.74% (536,488B) 0x50006E8: PetscTrMallocDefault (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->10.51% (524,852B) 0x4FFE767: PetscMallocA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->08.51% (425,240B) 0x4FDB939: PetscStrallocpy (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->07.24% (361,772B) 0x4F662CD: PetscEventRegLogRegister (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->07.24% (361,772B) 0x4F3968E: PetscLogEventRegister (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->07.24% (361,772B) in 247 places, all below massif's threshold (01.00%)
| | | ->01.27% (63,468B) in 32 places, all below massif's threshold (01.00%)
| | ->01.99% (99,612B) in 203 places, all below massif's threshold (01.00%)
| ->00.23% (11,636B) in 1+ places, all below ms_print's threshold (01.00%)
->04.79% (239,180B) in 130 places, all below massif's threshold (01.00%)
->01.12% (55,933B) 0xC2A1ED0: strdup (in /lib64/libc-2.12.so)
| ->01.12% (55,933B) in 100 places, all below massif's threshold (01.00%)
->01.02% (50,837B) 0xB6E2FC3: hwloc_tma_malloc (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
->01.02% (50,837B) in 8 places, all below massif's threshold (01.00%)
55 1,209,131,298,332 4,889,160 4,841,622 47,538 0
56 1,209,131,313,702 4,784,120 4,737,862 46,258 0
57 1,209,131,329,062 4,679,160 4,634,182 44,978 0
58 1,209,131,344,556 4,585,648 4,541,730 43,918 0
59 1,209,131,372,522 4,497,744 4,454,235 43,509 0
60 1,209,131,391,226 4,483,776 4,440,702 43,074 0
61 1,209,131,406,563 4,481,160 4,438,490 42,670 0
62 1,209,131,422,011 4,459,456 4,420,562 38,894 0
63 1,209,131,437,338 4,438,256 4,403,151 35,105 0
64 1,209,131,452,709 4,416,680 4,385,319 31,361 0
99.29% (4,385,319B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->62.32% (2,752,512B) 0xB6B4A75: MPIDI_RMA_init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->62.32% (2,752,512B) 0xB69B950: MPID_Init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->62.32% (2,752,512B) 0xB5031EE: MPIR_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->62.32% (2,752,512B) 0xB5036EE: PMPI_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->62.32% (2,752,512B) 0x4FAB272: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->62.32% (2,752,512B) 0x41983C: main (main_petsc310.cc:2241)
->29.68% (1,310,720B) 0xB6B4CFD: MPIDI_RMA_init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->29.68% (1,310,720B) 0xB69B950: MPID_Init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->29.68% (1,310,720B) 0xB5031EE: MPIR_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->29.68% (1,310,720B) 0xB5036EE: PMPI_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->29.68% (1,310,720B) 0x4FAB272: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->29.68% (1,310,720B) 0x41983C: main (main_petsc310.cc:2241)
->06.03% (266,288B) in 132 places, all below massif's threshold (01.00%)
->01.26% (55,799B) 0xC2A1ED0: strdup (in /lib64/libc-2.12.so)
->01.02% (45,156B) 0xB6D6187: MPIR_T_CVAR_REGISTER_impl (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.02% (45,156B) in 235 places, all below massif's threshold (01.00%)
->00.24% (10,643B) in 1+ places, all below ms_print's threshold (01.00%)
65 1,209,131,468,036 4,395,496 4,367,908 27,588 0
66 1,209,131,483,425 4,374,144 4,350,321 23,823 0
67 1,209,131,498,780 4,352,664 4,332,601 20,063 0
68 1,209,131,515,035 266,744 249,681 17,063 0
69 1,209,131,530,396 211,640 200,353 11,287 0
70 1,209,131,545,804 143,072 136,226 6,846 0
71 1,209,131,561,148 133,480 128,378 5,102 0
72 1,209,131,576,478 122,528 119,356 3,172 0
73 1,209,131,659,641 107,416 105,622 1,794 0
74 1,209,131,709,690 88,184 86,649 1,535 0
98.26% (86,649B) (heap allocation functions) malloc/new/new[], --alloc-fns, etc.
