[petsc-users] Communication during MatAssemblyEnd
Ale Foggia amfoggia at gmail.com
Fri Jun 21 09:27:08 CDT 2019
I'm sending one with a bit less time.
I'm timing the functions also with std::chronos and for the case of 180
seconds the program runs out of memory (and crushes) before the PETSc log
gets to be printed, so I know the time only from my function. Anyway, in
every case, the times between std::chronos and the PETSc log match.
(The large times are in part "4b- Building offdiagonal part" or "Event
Stage 5: Offdiag").
El vie., 21 jun. 2019 a las 16:09, Zhang, Junchao (<jczhang at mcs.anl.gov>)
escribió:
> On Fri, Jun 21, 2019 at 8:07 AM Ale Foggia <amfoggia at gmail.com> wrote:
>> Thanks both of you for your answers,
>> El jue., 20 jun. 2019 a las 22:20, Smith, Barry F. (<bsmith at mcs.anl.gov>)
>> escribió:
>>>   Note that this is a one time cost if the nonzero structure of the
>>> matrix stays the same. It will not happen in future MatAssemblies.
>>> > On Jun 20, 2019, at 3:16 PM, Zhang, Junchao via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>> > Those messages were used to build MatMult communication pattern for
>>> the matrix. They were not part of the matrix entries-passing you imagined,
>>> but indeed happened in MatAssemblyEnd. If you want to make sure processors
>>> do not set remote entries, you can use
>>> MatSetOption(A,MAT_NO_OFF_PROC_ENTRIES,PETSC_TRUE), which will generate an
>>> error when an off-proc entry is set.
>> I started being concerned about this when I saw that the assembly was
>> taking a few hundreds of seconds in my code, like 180 seconds, which for me
>> it's a considerable time. Do you think (or maybe you need more information
>> to answer this) that this time is "reasonable" for communicating the
>> pattern for the matrix? I already checked that I'm not setting any remote
>> entries.
> It is not reasonable. Could you send log view of that test with 180
> seconds MatAssembly?
>> Also I see (in my code) that even if there are no messages being passed
>> during MatAssemblyBegin, it is taking time and the "ratio" is very big.
>>> > --Junchao Zhang
>>> > On Thu, Jun 20, 2019 at 4:13 AM Ale Foggia via petsc-users <
>>> > Hello all!
>>> > During the conference I showed you a problem happening during
>>> MatAssemblyEnd in a particular code that I have. Now, I tried the same with
>>> a simple code (a symmetric problem corresponding to the Laplacian operator
>>> in 1D, from the SLEPc Hands-On exercises). As I understand (and please,
>>> correct me if I'm wrong), in this case the elements of the matrix are
>>> computed locally by each process so there should not be any communication
>>> during the assembly. However, in the log I get that there are messages
>>> being passed. Also, the number of messages changes with the number of
>>> processes used and the size of the matrix. Could you please help me
>>> understand this?
>>> > I attach the code I used and the log I get for a small problem.
