[petsc-users] Bad memory scaling with PETSc 3.10
Myriam Peyrounette
myriam.peyrounette at idris.fr
Tue Mar 5 06:14:09 CST 2019
Hi Matt,
I plotted the memory scalings using different threshold values. The two
scalings are slightly translated (from -22 to -88 mB) but this gain is
neglectable. The 3.6-scaling keeps being robust while the 3.10-scaling
deteriorates.
Do you have any other suggestion?
Thanks
Myriam
Le 03/02/19 à 02:27, Matthew Knepley a écrit :
> On Fri, Mar 1, 2019 at 10:53 AM Myriam Peyrounette via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Hi,
> I used to run my code with PETSc 3.6. Since I upgraded the PETSc
> version
> to 3.10, this code has a bad memory scaling.
> To report this issue, I took the PETSc script ex42.c and slightly
> modified it so that the KSP and PC configurations are the same as
> in my
> code. In particular, I use a "personnalised" multi-grid method. The
> modifications are indicated by the keyword "TopBridge" in the attached
> scripts.
> To plot the memory (weak) scaling, I ran four calculations for each
> script with increasing problem sizes and computations cores:
> 1. 100,000 elts on 4 cores
> 2. 1 million elts on 40 cores
> 3. 10 millions elts on 400 cores
> 4. 100 millions elts on 4,000 cores
> The resulting graph is also attached. The scaling using PETSc 3.10
> clearly deteriorates for large cases, while the one using PETSc 3.6 is
> robust.
> After a few tests, I found that the scaling is mostly sensitive to the
> use of the AMG method for the coarse grid (line 1780 in
> main_ex42_petsc36.cc). In particular, the performance strongly
> deteriorates when commenting lines 1777 to 1790 (in
> Do you have any idea of what changed between version 3.6 and version
> 3.10 that may imply such degradation?
> I believe the default values for PCGAMG changed between versions. It
> sounds like the coarsening rate
> is not great enough, so that these grids are too large. This can be
> set using:
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
> There is some explanation of this effect on that page. Let us know if
> setting this does not correct the situation.
> Thanks,
> Matt
> Let me know if you need further information.
> Best,
> Myriam Peyrounette
> Myriam Peyrounette
> CNRS/IDRIS - HLST
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
Myriam Peyrounette
CNRS/IDRIS - HLST
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190305/10b3efce/attachment-0001.html>
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190305/10b3efce/attachment-0001.p7s>