->49.90% (44,008B) 0x4FFCEA1: PetscMallocAlign (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->49.90% (44,008B) 0x50006E8: PetscTrMallocDefault (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->49.90% (44,008B) 0x4FFE767: PetscMallocA (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->22.19% (19,568B) 0x4FDB939: PetscStrallocpy (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->11.13% (9,816B) 0x500DF1D: PetscFunctionListAdd_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->11.13% (9,816B) 0x4F8255C: PetscObjectComposeFunction_Petsc (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->11.13% (9,816B) 0x4F83ACF: PetscObjectComposeFunction_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->03.71% (3,272B) 0x50D123D: PetscViewerCreate_ASCII (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->03.71% (3,272B) 0x50E29F2: PetscViewerSetType (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->03.71% (3,272B) 0x50D4E82: PetscViewerASCIIOpen (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | | ->01.86% (1,636B) 0x418A0C: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2169)
| | | | | | | ->01.86% (1,636B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | | ->01.86% (1,636B) 0x418AE3: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2178)
| | | | | ->03.71% (3,272B) 0x50D12A7: PetscViewerCreate_ASCII (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->03.71% (3,272B) 0x50D1311: PetscViewerCreate_ASCII (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.71% (3,272B) 0x500DBCE: PetscFunctionListAdd_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.71% (3,272B) 0x4F8255C: PetscObjectComposeFunction_Petsc (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->03.71% (3,272B) 0x4F83ACF: PetscObjectComposeFunction_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->03.71% (3,272B) 0x50D11D3: PetscViewerCreate_ASCII (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.67% (3,240B) 0x4F74319: PetscObjectChangeTypeName (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.67% (3,240B) 0x50E2995: PetscViewerSetType (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->03.67% (3,240B) 0x50D4E82: PetscViewerASCIIOpen (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | | ->01.84% (1,620B) 0x418A0C: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2169)
| | | | | | ->01.84% (1,620B) 0x419ADD: main (main_petsc310.cc:2254)
| | | | | ->01.84% (1,620B) 0x418AE3: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2178)
| | | ->03.67% (3,240B) 0x50CFAFF: PetscViewerFileSetName_ASCII (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.67% (3,240B) 0x50CED56: PetscViewerFileSetName (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | | ->03.67% (3,240B) 0x50D4EEF: PetscViewerASCIIOpen (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->11.13% (9,816B) 0x500DEB6: PetscFunctionListAdd_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->05.34% (4,712B) 0x50E20A8: PetscViewerCreate (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->05.34% (4,712B) 0x50D4E1C: PetscViewerASCIIOpen (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->02.67% (2,356B) 0x418A0C: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2169)
| | | | ->02.67% (2,356B) 0x419ADD: main (main_petsc310.cc:2254)
| | | ->02.67% (2,356B) 0x418AE3: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2178)
| | ->03.86% (3,400B) 0x50D1059: PetscViewerCreate_ASCII (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.86% (3,400B) 0x50E29F2: PetscViewerSetType (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->03.86% (3,400B) 0x50D4E82: PetscViewerASCIIOpen (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | | ->01.93% (1,700B) 0x418A0C: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2169)
| | | | ->01.93% (1,700B) 0x419ADD: main (main_petsc310.cc:2254)
| | | ->01.93% (1,700B) 0x418AE3: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2178)
| | ->03.71% (3,272B) 0x500DB67: PetscFunctionListAdd_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->03.67% (3,240B) 0x50D4F74: PetscViewerASCIIOpen (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
->38.03% (33,536B) 0x8C869BB: mkl_serv_allocate (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_core.so)