>>> > Cheers,
>>> > Ale
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190621/0686d080/attachment-0001.html>
srun -n 32768 home/build/main.x 38 -nn -j1 1.0 -d1 1.0 -eps_type krylovschur -eps_tol 1e-9 -log_view
 ------ Parameters ------
       J1:   1.00000
       D1:   1.00000
       J2:   0.00000
       D2:   0.00000
disorder?:   0
1- Creating basis
*                Basis: 7.916039e-02 -- 7.916039e-02 -- 1
2- Creating lattice
*              Lattice: 4.789100e-05 -- 4.789100e-05 -- 1
3- Creating Hamiltonian
*          prealloc-J1: 4.108500e-05 -- 2.892727e+01 -- 1078652
*   PetscPreallocation: 6.085745e+01 -- 6.085745e+01 -- 1
*             prealloc: 9.314486e+01 -- 9.314486e+01 -- 1
*        Miscellaneous: 1.581486e-01 -- 1.581486e-01 -- 1
*       MatZeroEntries: 9.806940e-02 -- 9.806940e-02 -- 1
*     MatAssembly-init: 2.934797e-01 -- 2.934797e-01 -- 1
*              MatInit: 9.369477e+01 -- 9.369477e+01 -- 1
4a- Building diagonal part
*  get_coup_elems-d-nn: 3.428000e-06 -- 3.751426e+00 -- 1078652
* MatSetValues-diag-nn: 2.496000e-06 -- 2.741947e+00 -- 1078652
*           build_diag: 1.269635e+01 -- 1.269635e+01 -- 1
*  get_coup_elems-o-nn: 4.094500e-05 -- 2.944290e+01 -- 1078652
*  MatSetValues-off-nn: 4.119000e-06 -- 4.000079e+00 -- 1078652
*  MatAssembly-offdiag: 1.253235e+02 -- 1.253235e+02 -- 1
*       build_off_diag: 1.657913e+02 -- 1.657913e+02 -- 1
 iter          k          ||Ax-kx||/||kx||
*             EPSSolve: 8.045663e+02 -- 8.045663e+02 -- 1
  0       -16.861318        4.88671e-10
*            Get Eigen: 4.278705e+01 -- 4.278705e+01 -- 1
8- Phys quantities
*             EPSSolve: 4.499570e+03 -- 5.304137e+03 -- 2
*             CoeffDSF: 1.979352e+01 -- 8.826874e+02 -- 38
*            SolverDSF: 4.499571e+03 -- 4.499571e+03 -- 1
*      DynStructFactor: 5.404416e+03 -- 5.404416e+03 -- 1
9- Cleaning
----------------------------- Execution Times ---------------------------------
              Function:    Current ET      Total ET   Calls
*                Basis:   7.916039e-02   7.916039e-02   1
*             CoeffDSF:   1.979352e+01   8.826874e+02   38
*      DynStructFactor:   5.404416e+03   5.404416e+03   1
*             EPSSolve:   4.499570e+03   5.304137e+03   2
*            Get Eigen:   4.278705e+01   4.278705e+01   1
*              Lattice:   4.789100e-05   4.789100e-05   1
*     MatAssembly-init:   2.934797e-01   2.934797e-01   1
*  MatAssembly-offdiag:   1.253235e+02   1.253235e+02   1
*              MatInit:   9.369477e+01   9.369477e+01   1
* MatSetValues-diag-nn:   2.496000e-06   2.741947e+00   1078652
*  MatSetValues-off-nn:   4.119000e-06   4.000079e+00   1078652
*       MatZeroEntries:   9.806940e-02   9.806940e-02   1
*        Miscellaneous:   1.581486e-01   1.581486e-01   1
*   PetscPreallocation:   6.085745e+01   6.085745e+01   1
*            SolverDSF:   4.499571e+03   4.499571e+03   1
*       SqzConstructor:   4.669800e-05   2.305247e-03   38
*   SqzOpOnStateVector:   5.694926e-01   2.166454e+01   38
*           build_diag:   1.269635e+01   1.269635e+01   1
*       build_off_diag:   1.657913e+02   1.657913e+02   1
*  get_coup_elems-d-nn:   3.428000e-06   3.751426e+00   1078652
*  get_coup_elems-o-nn:   4.094500e-05   2.944290e+01   1078652
*             prealloc:   9.314486e+01   9.314486e+01   1
*          prealloc-J1:   4.108500e-05   2.892727e+01   1078652
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
home/build/main.x on a  named r065c17s01 with 32768 processors, by a Wed May 29 11:31:23 2019
Using Petsc Release Version 3.10.2, Oct, 09, 2018
                         Max       Max/Min     Avg       Total
Time (sec):           6.527e+03     1.000   6.527e+03
Objects:              5.500e+01     1.000   5.500e+01
Flop:                 7.303e+11     1.207   6.692e+11  2.193e+16
Flop/sec:             1.119e+08     1.207   1.025e+08  3.360e+12
MPI Messages:         3.261e+04     6.200   1.907e+04  6.248e+08
MPI Message Lengths:  2.693e+11    10.298   7.757e+06  4.847e+15
MPI Reductions:       1.944e+03     1.000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flop
