[petsc-users] IS from MatNestGetISs
Smith, Barry F. bsmith at mcs.anl.gov
Sat Jun 15 21:26:36 CDT 2019
  From the manual page: "The reference count is not increased on the returned ISs", so you should not delete them
  Note that the rule in PETSc is items obtained with a call that contains the work Create must destroy the object, if it contains Get then it should not destroy the object.
   Barry
> On Jun 15, 2019, at 9:17 PM, tangqi via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Dear all,
> Do I need to delete index_set from MatNestGetISs? I get my index_set from
>     MatNestGetISs(P, index_set, NULL); //P is a nest matrix of 3x3
> When I delete index_set later
>     for (int i=0; i<3; i++)
>         ISDestroy(&index_set[i]);
> It gives me error
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Wrong type of object: Parameter # 1
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
> [0]PETSC ERROR: Unknown Name on a arch-linux2-c-debug named ba005.localdomain by qtang Sat Jun 15 19:48:29 2019
> [0]PETSC ERROR: Configure options --with-mpi-dir=/usr/projects/hpcsoft/toss3/badger/openmpi/2.1.2-gcc-7.4.0 --download-hypre --with-cxx-dialect=C++11
> [0]PETSC ERROR: #1 ISDestroy() line 428 in /turquoise/users/qtang/Software/petsc-3.11.1/src/vec/is/is/interface/index.c
> Thanks,
> Qi