| ->37.30% (32,896B) 0x90EA3BD: mkl_lapack_dgehrd (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_core.so)
| | ->37.30% (32,896B) 0x90E3F92: mkl_lapack_dgeev (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_core.so)
| | ->37.30% (32,896B) 0x7F41809: DGEEV (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_intel_lp64.so)
| | ->37.30% (32,896B) 0x62CE421: KSPComputeEigenvalues_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x632E270: KSPComputeEigenvalues (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x62A54C2: KSPChebyshevComputeExtremeEigenvalues_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x62A64CB: KSPSolve_Chebyshev (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x633504F: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x61990DE: PCMGMCycle_Private (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x619E2A5: PCApply_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x61E665F: PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x635E4EB: KSP_PCApply (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x635F3D2: KSPInitialResidual (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x62C24DD: KSPSolve_GMRES (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->37.30% (32,896B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | ->37.30% (32,896B) 0x419ADD: main (main_petsc310.cc:2254)
| ->00.73% (640B) in 1+ places, all below ms_print's threshold (01.00%)
->02.73% (2,406B) 0x400B13D: _dl_new_object (in /lib64/ld-2.12.so)
| ->02.73% (2,406B) 0x400745C: _dl_map_object_from_fd (in /lib64/ld-2.12.so)
| ->02.73% (2,406B) 0x4008660: _dl_map_object (in /lib64/ld-2.12.so)
| ->02.73% (2,406B) 0x4012EF3: dl_open_worker (in /lib64/ld-2.12.so)
| ->02.73% (2,406B) 0x400E5E4: _dl_catch_error (in /lib64/ld-2.12.so)
| ->02.73% (2,406B) 0x4012998: _dl_open (in /lib64/ld-2.12.so)
| ->01.39% (1,228B) 0xAFB4F64: dlopen_doit (in /lib64/libdl-2.12.so)
| | ->01.39% (1,228B) 0x400E5E4: _dl_catch_error (in /lib64/ld-2.12.so)
| | ->01.39% (1,228B) 0xAFB529A: _dlerror_run (in /lib64/libdl-2.12.so)
| | ->01.39% (1,228B) 0xAFB4EDF: dlopen@@GLIBC_2.2.5 (in /lib64/libdl-2.12.so)
| | ->01.39% (1,228B) 0x8C83F19: mkl_serv_load_dll (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_core.so)
| | ->01.39% (1,228B) 0x8CD46DC: mkl_blas_dnrm2 (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_core.so)
| | ->01.39% (1,228B) 0x918D552: mkl_lapack_dlarfg (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_core.so)
| | ->01.39% (1,228B) 0x90FF89F: mkl_lapack_dgeqr2 (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_core.so)
| | ->01.39% (1,228B) 0x958109D: mkl_lapack_xdgeqrf (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_core.so)
| | ->01.39% (1,228B) 0x8714BB6: mkl_lapack_dgeqrf (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_sequential.so)
| | ->01.39% (1,228B) 0x7F37955: DGEQRF (in /gpfs4l/smplocal/intel/composer_xe_2013_sp1.1.106/mkl/lib/intel64/libmkl_intel_lp64.so)
| | ->01.39% (1,228B) 0x60F2D40: formProl0 (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->01.39% (1,228B) 0x60F74C2: PCGAMGProlongator_AGG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->01.39% (1,228B) 0x60DFD80: PCSetUp_GAMG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->01.39% (1,228B) 0x61ED10C: PCSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->01.39% (1,228B) 0x6330A89: KSPSetUp (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->01.39% (1,228B) 0x61A45F2: PCSetUp_MG (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->01.39% (1,228B) 0x633452D: KSPSolve (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->01.39% (1,228B) 0x4184F1: solve_stokes_3d_coupled(int, int, int) (main_petsc310.cc:2130)
| | ->01.39% (1,228B) 0x419ADD: main (main_petsc310.cc:2254)
| ->01.34% (1,178B) 0xC347EFE: do_dlopen (in /lib64/libc-2.12.so)
| ->01.34% (1,178B) 0x400E5E4: _dl_catch_error (in /lib64/ld-2.12.so)
| ->01.34% (1,178B) 0xC348055: __libc_dlopen_mode (in /lib64/libc-2.12.so)
| ->01.34% (1,178B) 0xC31D571: __nss_lookup_function (in /lib64/libc-2.12.so)
| ->01.34% (1,178B) 0xC31D5DA: __nss_lookup (in /lib64/libc-2.12.so)
| ->01.34% (1,178B) 0xC324DEE: gethostbyname_r@@GLIBC_2.2.5 (in /lib64/libc-2.12.so)