                            and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total    Count   %Total     Avg         %Total    Count   %Total
 0:      Main Stage: 8.5045e+02  13.0%  3.0633e+15  14.0%  8.196e+07  13.1%  7.768e+06       13.1%  2.530e+02  13.0%
 1:    Create Basis: 7.9234e-02   0.0%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 2:  Create Lattice: 8.3944e-05   0.0%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 3:   Create Hamilt: 1.0694e+02   1.6%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  2.000e+00   0.1%
 5:         Offdiag: 1.6525e+02   2.5%  0.0000e+00   0.0%  1.188e+06   0.2%  1.942e+06        0.0%  8.000e+00   0.4%
 6: Phys quantities: 5.4045e+03  82.8%  1.8866e+16  86.0%  5.417e+08  86.7%  7.768e+06       86.8%  1.674e+03  86.1%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                  Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   AvgLen: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
BuildTwoSidedF         1 1.0 1.6722e-0241.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult              138 1.0 2.6604e+02 7.4 3.19e+10 2.1 8.2e+07 7.8e+06 0.0e+00  2  4 13 13  0  15 25100100  0 2935476
MatAssemblyBegin       1 1.0 1.6807e-0236.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         1 1.0 3.5680e-01 3.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNorm                2 1.0 4.4252e+0174.8 1.73e+07 1.0 0.0e+00 0.0e+00 2.0e+00  1  0  0  0  0   5  0  0  0  1 12780
VecCopy                6 1.0 6.5655e-02 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                2 1.0 1.3793e-02 2.7 1.73e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 41000838
VecScatterBegin      138 1.0 1.1653e+0285.8 0.00e+00 0.0 8.2e+07 7.8e+06 0.0e+00  1  0 13 13  0   4  0100100  0     0
VecScatterEnd        138 1.0 1.3653e+0222.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   4  0  0  0  0     0
VecSetRandom           1 1.0 9.6668e-01 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
EPSSetUp               1 1.0 8.0236e-01 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  2     0
EPSSolve               1 1.0 8.0484e+02 1.0 1.01e+11 1.2 8.1e+07 7.8e+06 2.5e+02 12 14 13 13 13  95100 99 99 98 3790582
STSetUp                1 1.0 7.0133e-022195.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
STApply              136 1.0 2.6264e+02 7.4 3.14e+10 2.1 8.1e+07 7.8e+06 0.0e+00  2  4 13 13  0  15 25 99 99  0 2930393
BVCopy                19 1.0 1.3275e-01 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BVMultVec            243 1.0 1.4706e+01 1.7 2.51e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  4  0  0  0   1 27  0  0  0 55951391
BVMultInPlace         16 1.0 4.3480e+00 1.6 1.67e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0 18  0  0  0 125903565
BVDotVec             243 1.0 7.5430e+02 1.4 2.72e+10 1.0 0.0e+00 0.0e+00 2.4e+02 10  4  0  0 12  78 29  0  0 96 1181949
BVOrthogonalizeV     137 1.0 7.6479e+02 1.4 5.23e+10 1.0 0.0e+00 0.0e+00 2.4e+02 10  8  0  0 12  79 56  0  0 96 2241651
BVScale              137 1.0 7.0904e-01 1.8 5.91e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 27317472
BVSetRandom            1 1.0 9.6671e-01 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSSolve               16 1.0 2.9756e-0115.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSVectors             17 1.0 2.8753e-04 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSOther               47 1.0 1.6295e-0270.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 1: Create Basis
--- Event Stage 2: Create Lattice
--- Event Stage 3: Create Hamilt
BuildTwoSidedF         1 1.0 2.9318e-01151.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin       1 1.0 2.9336e-01123.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         1 1.0 4.1753e-021018.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         1 1.0 2.6666e-01 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 4: Unknown
--- Event Stage 5: Offdiag
BuildTwoSidedF         1 1.0 7.1565e+01148448.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  28  0  0  0  0     0
MatAssemblyBegin       1 1.0 7.1565e+01127783.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  28  0  0  0  0     0
