[petsc-users] DMPlexDistributeField
Adrian Croucher
a.croucher at auckland.ac.nz
Thu Jun 20 23:49:05 CDT 2019
I have been trying to get this FVM geometry data re-distribution to work
using DMPlexDistributeField().
It seems to be working OK for the cell geometry data (cell volumes and
centroids). But it is making a mess of the face geometry data (face
normals and centroids).
Should I even expect DMPlexDistributeField() to work for redistributing
a vector of data defined on mesh faces? Or is there some reason I
haven't thought of, which means that will never work?
The only example I could find anywhere of DMPlexDistributeField() being
used is in DMPlexDistributeCoordinates() so I've been basing what I'm
doing on that.
(I think I have answered my own questions below by experiment- 1) local
vectors should work (they do in DMPlexDistributeCoordinates); 2)
probably doesn't matter; 3) yes.)
- Adrian
On 6/06/19 1:42 PM, Adrian Croucher wrote:
> hi
> I have some questions about using the DMPlexDistributeField()
> function. I have finite volume mesh geometry data stored in two local
> vectors created using DMPlexComputeGeometryFVM(), and I need to
> redistribute these after calling DMPlexDistribute() to redistribute my
> mesh. (I need the geometry data before redistribution, so I can't just
> wait until after redistribution to create them.)
> So I figured DMPlexDistributeField() looks like the thing to use for
> that, using the SF that comes out of DMPlexDistribute().
> 1) Does DMPlexDistributeField() work on local vectors or do they have
> to be global ones?
> 2) It takes a 'dm' parameter and the documentation says this is "The
> DMPlex object", but is that the original DM (before redistribution) or
> the redistributed one, or does it not matter? It looks like it only
> uses the DM to get the vector type.
> 3) It looks like you need to manually create the newSection and newVec
> output parameters before passing them in to this routine, is that
> correct?
> - Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