| ->01.34% (1,178B) 0xC324491: gethostbyname (in /lib64/libc-2.12.so)
| ->01.34% (1,178B) 0xB6BC049: MPIDU_CH3U_GetSockInterfaceAddr (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.34% (1,178B) 0xB6BA105: MPIDI_CH3U_Get_business_card_sock (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.34% (1,178B) 0xB6B92D0: MPIDI_CH3U_Init_sock (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.34% (1,178B) 0xB6C3B8C: MPIDI_CH3_Init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.34% (1,178B) 0xB69B394: MPID_Init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.34% (1,178B) 0xB5031EE: MPIR_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.34% (1,178B) 0xB5036EE: PMPI_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.34% (1,178B) 0x4FAB272: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->01.34% (1,178B) 0x41983C: main (main_petsc310.cc:2241)
->02.18% (1,923B) 0xC2BF7CA: __tzfile_read (in /lib64/libc-2.12.so)
| ->02.18% (1,923B) 0xC2BE962: tzset_internal (in /lib64/libc-2.12.so)
| ->02.18% (1,923B) 0xC2BEAC7: __tz_convert (in /lib64/libc-2.12.so)
| ->02.18% (1,923B) 0x4F6EBAB: PetscGetDate (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->02.18% (1,923B) 0x511FB42: PetscErrorPrintfInitialize (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->02.18% (1,923B) 0x4FAB5F8: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->02.18% (1,923B) 0x41983C: main (main_petsc310.cc:2241)
->01.79% (1,582B) in 129 places, all below massif's threshold (01.00%)
->01.29% (1,136B) 0xC287D39: __fopen_internal (in /lib64/libc-2.12.so)
| ->01.29% (1,136B) 0x50CFF95: PetscViewerFileSetName_ASCII (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->01.29% (1,136B) 0x50CED56: PetscViewerFileSetName (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->01.29% (1,136B) 0x50D4EEF: PetscViewerASCIIOpen (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| | ->01.29% (1,136B) in 2 places, all below massif's threshold (01.00%)
->01.17% (1,034B) 0xC31D739: nss_parse_service_list (in /lib64/libc-2.12.so)
| ->01.17% (1,034B) 0xC31E1FF: __nss_database_lookup (in /lib64/libc-2.12.so)
| ->01.17% (1,034B) 0xC31F356: __nss_hosts_lookup2 (in /lib64/libc-2.12.so)
| ->01.17% (1,034B) 0xC324DEE: gethostbyname_r@@GLIBC_2.2.5 (in /lib64/libc-2.12.so)
| ->01.17% (1,034B) 0xC324491: gethostbyname (in /lib64/libc-2.12.so)
| ->01.17% (1,034B) 0xB6BC049: MPIDU_CH3U_GetSockInterfaceAddr (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.17% (1,034B) 0xB6BA105: MPIDI_CH3U_Get_business_card_sock (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.17% (1,034B) 0xB6B92D0: MPIDI_CH3U_Init_sock (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.17% (1,034B) 0xB6C3B8C: MPIDI_CH3_Init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.17% (1,034B) 0xB69B394: MPID_Init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.17% (1,034B) 0xB5031EE: MPIR_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.17% (1,034B) 0xB5036EE: PMPI_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
| ->01.17% (1,034B) 0x4FAB272: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
| ->01.17% (1,034B) 0x41983C: main (main_petsc310.cc:2241)
->01.16% (1,024B) 0xC324563: gethostbyname (in /lib64/libc-2.12.so)
->01.16% (1,024B) 0xB6BC049: MPIDU_CH3U_GetSockInterfaceAddr (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
->01.16% (1,024B) 0xB6BA105: MPIDI_CH3U_Get_business_card_sock (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
->01.16% (1,024B) 0xB6B92D0: MPIDI_CH3U_Init_sock (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
->01.16% (1,024B) 0xB6C3B8C: MPIDI_CH3_Init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
->01.16% (1,024B) 0xB69B394: MPID_Init (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
->01.16% (1,024B) 0xB5031EE: MPIR_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
->01.16% (1,024B) 0xB5036EE: PMPI_Init_thread (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libmpi.so.0.0.0)
->01.16% (1,024B) 0x4FAB272: PetscInitialize (in /gpfs4l/smplocal/pub/PETSc/3.10.2/real-debug-mpich-mumps-hypre/lib/libpetsc.so.3.10.2)
->01.16% (1,024B) 0x41983C: main (main_petsc310.cc:2241)
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190308/99d1b272/attachment-0001.p7s>