MatAssemblyEnd         1 1.0 5.3762e+01 1.0 0.00e+00 0.0 1.2e+06 1.9e+06 8.0e+00  1  0  0  0  0  33  0100100100     0
VecSet                 1 1.0 7.5533e-02 9.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 6: Phys quantities
MatMult              912 1.0 1.5033e+03 6.2 2.11e+11 2.1 5.4e+08 7.8e+06 0.0e+00 13 24 87 87  0  16 27100100  0 3433060
VecDot               380 1.0 1.2952e+01 1.0 3.28e+09 1.0 0.0e+00 0.0e+00 3.8e+02  0  0  0  0 20   0  1  0  0 23 8295974
VecNorm              380 1.0 7.6332e+02 3.0 3.28e+09 1.0 0.0e+00 0.0e+00 3.8e+02  8  0  0  0 20   9  1  0  0 23 140766
VecScale              38 1.0 1.7310e-01 1.5 1.64e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 31036816
VecCopy             1178 1.0 8.6691e+00 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              380 1.0 2.3530e+00 2.4 3.28e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 45664922
VecScatterBegin      912 1.0 7.4409e+0274.9 0.00e+00 0.0 5.4e+08 7.8e+06 0.0e+00  3  0 87 87  0   4  0100100  0     0
VecScatterEnd        912 1.0 5.7096e+0212.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
VecSetRandom           1 1.0 1.0213e+00 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
EPSSetUp               1 1.0 5.4395e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
EPSSolve               1 1.0 4.5000e+03 1.0 5.31e+11 1.1 3.2e+08 7.8e+06 9.1e+02 69 75 51 51 47  83 87 58 58 54 3641650
STSetUp                1 1.0 1.0705e-0412.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
STApply              532 1.0 9.1435e+02 6.8 1.23e+11 2.1 3.2e+08 7.8e+06 0.0e+00  8 14 51 51  0   9 16 58 58  0 3292645
BVCopy               811 1.0 5.3793e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BVMultVec            907 1.0 9.5485e+01 1.4 1.56e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1 23  0  0  0   1 27  0  0  0 53641657
BVMultInPlace         52 1.0 2.0483e+01 1.5 8.55e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0 13  0  0  0   0 15  0  0  0 136750118
BVDotVec             907 1.0 4.2638e+03 1.2 1.64e+11 1.0 0.0e+00 0.0e+00 9.1e+02 60 25  0  0 47  72 29  0  0 54 1261411
BVOrthogonalizeV     533 1.0 4.3471e+03 1.2 3.20e+11 1.0 0.0e+00 0.0e+00 9.1e+02 61 48  0  0 47  74 56  0  0 54 2415474
BVScale              533 1.0 2.6414e+00 1.6 2.30e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 28528560
BVSetRandom            1 1.0 1.0213e+00 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSSolve               52 1.0 1.5004e-0110.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSVectors             64 1.0 7.6532e-04 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DSOther              155 1.0 1.9093e-03 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Matrix     2              5    446597144     0.
              Vector    10             11    404606488     0.
         Vec Scatter     0              1         1456     0.
          EPS Solver     1              1         2456     0.
  Spectral Transform     1              1          904     0.
       Basis Vectors     1              1         9440     0.
         PetscRandom     1              1          710     0.
              Region     1              1          720     0.
       Direct Solver     1              1        16176     0.
       Krylov Solver     1              1         1520     0.
      Preconditioner     1              1         1056     0.
              Viewer     1              0            0     0.
              Matrix     3              0            0     0.
              Vector     2              1         1792     0.
           Index Set     2              2     12450096     0.
         Vec Scatter     1              0            0     0.
              Matrix     7              7        66696     0.
              Vector    11             11    552300352     0.
          EPS Solver     1              1         2960     0.
       Basis Vectors     1              1        14560     0.
              Region     1              1          720     0.
       Direct Solver     1              1        35184     0.
