[petsc-users] Get global column indices thay belong to another process?
Smith, Barry F.
bsmith at mcs.anl.gov
Sun Mar 3 16:01:21 CST 2019
> On Mar 3, 2019, at 3:04 PM, Appel, Thibaut via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Assuming you preallocate/assemble a MPIAIJ matrix “by hand” using a ISLocalToGlobalMapping object obtained from DMDA: what’s the easiest way to get global column indices that do not belong to a process?
> Say, if you have a finite-difference stencil and the stencil exceeds the portion owned by the process.
> I think the way to go is to preallocate a MPIAIJ matrix using local information with MatPreallocateSetLocal and then fill values with MatSetLocal, those routines can’t work with rows/columns not owned by the process right?
Yes, MatSetValuesLocal() cannot write for matrix locations that are NOT in the ghosted region of the process.
> Thank you,
> Thibaut
