[petsc-users] Get global column indices thay belong to another process?
Appel, Thibaut t.appel17 at imperial.ac.uk
Sun Mar 3 15:04:59 CST 2019
Assuming you preallocate/assemble a MPIAIJ matrix “by hand” using a ISLocalToGlobalMapping object obtained from DMDA: what’s the easiest way to get global column indices that do not belong to a process?
Say, if you have a finite-difference stencil and the stencil exceeds the portion owned by the process.
I think the way to go is to preallocate a MPIAIJ matrix using local information with MatPreallocateSetLocal and then fill values with MatSetLocal, those routines can’t work with rows/columns not owned by the process right?
Thank you,
Thibaut