Average time to get PetscTime(): 1.90735e-07
Average time for MPI_Barrier(): 0.000459194
Average time for zero size MPI_Send(): 3.11734e-05
#PETSc Option Table entries:
-d1 1.0
-eps_tol 1e-9
-j1 1.0
-log_view
-nn
#End of PETSc Option Table entries
Compiled with FORTRAN kernels
Compiled with 64 bit PetscInt
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 16 sizeof(PetscInt) 8
Configure options: --known-level1-dcache-size=32768 --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=8 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-memcmp-ok=1 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-has-attribute-aligned=1 --prefix=/machine_work/IscrC_SkMagn/opt/lib/petsc/3.10.2/prod-intel-mkl_seq-avx512-64bit-double-complex --with-precision=double --with-scalar-type=complex --with-64-bit-indices=1 --with-shared-libraries=1 --with-avx512-kernels=1 --with-memalign=64 --CC=mpiicc --CXX=mpiicpc --FC=mpiifort --F90=mpiifort --F77=mpiifort --COPTFLAGS="-O3 -g" --CXXOPTFLAGS="-O3 -g" --FOPTFLAGS="-O3 -g" --CFLAGS="-DMKL_ILP64 -I/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/include" --CXXFLAGS="-DMKL_ILP64 -I/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/include" --FFLAGS="-DMKL_ILP64 -I/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/include" --with-debugging=0 --with-mpi=1 --with-mpi-compilers=1 --with-default-arch=0 --with-blaslapack=1 --with-blaslapack-pkg-config=/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/bin/pkgconfig/mkl-dynamic-ilp64-seq.pc --with-valgrind=1 --PETSC_ARCH=prod-intel-mkl_seq-avx512-64bit-double-complex -with-batch=1 --known-mpi-shared-libraries=1 --known-64-bit-blas-indices=1 --CXX_LINKER_FLAGS="-L/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/lib/intel64 -lmkl_intel_ilp64 -lmkl_sequential -lmkl_core -lpthread -ldl" --CC_LINKER_FLAGS="-L/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/lib/intel64 -lmkl_intel_ilp64 -lmkl_sequential -lmkl_core -lpthread -ldl" --FC_LINKER_FLAGS="-L/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/lib/intel64 -lmkl_intel_ilp64 -lmkl_sequential -lmkl_core -lpthread -ldl" --with-fortran-kernels=1
Libraries compiled on 2018-12-02 13:09:11 on r000u11l06
Machine characteristics: Linux-3.10.0-327.36.3.el7.x86_64-x86_64-with-centos-7.2.1511-Core
Using PETSc directory: /machine_work/IscrC_SkMagn/opt/lib/petsc/3.10.2/prod-intel-mkl_seq-avx512-64bit-double-complex
Using PETSc arch:
Using C compiler: mpiicc -DMKL_ILP64 -I/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/include -fPIC  -O3 -g
Using Fortran compiler: mpiifort -DMKL_ILP64 -I/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/include -fPIC -O3 -g
Using include paths: -I/machine_work/IscrC_SkMagn/opt/lib/petsc/3.10.2/prod-intel-mkl_seq-avx512-64bit-double-complex/include
Using C linker: mpiicc
Using Fortran linker: mpiifort
Using libraries: -Wl,-rpath,/machine_work/IscrC_SkMagn/opt/lib/petsc/3.10.2/prod-intel-mkl_seq-avx512-64bit-double-complex/lib -L/machine_work/IscrC_SkMagn/opt/lib/petsc/3.10.2/prod-intel-mkl_seq-avx512-64bit-double-complex/lib -lpetsc -Wl,-rpath,/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/lib/intel64 -L/facility/prod/opt/compilers/intel/pe-xe-2018/binary/mkl/lib/intel64 -Wl,-rpath,/facility/prod/opt/compilers/intel/pe-xe-2018/binary/impi/2018.4.274/intel64/lib/debug_mt -L/facility/prod/opt/compilers/intel/pe-xe-2018/binary/impi/2018.4.274/intel64/lib/debug_mt -Wl,-rpath,/facility/prod/opt/compilers/intel/pe-xe-2018/binary/impi/2018.4.274/intel64/lib -L/facility/prod/opt/compilers/intel/pe-xe-2018/binary/impi/2018.4.274/intel64/lib -Wl,-rpath,/machine/prod/opt/compilers/intel/pe-xe-2018/binary/compilers_and_libraries_2018.5.274/linux/compiler/lib/intel64_lin -L/machine/prod/opt/compilers/intel/pe-xe-2018/binary/compilers_and_libraries_2018.5.274/linux/compiler/lib/intel64_lin -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib -lX11 -lmkl_intel_ilp64 -lmkl_sequential -lmkl_core -lpthread -ldl -lstdc++ -lmpifort -lmpi -lmpigi -lrt -lifport -lifcoremt_pic -limf -lsvml -lm -lipgo -lirc -lgcc_s -lirc_s -lstdc++ -ldl
