[petsc-users] Loading only upper + MatSetOption(A,MAT_SYMMETRIC,PETSC_TRUE);
    Matthew Knepley
    knepley at gmail.com
    Mon Mar  4 07:45:03 CST 2019
On Mon, Mar 4, 2019 at 8:03 AM Klaus Burkart via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> I want to solve many symmetric linear systems one after another in
> parallel using boomerAMG + KSPCG  and need to make the matrix transfer more
> efficient. Matrices are symmetric in structure and values. boomerAMG +
> KSPCG work fine.
Can you be more specific about where you want to save time? The best thing
would be to send the output of -log_view and show us.
I ask because loading a matrix from memory  should be much faster than
BAMG. Loading it from disk could possibly be slower, but
I do not think that BAMG handles a symmetric format, so you would load a
symmetric matrix and convert to AIJ.
    Matt
So far I have been loading the entire matrices but I read in a paper, that
> it's sufficient to load the upper part only and tell petsc that the matrix
> is symmetric using MatSetOption(A,MAT_SYMMETRIC,PETSC_TRUE); Unfortunately
> all computations fail if I load only the upper values and use
> The idea is:
>     if (matrix_.symmetric())
>        //load only upper part of the matrix MatSetValues(...)
>    }else //asymmetric matrix
>                //load the entire matrix MatSetValues(...)
> Is it possible at all?
> Klaus
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190304/6b66f025/attachment.html>
