[petsc-users] MatPermute problem because of wrong sized index set
Eda Oktay
eda.oktay at metu.edu.tr
Mon Jun 17 09:15:42 CDT 2019
I did but ı didn't send you that part:
PetscInt kk;
for (i=0;i<siz;i++){
if (avr[i] < 0){
++kk;
Mark Adams <mfadams at lbl.gov>, 17 Haz 2019 Pzt, 16:23 tarihinde şunu yazdı:
> You also do not seem to be initializing kk.
> On Mon, Jun 17, 2019 at 4:00 AM Eda Oktay via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hello everyone again,
>> I was making an index mistake in for loop. I corrected it and my problem
>> solved.
>> Thank you,
>> Eda
>> Eda Oktay <eda.oktay at metu.edu.tr>, 17 Haz 2019 Pzt, 10:28 tarihinde şunu
>> yazdı:
>>> Hello everyone,
>>> I am trying to permute a matrix by using a sorted eigenvector in order
>>> to partition the matrix. I sorted the vector and got the index set idx. I
>>> am using 2 processors and I have to divide the vector into 2 according to
>>> the sign of elements (first negative signed ones, then positive signed
>>> ones) first, so I wrote the code below (if-else part). After sorting and
>>> dividing them, I need to permute the matrix with these index sets.
>>> However, in last line (MatPermute), I got the following error:
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Argument out of range
>>> [0]PETSC ERROR: Index 13 is out of range
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
>>> [0]PETSC ERROR: ./son_without_parmetis on a arch-linux2-c-debug named
>>> 5470.wls.metu.edu.tr by edaoktay Mon Jun 17 10:11:54 2019
>>> [0]PETSC ERROR: Configure options --download-mpich --download-openblas
>>> --download-slepc --download-metis --download-parmetis --download-chaco
>>> --with-X=1
>>> [0]PETSC ERROR: #1 PetscLayoutFindOwner() line 249 in
>>> /home/edaoktay/petsc-3.11.1/include/petscis.h
>>> [0]PETSC ERROR: #2 PetscSFSetGraphLayout() line 545 in
>>> /home/edaoktay/petsc-3.11.1/src/vec/is/utils/pmap.c
>>> [0]PETSC ERROR: #3 MatPermute_MPIAIJ() line 1622 in
>>> /home/edaoktay/petsc-3.11.1/src/mat/impls/aij/mpi/mpiaij.c
>>> [0]PETSC ERROR: #4 MatPermute() line 5095 in
>>> /home/edaoktay/petsc-3.11.1/src/mat/interface/matrix.c
>>> [0]PETSC ERROR: #5 main() line 354 in
>>> /home/edaoktay/petsc-3.11.1/arch-linux2-c-debug/share/slepc/examples/src/eda/son_without_parmetis.c
>>> [0]PETSC ERROR: PETSc Option Table entries:
>>> [0]PETSC ERROR: -f
>>> /home/edaoktay/petsc-3.11.1/share/petsc/datafiles/matrices/binary_files/LFAT5_binary
>>> [0]PETSC ERROR: -weighted
>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>> error message to petsc-maint at mcs.anl.gov----------
>>> I also found out that when I look at the submatrix Ais, I got different
>>> sized matrix. For example, I used 14*14 matrix, I get the vector of length
>>> 14 but then idx is divided into 5 and 7 elements so Ais is of size 12. 2 of
>>> the positive signed elements are not counted and I didn't understand why.
>>> I also checked the if-else part and I found out that this portion of the
>>> code is ran by processor 0. Can be this the problem for different sized
>>> Ais? And how can I fix that problem?
>>> Thanks,
>>> Eda
>>> PetscMPIInt rank,size;
>>> MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
>>> MPI_Comm_size(PETSC_COMM_WORLD, &size);
>>> PetscInt kk;
>>> if (avr[i] < 0){
>>> ++kk;
>>> PetscInt *idxx;
>>> IS iskk;
>>> PetscInt sizeofidxx;
>>> if (rank == 0){
>>> PetscMalloc1(kk,&idxx);
>>> j = 0;
>>> for (i=0; i<kk; i++){
>>> idxx[j] = idx[i];
>>> j++;
>>> } else{
>>> PetscMalloc1(siz-kk,&idxx);
>>> j = 0;
>>> for (i=siz-kk-2 ;i<siz; i++){
>>> idxx[j] = idx[i];
>>> j++;
>>> sizeofidxx = j;
>>> ISCreateGeneral(PETSC_COMM_WORLD,sizeofidxx,idxx,PETSC_COPY_VALUES,&is);
>>> ISView(is,PETSC_VIEWER_STDOUT_WORLD);
>>> /*Permute matrix L (spy(A(p1,p1)))*/
>>> Mat Ais;
>>> MatCreateSubMatrix(A,is,is,MAT_INITIAL_MATRIX,&Ais);
>>> ierr =ISSetPermutation(is);CHKERRQ(ierr);
>>> Create Partitioning
>>> PetscInt mA,nA,mL,nL;
>>> MatGetSize(Ais,&mA,&nA);
>>> MatGetLocalSize(Ais,&mL,&nL);
>>> PetscPrintf(PETSC_COMM_WORLD," Size of Ais: %D,%D\n",mA,nA);
>>> PetscPrintf(PETSC_COMM_WORLD," Size of local Ais: %D,%D\n",mL,nL);
>>> ierr = MatPermute(Ais,is,is,&PL);CHKERRQ(ierr);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190617/46fc020d/attachment.html>
